View Full Version : Maintenance & Repair
  1. Do these readings look normal?
  2. Comprehensive stock parts website?
  3. CHain Noise?!?!
  4. putting the Z on all fours
  5. Fuel tank problems
  6. CEL light on gas tank
  7. p0171 code on a stock 06
  8. haven't driven (or started) my G35 in 6 months.. suggestions for maintenance?
  9. Anyone having clutch problems with an 06??
  10. Service Engine Soon Light
  11. help with bad door ding and dented sides... pics inside
  12. A/C Compressor Won't Turn On!?
  13. Window Keeps Getting Stuck
  14. Please Help with electrical problem!!!
  15. Z died crossing a busy road!
  16. tire feathering rotate / swap front tires / mount and dismount from rim / shift belts
  17. 30K Service at 37K
  18. Build Thread: 2004 Theft Recovery Touring
  19. Thinking of getting an 03 Touring...tire feathering question
  20. I think I"m in trouble....
  21. Air Filter Poll
  22. Rear suspension squeak
  23. how many times have you had faulty airbag module(s) replaced?
  24. My Window
  25. 03 Z won't start?
  26. Jack Points
  27. Not your average window question...
  28. Noise when braking
  29. Need help on getting the CEL codes plz...
  30. Help!!!!!!!!!
  31. Corrupt ECU?
  32. Rock Chip Fix?
  33. abnormal noise on my wife's car
  34. fluids/plugs
  35. questions questions cruise control disaster
  36. window switch problem
  37. I'm getting pretty good at replacing window motors
  38. Is 10w-40 oil okay?!
  39. Car Parts
  40. Transmission Warranty Question???
  41. Clutch Bleeding
  42. Car stalling at idle
  43. Low Wiper Fluid Light Problem
  44. Rebuilt title, warranty issues, only 1 month Out of warranty. What to do?
  45. Gray smoke coming from tail pipe...
  46. fuel tank TSB
  47. transmisson help, syncro???
  48. anyone had this problem before???
  49. gas problem
  50. Window Repairing Stripped Screw Fix??
  51. Car wont hold idle when starting up
  52. Hissing Noise from rear
  53. Non- HID Light Bulbs
  54. Air Leaking sound under car..
  55. Engine Removal
  56. Injector Flush? 45,000 mile service?
  57. intake problem....please help
  58. compression test?
  59. A/C Fill Port
  60. any ramps to hold up whole car??
  61. question about aftermarket flywheels
  62. Window ripped a chunk off my roof
  63. Looks like I need to replace my window motor for a second time.
  64. passenger window acting funny
  65. What service intervals do people have?
  66. Question about Fuel filter, advise is needed.
  67. stupid gas gauge blows
  68. front brake hose replacement
  69. Service engine light on, need help finding part
  70. Strange throttle lift vibration
  71. 06 dash sound
  72. battery leak?
  73. Found Maintenance Service Manual
  74. HELP cant start my 03 z (Its not the Batt)
  75. 05-06 owners review?
  76. oil in plenum?
  77. something rings during breaking
  78. Wheel Bearing
  79. IS my clutch going BAD?
  80. window rattle when its all the way up?
  81. Question about power loss
  82. How should i deal with this problem?(window motor related)
  83. Slipping indicator
  84. what would be the problem
  85. Help Windshield Wiper
  86. Bad window problem(still cant figure it out)
  87. leak from valve stem
  88. Code P0183 Fuel tank temp sensor...?????
  89. changing AC hard line?
  90. Swapping base seats for leather, power, and heated seats
  91. help... window switch diagram
  92. Gauge cluster DEAD!! need help!
  93. Cracked Test Pipe
  94. revving slower than a snail.
  95. stripped bolt how to get off
  96. Help with my acceleration PLEASE!!!
  97. What just happened to my motor
  98. tech help
  99. rpm's tach stuck??
  100. My Litres per 100km is screwed up
