View Full Version : Maintenance & Repair
  1. PLS help!! water in car
  2. Got Gas, Get beck in, Smell burning clutch....
  3. Fresher smelling A/C...
  4. 2003 350z Feathering Issue
  5. Replacing Cabin Air Filter
  6. Car won't start, immobilizer?
  7. Belt squeal
  8. fueling issues? fixed mines..
  9. need help broke 10pin m40 harness now guages dont light nor does the sidemirrors move
  10. 2004 Vq35 Help!!!
  11. MT problem & Warranty?? HELP
  12. My Z is sick (in a bad way) - not sure what it is
  13. Coolant Problem
  14. Issues with OEM Navigation System Please HELP!
  15. Steering Problems!!!
  16. i put 6 qts of oilow oil leak!!! plz help!
  17. 350z frame chart
  18. Question about Red Locktite on flywheel bolt for install
  19. Question about flywheel torx bolts.
  20. Rear End Shuttering?!?!
  21. I really need some help with the hatch rattle
  22. Help With Door Locks Asap
  23. recall , replacing hoses on fuel tank
  24. Is it okay to use Dot 4 Brake fluid in the clutch
  25. BOTH front lights?!
  26. Wouldn't start...
  27. Rock Chips = Future Rust?
  28. parts needed for wheel bearing replacment?
  29. 100 point courtesy inspection
  30. driver's side power seats not working!!!
  31. need some advice
  32. tranny fluid
  33. $850 for my Unified Meter A/C Amp!
  34. Oil on Plug, Might be valve Guide
  35. Start up problems solved..
  36. Tach / Rev Counter goes on strike at times
  37. Just change accesorry belts, and spark plugs
  38. First oil change
  39. car won't start during alarm install
  40. liftgate struts
  41. Sticky clutch?
  42. P0420 and P0430
  43. My 2nd thread about this gas tank issue.
  44. Where is my third gear?
  45. Shifter coming loose?
  46. Part numbers for OEM Brembo seal kit
  47. Limp mode...help please!
  48. well im in the club now
  49. Keeping record of oil changes?
  50. Car died
  51. clicking noise in rear of car
  52. The Tool man
  53. bad smell from air condition
  54. I broke bolt off in lower plenum of mrev2
  55. Heated Seats Issue...
  56. Automotive Electrical Expertise needed
  57. power outlets
  58. Oil on spark plug...... Help!
  59. OIL PRESS SLAMMED AT 120+ psi
  60. When to change Trans fluid
  61. window problem
  62. smoke from z
  63. Window motor question
  64. New Clutch / Transmission Fluid Info
  65. Is this the Alarm sensor for the Hood?
  66. Need help with the following codes, P0183 and P0462
  67. Rattling and Vibrations
  68. a/c compressor clutch?
  69. Transmission Problem
  70. Strange vibration/knocking on fast acceleration.
  71. Check engine light after stalling twice
  72. Starting issue
  73. Tire Feathering
  74. Where is tensioner to replace belts
  75. HELP! Z is wobbling when turning right!?
  76. SES code 1284 & 1273
  77. Strange Whine Between 1800-2000rpm
  78. Help!!!
  79. Crazy sound when turning
  80. Dealer says I need a new Intelligent Power Distribution Module
  81. Over revved...should i be worried?
  82. I got another Z but it didn't come with the wireless alarm remote
  83. New clutch feels almost worn out?
  84. Help me fix my broken passengers seat.
  85. VDC Off & SLIP Light on.
  86. strange problem...engine randomly shutting off
  87. Auto Tranny question
  88. horn won't stop
  89. Grinding 2nd Gear.
  90. Gas filter?
  91. radiator fan wiring
  92. Fogging in my headlights
  93. Tachometer Froze for 5 minutes
  94. Passenger window slowly falls when driving?
  95. tranny fluid on rubber hoses
  96. Warranty Service
  97. A/C Door Vent Removal - Any ideas? (pics)
  98. Loud CLUNK Front Driver side - Stock 06
  99. Help me improve my mpg
  100. Gas Tank Size???
