- Magnetic oil plug
- Help with front driver seat part
- Please Answer
- Bolts securing underpanel
- Help PLEASE!
- Passenger side window stuck 3/4 down.
- Is car running Lean??
- Best oil to use? Amsoil vs Mobil vs Castrol???
- paint + egg..
- Question about my car
- E-brake quit working! Help!
- Headlight question
- Cold Engine Squeel ??
- Transmission noise and another issue
- HELP WITH TRANNY! 50K MILES need advise
- HELp CLUTCH READJUSTED ITSELF!! HELP~**
- Electrical problem ??
- Nissan Recall on 52,400 350Z's
- Possible Fix To My Rattle Problem!!!
- Code p1681
- Question About Rust...and Warranty
- Tire Feathering Class Action
- Still have rattle under left windshield pillar
- Hmm where to get parts?
- Occational clutch slipage..What's up with that? Normal?
- Squeak in rear passenger side(suspension)
- Window, auto-up broken? Help
- What would happen if...
- Question About Touchup Paint and Clearcoat.
- Confused about funny sound...
- Need Help?! Car won't start....
- oh this is wack...warranty issues.
- The Clicking axel is back!!! YAY!!
- Hears what my rattle sounds like....
- Bad Noise! not sure what?
- How do you remove plastic pieces on hatch??
- Air & Fuel Filter
- weird whistling sound?
- Problem with ABS, TCS, SLIP Lights!!!
- Won't Start (Clutch Sensor?)
- Windshield Replacement - Safelite.com
- Engine Light!! Help!!
- Brake Light on
- Switched back to stock size tire, now steering wheel shakes
- Tranny question....
- 2003maxima 'fender bender'
- Reputable Mechanic / New Short Block
- Window rattle,drivers side door
- Problems: brakes, tranny, clutch, rattle
- AC belt broke off, should i upgrade? how hard to re-install
- 0w-20 motor oil...good or no??
- HID Pattern
- unsteady idle...
- popping sound in an 06 when clutch in..
- 3k maintenence help!
- Front end problem
- Smell of Gas Through the Ventilation System
- Let's play "Find That Rattle"....
- Removing fenders and doors - need help - lambo door uninstall
- So my dealer quotes me $599 for 30K service!
- Garden Grove Nissan are F**KERS!!!
- anyone know a good mechanic in la area?
- Whats eating my battery?? Help Diagnose.
- Spark Plug Question????
- Drivetrain Question
- rear end and axle
- ac/heater problem...
- 30,000 mile premium or normal Maintenance?
- bad brushings?
- Redline Gear Oil
- Redline Gear Oil
- Shaking Tranny Letting Off Gas?
- Brake pressure goes nuts! Please help!
- Window Issues
- Wind wistle from 35-55mph:(
- squealing/squeaking? front wheel when driving
- CD Player Problem...
- Ok...here we go again
- Driver window...PLEASE HELP
- Fuel Filler Recall Info
- nissan ****ed me!!!!
- front wheel isnt centered.
- Weird sound engine from the engine. Sounds like a cracked manifold but its not
- Transmission Problems After Clutch Change
- no power when i gunning it. HELP
- rear axle
- 30,000 mile service
- rear windshield washer fluid...
- Contacting Nissan Direct
- front camber woes
- yes another gear grind question
- Crank Pulley Wobbling!.......
- Horrible noise post clutch&tranny replaced -v008 & 05+ M/T Z owners I need your help!
- Fluid Dripping.....?
- Front bumper removal RANT
- Can there be water flooding my engine?!
- No Return Clutch
- Car Won't Start... please help?
- How to reset the AirBag Warning Lamp
- Breaking Noise...
