View Full Version : Maintenance & Repair
  1. Planning on buy used Z, but the milage
  2. RPMs and Speed Wont Budge?!?!
  3. Rpm + Fuel Gauges Problems! Plz Help
  4. Clutch noise?
  5. Anyone elses trip odometer failing?
  6. Fuel Pump or Relay car does not start
  7. Tire feathering
  8. Drive Side Window
  9. Rust?
  10. Installed new clutch, flywheel and rear alignment kit, now I've got a rattle...
  11. Making new key.
  12. Lighter socket dead, fuse?
  13. Problems
  14. Neither power windows work! Help please.
  15. Heater Core anybody replace there's yet??
  16. Clutch engages all the way at the top??
  17. Brake noise! (New Brakes)
  18. Battery Charge Problem
  19. Where can I buy diff and tranny oil?
  20. Hearing a weird click when turning left.
  21. Constant Pass Rear Wheel Click..
  22. Help! Air in Coolant
  23. Nissan replacing slave cylinder....
  24. Reset/Adjust window pinch control
  25. Bad MAF symptoms!?
  26. electric problem help!!
  27. Ignition Coil Problem?
  28. Slight Troubles
  29. I think one of my wheel bearings went out tonight
  30. One horn quit...I think
  31. Loss of power...
  32. Weird noise
  33. 1000 dollar lower radiator repair
  34. This fell out of my front grill
  35. Popping Noise
  36. Dead Battery Problems
  37. Oil In Spark Plug Housing, Parts on Backorder
  38. Shifting Issues..
  39. Engine Shuts Off While Driving
  40. diagnoses and suggestions for rear end?
  41. Fuel gauge meter malfunction
  42. Sensor 2 Bank 2?
  43. What direction should puller fans turn???
  44. i propose we make a new subforum to stop the spam crud
  45. ECU code???
  46. Car vacuum
  47. Uut-Oh..
  48. pop charger cleaner
  49. Service Engine Soon Light ! OMG =[
  50. cruise contril
  51. Roadster window rolls itself back down???
  52. shakes at high speed
  53. headlight problem!!
  54. Basic Warranty/Powertrain Waranty?
  55. Weird rear suspension feel
  56. Engine turns over.. won't start.
  57. P0430, Catalyst Efficiency Below Threshold
  58. Window problems please help
  59. Check engine light turns off and on????
  60. Clearing Codes to Pass CA Smog
  61. I think my engine or tranny is damaged HELP!
  62. I dont now what I did.
  63. Car Wont Start HELP
  64. stealership ripoff
  65. Air leak in driver-window
  66. help..
  67. Condensation in headlight, headlight went out, Bulb or Ballast?
  68. Service Eng Soon / P 0183 & P 0462
  69. srs light came on...
  70. Brake lamp fuse keeps blowing
  71. Hard shifting
  72. after X miles of driving, slip and VDC light come on?
  73. Help Please
  74. looking for a nissan tech input.... HELP!!
  75. cruise control problem
  76. Washer fluid reservoir leak?
  77. Passenger window problems help!
  78. AC leak!!!! i guess
  79. Very Loud Transmission Shifts?
  80. high pitched noise in cabin of car?
  81. Anyone intall DRL???
  82. Nissan 350z cd player not working
  83. I'm on my fourth window motor
  84. Just bought an 05 Z 35th...transmission question
  85. any Nissan techs?
  86. my rant....and what did i mees up
  87. What Is This Sound!?
  88. Washer fluid reservoir
  89. Clinking Sound - Help me identify please
  90. i need help
  91. HELP. Trans problem
  92. Improving MPG
  93. Car is jerking under acceleration??
  94. AC Compressor belt sitting on skidplate - needs replaced
  95. recommended height 06 headlights.
  96. whats your favorite wiper blade
  97. P2100 & P2101 Codes
  98. How do you remove the shift lever cup?
  99. no start issues
  100. Reseting side air bag
