- How would you tell...
- Finally...Possible"CLASS ACTION LAWSUIT" For Tire Feathering
- Dealer screwed up sensors
- Small outward ding on passenger side
- Feathering...think I got it! HELP
- Stock pulleys/belts are SQUEELING!
- Car wants to die when idling at 500rpms......
- Whats the Problem with my Z???
- Weird noise when from stop?!? Help please..
- SF East Bay Area Dealers/Autoshops
- Do you follow the maintinence shedule in the manual?
- its that topic again we all love hearing: rear diff. oil
- Official tools thread - questions and answers
- HELP: weird noise heard when engine crosses 3000 RPM
- Multiple ECM failures... Anyone else?
- Air bag and service light is on...?
- Coolant Change Tutorial
- Is squeeling from the clutch pedal normal when shifting.......
- PCV Replacement
- Help!!! Car Wont Start!!!!
- HELP!!! CAR WONT sTART!!!!
- Expensive Nissan pads or aftermarket pads?
- Squeeky brakes
- bose problem
- How to reset the ECU ?
- 04' Cloth seat fraying
- Stupid Rock Throwing Kids...how much will this cost?
- Nissan CEO Phone Call Transcript
- What causes tire feathering ?
- Tire Feathering caused by tires not suspension
- Annoying Noise....
- What do I use to clean my MAF ?
- Final Feathering Fix is at Hand
- Touch up Paint tips?
- did the bose fix now audio pilot broke
- Clutch, Flywheel problems... Help!
- Fixed Rattles this weekend, heres what I did:
- oil pressure gauge and exhaust smell (long)
- Help: how to adj. torque wrench
- Non-HID headlights
- Emergency brake, VDC Off, and SLIP lights all on... need help troubleshooting...
- One reason to attend ZCCA 2004 convention
- Machining Front Non Brembo Rotors?
- Moisture trapped in tail light
- Is there a way to tell what tranny revision you have?
- Heater shut down @ stops
- Jack Stand attachments?
- How do I settle with NNA on Feathering?
- Getting a new Tranny
- HELP! Grease Streaks....
- Clicking sound when accelerating?
- Lemon Law Help!?
- Wheel Repair Redux
- Scraped Wheel Rim
- Nissan finally replaced my engine
- Any Dealers Out There Have Paint Code for Factory Wheels?
- To Lemon Law or Not to Lemon Law
- crinkling sound under car after driving
- Scratch on horn cover?
- Need help with headlight harness removal
- Valve Cover Gasket Leak
- turbo
- price of new winshield ??
- Q about arbitration & buyback!!
- Routine Oil Changes not at a dealer?
- Request - Serivice Manual Sections - Cam's & Pulleys
- which model is the worst??
- 350 Z service manual
- The problems just keep mounting...
- Not sure if I like new tranny
- Tire feathering/Tire swap
- Tranny update. They're replacing it
- trunk latch not releasing
- Almost at 25k miles... Fuel Filter?
- My Dome lights are out
- Considering cancelling extended warranty
- NISMO S-tune Suspension & VDC
- Thunk noise near rear hatch when accelerating from a stop
- Popping noise from drivers seat
- Help! My shifter vibrates with a clinking sound
- why does my car pull to the right????
- Paint repair-Am I being screwed?
- HELP! My car won't run becuase it's Running WAY TOO LEAN (so the dealership says)
- Please help car still pulling to right
- Recommended oil
- Approaching 30K miles... How much $ for complete fluid flush?
- Who went to arbitration on TIRE CUPPING?
- Fuel Hole Cover
- Are '04s affected with the crankshaft position sensor recall?
- ?? Can anybody tell me what this part # is ??
- DIY'ers: Coolant top-off... which brand besides Nissan's?
- Need info on interior temperature sensor
- Anyone have updated complete ALignment specs for the 350Z??
- BBB LL arbitration -- HOW!?
- Broken Plastic Bumper Rivets
- Tire Feathering Arbitration hearing meeting....
- tire feathering facts
- "Tick" noise behind tach/speedo-any fix ever found?
- Anyone with 350Z ALIGHNMENT EXPERIENCE PLEASE HELP!! Still pulling 2 right......
