View Full Version : Maintenance & Repair
  1. Temp solution for nasty hood scratch?
  2. Throttle Body Recalibration Required?
  3. Coolant Level
  4. Passenger Side Window Retarded...
  5. wtf!!! please help if ya can
  6. Axle click question
  7. Daylight driving lights not working!!
  8. are all of these problems related?
  9. Maintenance
  10. Rattle in the rear strut bar cover
  11. RPM guage does not work sometimes?
  12. Auto window - rolling half way down...
  13. Handbrake Light, VDC Off Light, & Slip Light Turning on Randomly while Driving!
  14. Help!! wiring problem
  15. Help!!
  16. Tranny shaking on idle
  17. Low Beam Trouble shooting need help!!!
  18. Power seat problem
  19. PCV Valve
  20. Faulty brakes
  21. electrical impacts
  22. How much oil needed to replace tranny?
  23. Service engine soon light?
  24. Stalling leads to New Crank Position Sensor
  25. Tranny problem need help!
  26. How to avoid Tire flat spotting
  27. Storing the Roadster for a year!
  28. rear sqeaking when driving over bumps?? and signs of a needing a new clutch?
  29. Weird Sound
  30. A/C problem
  31. Your Plenum
  32. Problems with my COMPUSTAR... someone help please
  33. Dealership... - need advice
  34. Brand new engine bounces off rev at 2500 RPM
  35. Would you $$ the dealer?
  36. need tech help
  37. Starting Problem
  38. Loose passenger side window with rattle
  39. Are one of my radiator fans broken??
  40. What's with my gas tank?
  41. Dealer Rip Off!
  42. went to dealer for axle clicking problem
  43. whinny sound on passenger window roll up...help!
  44. Wanted: Behind the seat trim piece
  45. sealant
  46. Behind the seat (cubby?)
  47. Spots on inside of plastic headlight encloseure
  48. Ohh NO!!!
  49. Oil pressure gauge is really low
  50. Strange transmission rattle
  51. LH Headlight Low Beam not working!
  52. Too Much Oil
  53. Problems with pass window...anybody have wiring diagnostics
  54. my theory on why Z/G trannies have so many problems...
  55. Brembo calipers leaking
  56. preventative maintenance??
  57. Hotspots on clutch / flywheel?
  58. antifreeze/coolant?
  59. RPM/Slip light come son when TCS is turned off!
  60. getting rid of rust?
  61. 05 ECU reset
  62. brief grinding noise on cold starts
  63. Air Bag light blinking?
  64. Fuel Pump Upgrade
  65. Impression after MT fluid and Diff. fluid change
  66. Bolt Size Need Help...
  67. Help!!
  68. my trunk won't open...
  69. Got my CEL codes, what is wrong with my car ?!?
  70. ut oh!
  71. Tire Pressure Problem
  72. Manual Transmission Fluid Opinions
  73. Balancer q's ...
  74. Iridium plugs?
  75. Oil discrepency?
  76. scuffed rims?
  77. HELP! Engine Stalled out of nowhere!
  78. pedal shaking at 1800 RPM
  79. Z mysteriously shut down
  80. Window rattle
  81. Belt squeak
  82. Nissan Touch Up Paint
  83. 1 Month remaining on Warranty?????????
  84. How do you get to the cigarette lighter wires?
  85. 03' Replacement Tranny
  86. Fix-a-Flat and TPMS
  87. squeaking clutch...
  88. Car Stalls...Service Engine Light On...Possible TPS?
  89. idling problem
  90. Synthetic a problem????
  91. speaker problem!!!!
  92. help w/ performance nissan dealer situation
  93. Power steering problems
  94. rattling noise is going to kill me!
  95. Belt Squeal?
  96. Code P1121?
  97. Door Rattle
  98. clicking sound
  99. is it new rims or what?
  100. Yet another tranny question...
