View Full Version : Maintenance & Repair
  1. Oil in exhaust
  2. just a quick ques
  3. Salvage Rebuild Help
  4. Worst Oil Consumption yet
  5. 06 GT Possibly over heating
  6. Going to dealer tomorrow.
  7. my creaky clutch is driving me NUTS!
  8. Window motor going out
  9. Does this sound right - need new brakes/rotor?
  10. Car just got keyed!
  11. code p1283
  12. any one had any transmission problem?
  13. Brake Job by Dealer?!?!
  14. Help with Front Clicking sound
  15. My A/c Doesnt Work!!
  16. popping in clutch
  17. looking for shifter plate alignment proceedure
  18. Anyone seen this???
  19. Dent = Depression, Fixed = :)
  20. What are the Torq specs for Caliper Bolts and Lug Nuts on a '04 350Z Roadster 6 speed
  21. Service Engine Light.
  22. driver window problem
  23. throttle body cleaning
  24. Break Pad Service Question
  25. HelPPPPPPPPP clutch problemm??? possiblyy.. HELP
  26. Automatic locks no longer automatic
  27. My z clutch is stuck inside
  28. TSBs Covered Under Extended Warranty?
  29. Technical question
  30. I'm getting shocked...ouch!
  31. Engine Start Problem - Fuel Delivery Issue
  32. a/c auto mode acting weird
  33. Change Drive Belts Myself or Send it to a Shop?
  34. Weird stall at startup
  35. Replacing the window motor is fairly simple v.save yourself $500
  36. Please HELP!!! ASAP
  37. Brake Light Problem
  38. When does the Check Engine Light come?
  39. Tail Lamp Relay...
  40. What's going on with the performance of my Z
  41. Clutch Pedal Sticking?? What Year Car??
  42. concern about coolant level?
  43. Transmission Noise
  44. Stupid people
  45. Airbags question
  46. My Shift Level bolt snapped off the bottom of the lever!
  47. Definition of Gear Grind
  48. question about oil change intervals
  49. Window Problems
  50. Help, Dealerships have no idea what's wrong
  51. Service Engine Soon + VDC Off + Slip Lights
  52. Air Compressor Recommendations
  53. service light one
  54. Rear Axle Clicking
  55. Burning
  56. need help asap im about to cry..
  57. 350z in storage doesn't want to start
  58. Time for oil change??
  59. Post Fuel Hose Recall Problems
  60. Sqweeking noise from DS rear.....
  61. Belt Replacement
  62. strut bar adjustment
  63. Axle Click
  64. Turn Signal Click
  65. Battery dies again!!!!?? Help?
  66. Buzzing Noise from MAF when heated ...
  67. Fuel hose recall fix = clicking?
  68. outside temp gauge prob
  69. crap.3rd gear grindage
  70. Clutch Sticks - Major Safety Issue
  71. Under Hood Wiring Diagram...
  72. fuel gauge going crazy
  73. My 350Z does not crank sometimes..help me out
  74. Clutch pedal stuck...can't shift gears
  75. Damn 350z...
  76. HELP engine burning oil!!!
  77. Axle clicking fixed twice, but what else is clicking?
  78. Accidental Off-Road adventure = Weird results - Help please!
  79. Alignment Question (not feathering related)
  80. A/C automatically turns on... anyone else?
  81. HELP - Need nissan dealer near Ft. Lee NJ / NYC
  82. Anyone in SoCAL....Know of Repolishing shops???
  83. Fluctuating idle
  84. wat is the best thing to do to solve tire feathering issues?
  85. OMG help PLEASE EMERGENCY!!! ENGINE = FCUKED!
  86. Strange problem, Loss of RPM and MPH data
  87. For those who installed Mrev2 + Spacer themselves...help?
  88. E-Brake light question
  89. Radiator/Heater/Thermostat problem with my Z :( Anyone know?
  90. Clickling from underneath my car
  91. ECM Power Supply Heater
  92. Rattling noise ?
  93. Problem with Electronic Throttle Chamber??
  94. Injen CAI wore a hole in the A/C pipe
  95. Broken Side View Mirrow/Minor Accident
  96. Tire Feathering or Defective Tires?
  97. Can't Fill Up on Gas!!!
  98. Lug Nut torque setting
  99. motive bleeding machine / speed bleeder
  100. amsoil 5w-30
