View Full Version : Maintenance & Repair
  1. Do you guys have any insight on this?
  2. Installing a pre-oiler?
  3. Z wont start and its not battery or starter
  4. Hard pedal until car warms up
  5. Another one of those A/C Issues
  6. ***Idle relearn ?????s ***
  7. 70k miles on 04, what to do?
  8. 350Z stock exhaust or Nismo Catback? HELP!!!
  9. Problems starting (P0345)
  10. Drivers side cam sensor
  11. my grille is messed up...
  12. Help with code P0340!!!
  13. Accident then i get a p1273 SEL light code
  14. Valve cover replacment, then mucho white smoke
  15. SES Light problem
  16. fuel pump wiring help
  17. 350z Clouded Headlights
  18. RPM drops to ZERO while car is running. now NO START
  19. Strange backfire
  20. Fuel pump wont run??
  21. SES light, code thrown P0462.
  22. car screeching at startup
  23. Window Motor Issue
  24. how do you test ecm terminals ?
  25. 03 350z timimg
  26. Bad Alternator?
  27. A/C not working
  28. Greddy Twin Turbo 04 350Z issues.
  29. Need Help with 04 350z convertible
  30. overheating replaced everything!!!
  31. P0031/P0037 Troubleshoot?
  32. Acceleration Noise? Tranny Problem? Video Attatched
  33. Throttle Problem Please Help!
  34. Idle and ECU reset problem
  35. Issue: Clutch/Cylinder Problem
  36. Check engine light issues
  37. Car turn on at cold start but dies at hot start
  38. Multiple codes pls help!!! Asap
  39. Belt tension pulley help!!! Please
  40. A/C Condenser Fan Intermittently Functioning
  41. Best Vendors for Oil/Fluids and Maint Parts
  42. New JWT install clutch pedal nightmare
  43. Headlights/tailights not working
  44. knock sensor code and just replaced
  45. blown headgasket?
  46. help my car takes time to start
  47. Car turns off after 1/4 mile run?
  48. Engine whine/buzz???
  49. Engine sputtering very badly
  50. HELP 07 cluch / shift problem
  51. Nismo Exhaust Flexpipe Scratch
  52. Battery Sparking big problem!!!!
  53. 08 clutch issue
  54. Oil leak
  55. Random Misfire. P0300
  56. need mechanical help...
  57. sticky throttle/ still revs when i put clutch in
  58. SEL On but No Codes
  59. HELP bucking, spitting, WTF
  60. Jerking when slowing down then going into 3rd
  61. No idle as soon as the car moves
  62. Need help identify the problem
  63. Did my AC line rupture?
  64. Water Pump $$$
  65. light chatter/rattle from engine
  66. 03 start up problems
  67. What would cause the RPM to dip below Idle
  68. Clicking noise in the rear on takeoff.
  69. Multiple cranks to start
  70. $4.5k Repair surely not, help needed
  71. SES,VDC off, Slip light on
  72. My 03 350z won't start randomly
  73. Suggestions for a new clutch and flywheel
  74. New Z I bought Has noise
  75. car battery dies if left for more than 16 hours
  76. Any sort of through maintenance at 45,000 miles
  77. Fresh clutch, pedal wont return
  78. HELP ASAP- Clutch pedal has no resistance
  79. Strange vibration felt in shifter..
  80. Starting Problems
  81. Window Lift Motor
  82. License Plate Lights
  83. Window Problem, cant shut driver door from inside
  84. Running too hot when going uphill and it's hot outside?
  85. ticking noise when comming to stop?
  86. Window rolls down when door shuts & alarm issue
  87. Vibrating Stick
  88. Strange ''BOV'' sound coming from engine?
  89. need some serious help
  90. Engine randomly stalls???
  91. Anybody familiar with what this'll cost me?
  92. Hard Startup HR
  93. when to replace stock battery
  94. Shifter problem
  95. Coolant On hood/radiator/front bumper
  96. Replacing my master/slave cylinder
  97. CDXXX to CD009 swap.. what parts stay/go?
  98. raggtop leaks
  99. What is this sound...?
  100. 03 glutch?trans?slave/master cyinder? not sure
