View Full Version : Maintenance & Repair
  1. What maintaince goes by time instead of miles?
  2. Rear View Mirror Broke Off!
  3. Slight vibration/shudder over bumps
  4. P0011 Code And How To Fix It
  5. Strange Fuel Smell..
  6. Help error code !!!
  7. squeek brake noise when turning
  8. fuel line
  9. How 2 Adjust Brake/Gas Pedal For Heel/Toe?
  10. Anyone know what this is?
  11. Gas pedal wasn't responding!!
  12. Noise when turn engine off
  13. parking brake light on??
  14. Proper break in for Nismo 1.5 way LSD
  15. clicking from rear axle
  16. exhaust leak?
  17. Tire replacement after feathering
  18. CEL on. OBD2 read p1274 p1283
  19. .delete
  20. Clutch Problems?
  21. 3rd gear grind
  22. Interior Lighting stops working, please help!
  23. touble w/door windows?
  24. Screw you!!!! HELP!
  25. TPMS - Portable DVD Player Conflict
  26. Weird Sound...maybe suspension?
  27. Car problem need help.
  28. Air Bag Light Help!
  29. Ticking noise???
  30. Passenger Door Wiring
  31. Drivers Seat squeaking/Creaking and loose?
  32. cruise problems
  33. Air Filter
  34. 03 streaking windows
  35. 30,000 mile service and brake pads..
  36. Squeaky/Sticky Clutch....Fixable?
  37. Buzzing dash rattle...want to fix...help
  38. wired nosie?? Can you help ??
  39. clutch problem? need advice
  40. Car Wont Start, Key Problem
  41. Removing cover of sub area
  42. Where Is The Clutch Pivot Ball?
  43. 2nd to 3rd gear grinding
  44. Gas gauge not working! car goes to limp mode!
  45. Rear axle clicking TSB
  46. battery light coming on
  47. Oil Dip Stick Question
  48. Clutch Help =(
  49. header install
  50. Car shuts off after changing the battery!
  51. help car dying out!
  52. HELP!:Interior Lights Don't Work
  53. CF Bumper Repair
  54. Electrical experts, help! see link!
  55. Tranny fluid
  56. Re-Shaping Urethane: Help!
  57. Had sway bars installed and now Slip light will not go off?
  58. BIG Problem!!!!!!
  59. Limited slip differential not limiting much
  60. automatic windows
  61. possible to estimate the cost of this?
  62. tranny problems
  63. Steering loose after 7,500 mile dealership maintenance
  64. throttle body
  65. Cruise control does not work!?
  66. radiator/grasshoppers and wasps
  67. Fuel Pump Failure on an 03 350z...
  68. Oil change
  69. please help...losing patience
  70. ses-light on
  71. Battery fit
  72. 2007 Front Bumper Grill Broke
  73. Squeeky belts..........?
  74. Different Window Motor Problem... please help
  75. Magnetic Drain Plug for Transmission: useless, or a good idea?
  76. Applying Clearcoat
  77. clutch issues... i think...help!
  78. Clutch switch is not engaging all the time...
  79. Scratches Around Gear Shift on Console
  80. Stalling? Possibly limp mode?
  81. exhaust/back box where to buy.
  82. 30,000 miles service - Necessary?
  83. Weak start-up
  84. VDC off and slip light are stuck on
  85. Help ME! my Z is pissing me off
  86. A/C Repair
  87. Crank sensor circuit error, Help!
  88. Might be a transmisson problem?
  89. exhaust problem...possibly baffle?
  90. Locking gas cap
  91. Need help finding a tool
  92. Gas Light on @ Half tank
  93. airbag light
  94. Rough Idle and Po300 Code
  95. engine light came on help!!!
  96. Headlights brightness question
  97. Shattering noise\rattle\stiff clutch?
  98. Speedo Recalibration
  99. Problem with my Headlight
  100. How much do you trust your dealership?
