View Full Version : Maintenance & Repair
  1. Problems when traction control off?
  2. Feathering switched sides....
  3. What is in front of the Radiator?
  4. What brand of oil comes in our Z's?
  5. How many have had "NO" problems with their Z
  6. AT5 transmission slipping
  7. noise from the dash?
  8. Which synthetic is best?
  9. Anyone had Success with tire wear fix
  10. My Valve Stem Broke... Should this be a Warranty Item?
  11. Limited slip
  12. Have you replaced a clutch yet?
  13. Keep this post alive
  14. Vacuum Hoses "Upgrade" Question
  15. strange A/C function findings..
  16. Has anyone had their crank sensor replaced (recall)?
  17. Brake bias adjustment
  18. Trade-in Question
  19. 04 350z
  20. 03 Z Burning Oil
  21. Clicking noise, left rear on acceleration?
  22. rear window question
  23. Has anyone had their tires replaced by dealer for rumbling noises???
  24. Touring Leather Seats Cracking
  25. Need some help w/nail in tire
  26. Jeff @ Performance
  27. Clutch Gone!! NEED HELP!
  28. Wind noise at speed
  29. Crooked / Off-Center Steering Wheel after TSB
  30. Soft Windsheild
  31. Dip stick blues...
  32. Problems With Fuel Filler Nozzle
  33. Tire feathering came back
  34. Has anyone found a fix for the outside
  35. Delo 15W-40?
  36. Do not buy the black 350z Track from McDavid
  37. Weak Parking Brake?
  38. Shifter Shaking Problem?? Help needed...
  39. Need some advice -MAFS
  40. Slight shaking after getting alignment...
  41. 04 G35, Same Problems as 350Z?
  42. Perf shop trying to make me sign waiver after problem.
  43. Shifter now vibrates at 23 k miles (Help!)
  44. Dealer wants to "repair" transmission
  45. Anyone else having problems with 4th generation tranny swap?
  46. To buy z or to get pre-order money back
  47. Exterior air noise
  48. Why does my frame/suspension creak?
  49. Windows Problem after fix!
  50. One more feathering story
  51. curbed my bumper.. help plz
  52. Need Some Help...
  53. Help: What to do about negative camber?
  54. Squeeking --> Popping Noise on Clutch Question???
  55. new tire roar article in autoweek 12/08/03
  56. Correct toe-in settings for front and back?
  57. SES light on?
  58. Are all OEM tires on our Z's the same?
  59. Is the dealership screwing with me? (Camber on one wheel way off)??
  60. Speedo Problem?
  61. Nna???
  62. tire feathering victims, LOOK HERE!!!
  63. Windows down
  64. Nissan Engineers inspected my car's tires......
  65. Your Front Caster and Camber specs please
  66. Grind/Rattle Echoing sound when Heat on
  67. High pitched noise from TPS ?!?!?!?
  68. Oil Filter on New Z
  69. tires leaning in
  70. After fixed grease streaks..
  71. jacks and Aftermarket Suspension
  72. Need help with ignition start.
  73. Got hit again!!! Please help!!!
  74. do you hear clicks from...
  75. G35c electronic service manual
  76. Limp mode?! Awsome!!!
  77. Tsb's
  78. A/C staying on
  79. Sleeping Tach
  80. Tire Feathering Database
  81. WIERD! car wouldn't rev about 2500 rpm
  82. Putting off TSB?
  83. Help! Can someone advise please
  84. Belt squeal at idle (car is stock)
  85. No Washer Fluid?
  86. free front tires
  87. Should I still be patient?
  88. Autoweek article on tire problem
  89. Dealerships in AZ for Service?
  90. trans leak second time
  91. Need some help.. Getting a lil worried..
  92. belt squeal question??
  93. Tire Feathering on Track Model
  94. People with 15K Mi Plus, POST
  95. How to fix stiff 5th & 6th. Yeah
  96. trans replaced, wouldn't shift right after, instructions to adjust
  97. How is 4th generation tranny?
  98. where to get 0W-40
  99. Rough Gear Changes?!
  100. My Dealer in GA changed my feathered tires with no fuss
