View Full Version : Maintenance & Repair
  1. Issues dropping the top
  2. AC Doesnt turn on or does randomly.
  3. Bump by my left foot
  4. Bad Vibrations... Front end troubles. Help APPRECIATED
  5. overheating could this be my thermostat?
  6. HELP! VDC sensor reads *OFF*
  7. Violent vibration coming from where?
  8. 03 350z Engine shut off while driving.
  9. Stock oil pressure gauge
  10. 03 6MT - Backup Light Switch
  11. driver's window
  12. Gauge cluster going out?
  13. Need Input, Possible Accident Situation
  14. :( Slip,vdc,brake, lights not turning off? help
  15. oil pump broke/fixed.
  16. O2 voltage good or bad?
  17. Calling those that have torn down the vq. Need help
  18. OC Stock block rebuild question? Help needed.
  19. coolant level
  20. PCV valve troubleshoot
  21. Problem with Intake or MassAirFlow?
  22. Ecu power supply code?
  23. Noise from A/C compressor?
  24. Thermostat not opening?!?
  25. Removing the pulley off the alternator?
  26. Which belt does a/c uses?
  27. Car just died!!
  28. Radiator Fan question
  29. Rattle under driver seat area of car?
  30. Headlight bulb problem>>>
  31. 03 Getting the New Transmission - is old one scrap?
  32. couple question on electronical
  33. 2003 350z brake problem
  34. Touch-up paint.. my new best friend?
  35. 2003 350z TPMS Backwards/faulty?
  36. Why is my ride super bouncy??
  37. Broken Drive Shaft
  38. DIY Request : Gas Fuel Filler Door Actuator
  39. help with draining coolant and refill
  40. Driver side window problem
  41. quarter panel window install
  42. P0420, Rich, n/a build. Common issue with resolve?
  43. Lost KEY!! Help!
  44. Sputtering above 2200 RPM's
  45. Axle boot installation
  46. clear liquid dripping from front right of 350z
  47. 06 350z rev needle bounces??
  48. Headlight spring clip that holds bulb in place HELP!
  49. Sound/vibration coming from rear. help please
  50. Name that noise!
  51. Rear O2 question
  52. 2 Dealerships, Still no luck :-(
  53. Code P0455
  54. What do you guys think of this?
  55. Best Sparkplug, Gear oil, Diff fluid.
  56. Bracket/Line on top of trans
  57. Oil Pan Gasket Leak
  58. Gearing issue
  59. Need HELP figuring out engine problem
  60. Alternator change question
  61. Error code P2135! Do I have to replace the throttle bod
  62. exhaust rattle
  63. can somebody identify this sound?
  64. VDC Problem, Have Video....Need some help
  65. clutch pedal issue - part(s) info needed
  66. 08 Z Thermostat stuck open?
  67. 06 350z track makes crackling noise on slow take off
  68. "clicking" noise in 5at?
  69. CLicking in the rear on acceleration
  70. wrong pivot ball installed
  71. P1078 cel
  72. what oil to use??
  73. redline mt 75-90?
  74. Clutch Fluid Maintenance
  75. Not sure if it's a clutch problem or not.
  76. Follow Up to Power Window Motor Replacement
  77. Redline 75w90 or 75w90 NS for stock VLSD
  78. High idle speed HELP
  79. Voltmeter not working on 03??
  80. 04 350z wont start
  81. window problem.
  82. Knocking Noise over Rough Ground
  83. Idle issue after nitrous??
  84. Is my clutch slipping?
  85. Will I need to replace the whole front bumper?
  86. door dinged today. is it fixable?
  87. Clicking Noise When Turning. What is it?
  88. Code P0441
  89. Question Regarding Ticking Noise
  90. when car is first started one time noise when steering
  91. 85k Service Costs
  92. Noise Underneath Car???
  93. how could i flush engine oil cooler (oil)
  94. i keep blowing ignition/ECCS fuse...
  95. What coolant line is it+why do people not use it
  96. 350z clutch problems
  97. Coil packs frying.... Help
  98. HELP - Fuel Gauge Fluctuation
  99. are all ac/heater blowers the same fitment for 350z?
  100. Leds cruise control
