View Full Version : Maintenance & Repair
  1. HELP!!! Window problem... Not the common problem
  2. Dyno tune or Reflashed ECU
  3. cigarette lighter/ accessory plug not working
  4. how do I reclibrate the drivers window motor?
  5. plz Help! Loud screeching coming from engine
  6. overheating?!
  7. No air coming through vents =( Hot in here!
  8. Aftermarket 02 Sensors on 07'?
  9. CRC Mass Air Flow Sensor Cleaner
  10. Help!!! Rough Idle
  11. Shift plate bulb replacement?
  12. Horn
  13. Blinking Air Bag Light Question.. Please help!
  14. Convertable/Passanger window problem
  15. Link to Nissan / Infiniti Parts Catalog
  16. My Rear View Mirror broke (best way to repair it)
  17. Overheating Issue
  18. Switching to full synthetic at 95k miles? Good or bad?
  19. Stealership at it again???
  20. Cracking sound in rear suspension somewhere?
  21. Engine clatter @ startup only
  22. helping to diagnose over heating in my z....
  23. Transmission/Slave Cylinder issue???
  24. Hi, new here looking for help.
  25. Power Steering Fluid
  26. rough idle
  27. Abs, vdc/off, slip light is on! Code=c1142. Help please
  28. 2003 6 speed 350z will not shift correctly -PLZ HELP!
  29. Whining noice
  30. problem please reply quickly
  31. Clutch issue
  32. Weird 2nd Gear Issue
  33. Battery bolt
  34. Internet Diagnosing FTL..I know but come in.(Ticking)
  35. Help!! WINDOW MOTOR OR SWITCH????
  36. Replacing gaskets on my '03
  37. SES Light on! HELP
  38. Oil In Plenum/Black Cylinder Ports
  39. Ignored my Z and now I'm getting bitten...hard
  40. CEL Flashing! Please help!
  41. overheating only on the interstate
  42. Auto trans issue
  43. 06 still has axle click?
  44. Window
  45. Metallic clutch and light F/W "squeaking" on downshift
  46. weird overheating issue!
  47. Opinions on engine noise?
  48. Suspension knock
  49. Door won't open!!!- driver side
  50. Tail light Fuse keeps blowing
  51. blew up DE engine, need a new one so post away ppl!!
  52. Front Windshield Wiper Fluid Problem
  53. BCM not seeing ECM.... Heeeelpppp!
  54. Put hfc ons and got p0056
  55. HELP!!! Need some advice.
  56. Hey guys, not new to the z, but i got sort of a problem
  57. Warranty Question
  58. Window Problem (NOT MOTOR) help!!!
  59. Wheel alignment toe-in check
  60. Help with Brake Problem
  61. Brake, VDC off and slip light on
  62. Dead battery?
  63. Yes...Another rear strut metal on metal clicking noise
  64. Crankshaft Position Sensor issue after new clutch/fw
  65. Need A New Clutch
  66. I need some help regarding my passenger window
  67. Auto tranny help reverse hard shift and other problems
  68. New Z, Clean Carfax, Signs of Previous Accident?
  69. 350z Bog and Hesitation 3rd Gear
  70. P0345 sensor A?
  71. trunk problem
  72. no start...help!
  73. 2008 350Z Automatic stalling. Revs drop to 0. 2008 350Z
  74. Need help. Slight knock
  75. 2003 problems
  76. Clutch wont disengage
  77. Engine idling lower than normal/ticking from front...
  78. Window motor or switch?
  79. Window motor/ regulator out??
  80. Failed a smog test
  81. weird sound when step on accelerator and white smoke
  82. Major issue! Need help!
  83. Water Pump Question
  84. Hard to start, but runs great
  85. Low Oil Damage?
  86. Whats up with my horn?
  87. Attn: San Diego Z people
  88. AC/HEATER problem-No temp. control
  89. How To? Replace Oil Pressure Sending Unit
  90. Grinding 3rd Gear
  91. Blown Fuse HELP!
  92. Rear Defrost Switch/Button
  93. Where to buy radiator drain valve
  94. door wont open from inside or out
  95. 75k maintainance -HELP please thanks.
  96. 04 nissan 350z has a problem no clue what it is
  97. I Think i Killed my ECU ! :( HELP :(
  98. OEM flywheel Chatter louder than usual
  99. Question: In need of assistance.
  100. Help! Z Wont turn on with a turn of Key???
