View Full Version : Maintenance & Repair
  1. passenger window only goes down
  2. synthetic
  3. Heater problems..
  4. Loose Gas Cap and Limp Mode
  5. Help me identify this bolt...
  6. Turning off Passenger Seat Belt Light w/ Aftermarket Seats
  7. BCM problem ? weird issues...
  8. Spare fuse?
  9. Big Power Loss Exiting Highway Today
  10. Stock CD player skipping when cold?
  11. Black and decker jump starter, work ok on a Z?
  12. 2003 track with OEM navigation problem
  13. 350z engine light, TCS light and slip light all ON...
  14. Smelly A/C after rain
  15. Best Play To Buy Rotors/Pads
  16. Limp Mode???? No CEL....
  17. Passenger window just quit
  18. smoke when i first start my car
  19. A/F sensor 1 on bank 2
  20. Starting car after 6 months of none use? ? ?
  21. Z eatsah de oil.
  22. Problem between 2000-2500 RPMS
  23. Water Puddle, AEM CAI, car idles erradic and nothing above 2500rpm
  24. Automotive display ramp? home maintenance?
  25. 03 Window Problem
  26. broken fuel gauge?
  27. OEM front chin spoiler
  28. Fuse box got wet..
  29. clutch is slipping
  30. Stuck at work w/ my clutch pedal stuck
  31. TCS OFF and SLIP Light... Help....
  32. 350Z 2003 Battery or Alternator Problem
  33. Falling out of 4th gear
  34. Car won't Start
  35. DTC definitions - Nissan and generic
  36. Engine Noise when cold and accelerating
  37. 04 Z 53k mile replacements
  38. No Interior Cabin Lights?
  39. Problem with Gas Gauge and or floater
  40. Rear axle removal question
  41. My Z Won't Start... and the Dealership is stumped :-(
  42. Very loud "POP" coming from front of Z
  43. In-dash cup holder, and the tale of the magical disappearing screws.
  44. Shift Knob Noise
  45. Paint damage. I'm going to cry.
  46. Is anyone's plastic turning white?
  47. i need help, installed test pipes an they smoke
  48. Rattle in neutral
  49. Speed Wobble? *HELP*
  50. o2 sensors
  51. 07 axle clicking?
  52. Headlight problem
  53. Gas Door?
  54. Body guys...chime in plz
  55. Tripometer resets everytime i turn off car.
  56. 2004 Z: Oil Drained = 3.5 quarts....What's going on?
  57. The Gas Gauge Dilemma (Detailed)
  58. weird problem with z..windows rolling down itself
  59. Repairing scratches, scrapes, chips?
  60. My Z shut down for no reason
  61. Alum jack suggestions
  62. wiring mess
  63. HELP! OEM brake shims on non-brembo
  64. ABS, TCS, Slip lights stuck on
  65. Tire Rotation and TPMS Question
  66. started sputtering??
  67. At the dealer ship again
  68. 350Z = Diesel Engine? And Tranny Question
  69. Question for the mechanics
  70. cigarrette adapter wont work which fuse
  71. How do i remove the headlights!
  72. Tpms Issue...again!!
  73. Vacuum hose problem?
  74. Help!!!
  75. Headlight problem
  76. what the hell does this code mean???
  77. Clock spring repair???
  78. Anyone know how to remove the windshield wipers?
  79. '07 Tach Sticking
  80. Broken Mirror Glass
  81. Drive Cycles?
  82. Clutch sticks 1/2 in when launching
  83. Plastic that covers oil filter?
  84. Finishing coat for rims
  85. installed aftermarket wheels w/o tpms
  86. Help! Vdc Light Brake Slip
  87. low profile ramps for teh cheap
  88. Difficulty? Alternator Replacement
  89. Help! Body Repair guys opinion needed.
  90. Wierd noise when turning
  91. Sticky 2nd gear - common? Usual?
  92. signal lights
  93. Blue Tape Question
  94. I Hate My Window!!!
  95. Window Question
  96. Throttle Body Recalibration
  97. Unusual noise coming from car
  98. P0300 Random Cylinder misfire
  99. Volts in Z battery
  100. CEL error code
