View Full Version : Maintenance & Repair
  1. Chip in Hood of New Z
  2. my z is using 2 quarts of oil a week
  3. Recommendation on Clutch and Tranny fluid for JWT clutch and flywheel?
  4. Z is starting to squeak, what could be squeaking?
  5. UTEC affecting NATS security system
  6. Gf spilled coffee on seat....
  7. Possessed Car......Turbonetics install from hell - HELP!
  8. driver side map light out
  9. HID headlights arent as blue any more
  10. Wiring Diagram Help? B2S2 O2 sensor wiring
  11. Tach gauge froze for awhile
  12. white smoke
  13. speedometer not working???
  14. Codes???
  15. Z getting sluggish, anything else I should check?
  16. jack/ramp preference to lift our Z's...
  17. Having Car troubles
  18. Help please! A few quick OIL questions...
  19. High Idle on Automatic Tranny
  20. SES light
  21. Passengar Airbag Keeps turning OFF
  22. The ULTIMATE MANUAL, every wire, fuse, screw and stitch explained - distribute???
  23. BEFORE you REPLACE the window motor - check this out
  24. Is this normal?
  25. Oil leak from somewhere
  26. sigh.
  27. obd II plug in
  28. HELP!! overheating after installing koyo.
  29. 1st gear MAJOR chatter
  30. Chatter? Rattle? ... not sure what to call it but concerned
  31. HELP!! Car wont start but everything else turns on
  32. Help needed.
  33. Clutch pedal on the floor
  34. Strange ?
  35. any advice on this
  36. Steering angle sensor?
  37. Volts Jump, Car bumps..
  38. p1614 and p1615 nats malfunction
  39. Airbag light is always flashing
  40. Rattleing noise in engine bay - injectors?
  41. Stripped Bolt Holes - words of advice please
  42. Power Steering Fluid
  43. Window auto adjust
  44. Cruise Control Malfunction...HELP
  45. Does your A/C need to be on 60 in order to get cold air?
  46. turn signals blink once and stop blinking
  47. Weird noise when turning off car
  48. Mystery window feature
  49. Clunk from driver door, not rear left axle.
  50. engine service soon codes
  51. WTF is that noise???
  52. coolant mess
  53. Whining noise when cold
  54. Please help! before the dealer rips me-off.
  55. Irritating vibration and noise in my '03 Enth. Z
  56. Clips holding rear body kit together
  57. Car cover & Battery Tender?
  58. Power Steering wheel is loozen
  59. What would void your warranty?
  60. BAD PRIMARY 02's
  61. Effing Nissan and their effing window motors!!!
  62. Is it too late to abort a radiator flush?
  63. Auto A/C, No heat with idle...
  64. Rear Hatch Strut replacement
  65. help with P1283 code
  66. p1614 and p1615 codes
  67. Unexplained High-Pitched Rattle
  68. Um... help? Freaking out!
  69. what's wrong with my car?
  70. blinking headlight
  71. Help!!! She won't start!
  72. No "Slip" light
  73. Rear Defroster draining my battery?
  74. Thuka thuka noise from 20mph to 60mph
  75. Long Shot... Anyone have this jack?
  76. tune up
  77. window problem..help
  78. noise in steering column when truning wheel
  79. Help! Can't match the Service codes???
  80. The Z is Dead...Warranty Question
  81. Airbag off?
  82. gator belts
  83. burning plastic smell
  84. Seat squeak
  85. Once again, I hate my window!
  86. mystery bolt?
  87. Broken Gas door button.
  88. How do you replace the wiper blade on the rear hatch?
  89. Tire Pressure Sensor
  90. Startup Issues After JWT Clutch/Flywheel Install
  91. Hot air/cold air but nothing in between
  92. Rough idle, tubing
  93. Anyone know of a good car cover?
  94. Attn Nissan Techs
  95. Won't go into gear
  96. 07 Recall for Slave Cylinder (CLUTCH)!
  97. Nav Door Broken
  98. Rattle from Stabilizer Bar
  99. P2A00 Code.. what is that?
  100. New Motor?
