View Full Version : Maintenance & Repair
  1. amsoil 5w-30
  2. Brand new brake pads, but still squeeking!?
  3. Question About Clutch/ Flywheel
  4. Passenger Window nor working
  5. rebuild for a vg30dett
  6. rewire traction control
  7. Window Grease question...
  8. remove CF side mirror covers?!
  9. tran/diff oil ??? Summitracing part#
  10. TB coolant bypass plug (f**king aps plenum)
  11. Stock Wheel Fix
  12. Okay to switch from 5W30 to 10W30???
  13. ABS Problem?
  14. Oil Consumption test
  15. Prices For Clutch/Flywheel
  16. What type of coolant?
  17. SES Light
  18. 2006 Z Roadster 3500 miles - brakes squealing BAD
  19. Brake light came on while driving..
  20. My E-brake and traction control lights won't go off...
  21. 2004 with 6,000 miles having tranny issues... please help..
  22. steering wheel question
  23. i am an idiot with cars please help me
  24. Engine Revs on its Own, Throttle Plate?
  25. Click / creak sound?
  26. brake problem
  27. Info On Winter Storage
  28. Cracked DC Sports SS Headers
  29. Clearing ECU codes
  30. Please help me find a fuse
  31. Replacing the Wiper Blade
  32. flooded engine or ????
  33. Installed new window motor and its acting weird
  34. Little help needed with a rebuild
  35. DYI Coolant fluid flush?
  36. Engine warning lights
  37. Cooling System Service 60K miles
  38. Will a 04, 05 or 06 manual tranny work in a 03?
  39. Do i need a tranny replacement?
  40. Replacement of Headlamps
  41. 2004 Nissan 350z "Slip" Light Illumination
  42. New Owner - Clicking Noise in Neutral?
  43. Extend Warranty?
  44. VDC Problem????
  45. Driver Side Window Stopped Working
  46. 2006 Tranny Being Replaced
  47. CD wont come out! pls. help
  48. window issue
  49. Anyone use Castrol GTX 5w-30?
  50. Need help with soft top electrical
  51. Condensation in the headlight.
  52. "Whats that weird creaking noise when i go over bumps?"
  53. non 350z question (Pathfinder)
  54. OK weird brake issue...
  55. Stalling!!!! Need Opinions..
  56. Anyone in Canada got TRANNY replaced?
  57. Someone go and check if your front (non Brembo) rotors are concave or flushed
  58. used to have axle clicking noise, now its gone... what happened?
  59. DIY Maintenance gurus please chime in. WHERE TO GREASE / LUBE?
  60. Paper Bag + LSD = $2000?
  61. Oil Consumption
  62. How to bleed the brake fluids
  63. Rev Guage Braking???
  64. 3300 Miles... Sound coming fron under car...
  65. Something knocking at my...
  66. 2006 squeak
  67. torque spec for caliper bolts
  68. 5AT Fluid Change, no internal filter? WTF
  69. Brake, VDC and SLIP came on help!
  70. Repair...cracked lower plenum?
  71. A 5000 mile oil change interval...
  72. A/C Blows Water Vapor
  73. Keeps stalling/no restart....
  74. 350z Enthusiast electric problem??
  75. Exhaust leak cause oil pressure to drop?
  76. Grinding into 3rd ONLY...Why?
  77. Maniual Transmission rattle
  78. Windshield wipers for 2004 350Z:
  79. some questions on pinging
  80. How to Change/Flush Radiator Coolant?
  81. just wondering
  82. Rear full of water
  83. Need help removing my AC Unit..
  84. Gasoline in a diesel engine??? Help please...
  85. TPS suddenly stopped working and acting wierd!!
  86. VDC button fell into my dash...
  87. Car Bounces Up and Down?
  88. Mechanic's Advice Needed...
  89. 3 weeks old wont start
  90. Bad grinding noise comming from front left brake, plz advise!
  91. quesiton about headgasket
  92. Tranny moving slightly and clunking???
  93. Repair Manual
  94. need help identfying part?
  95. Windor motor or mechanism?
  96. stripped bolt hole for strut bar
  97. Squeeky Clutch??
  98. Navigation problem
  99. The dreaded tire wear.
  100. Simple and Effective Breaker Bar = Metal Pipe?
