Nitrous Basics Thread, read here if you want nitrous for the first time....
#101
Retired Admin
Originally Posted by b-ron
the shop that will be installing my kit want 10 hours worth of labor is that about right
#102
on
im getting the dyno tune kit. it comes with>10lb bottle with high flow valve
>4AN stainless bottle nut & Teflon washer
>Stainless quick connect Bottle brackets and hardware
>16 foot braided stainless feed line, blue fittings
>High Flow Nitrous and Fuel solenoids
>Solenoid mounting bracket
>2 foot Braided stainless Nitrous and Fuel feed lines, red and blue fittings
>Braided stainless line for Fuel rail test port installation, red fitting
>Jets for 50, 75 and 100HP
>2 High flow Wet Nozzles
>Wet Nozzle Mounting adaptors so the Nozzles does not blow out during injection, makes mounting the nozzle in plastic or rubber a snap!
>Lighted arming switch, relay, wire and wire harness, fuse, crimp terminals etc..
we were just talking about installing the kit so im not sure if he means any safty parts
what else should i add to this like the must haves in your OP thanks
#103
Retired Admin
All you have right there is the basic kit, which does NOT take 10 hours to install. You may want to think about getting a window switch/throttle position sensor, bottle heater, purge, electronic opener, digital gauges, etc etc.
It seems as if you don't know too much about nitrous at the moment. If I were you, I'd hold off on even buying the nitrous kit until you know well enough how everything works and what you think would be necessary to run nitrous safely on your car. Again, don't install anything or even buy anything. Just study up on it first over and over again, until you can recite it.
#104
on
i understand nitrous what it does and how it works, i installed a kit on a focus that i had and had no safty stuff like air to fuel ratio gauge full cut off ect... i just used A WOT switch. i just wasnt sure if i should go with electronic TPS switch or a windo switch as in is one safer then the other ? as far as doing rolls in 2nd gear ect.... i already new i was going to get the fuel cut off switch, purge and heater, i didnt really think about getting the bottle opener. i should have been more clear on what i ment about getting safty goodies thats not really needed but would be nice to have.
#105
Retired Admin
I just assumed, since you just named off what comes in a regular kit, that you didn't know too much about nitrous. My bad.
Get a combo of TPS and a window switch, like the MDS or the Dynotune one, instead of a WOT switch.
#106
on
#108
on
so im ordering my dynotune kit monday and the items listed below is the extras. yes i will be getting a bottle heater and bottle opener.
Air/Fuel Ratio Lean Shut-Down Switch
* 12V RED LED REMOTE INDICATOR
Electronic Nitrous Activation switch (TPS)
Nitrous Oxide Purge system Kit
Round 2-1/16" Nitrous Switch Center
fuel pressure gauge
any other things i should really look into befor monday thanks
fuel pressure gauge
#110
on
Originally Posted by GolfinZ
fuel rail adapter
nitrous pressure guage
im going to add the nitrous pressure guage today thanks
#112
on
Originally Posted by never gone
Is this the dyno tune tps/window switch thats mentioned in this thread?
DynoTune Two Stage RPM Window Switch / TPS (711)
#114
on
i have a question ,, my cars has a jwt intake ,, greddy evo2 exhaust ,, nismo headers ,, how much could the shot be ? ( i want to be on a very very safe side ,, without putting a big load on my engine )
#115
on
i just got a NX wet kit and had a couple of questions...
1) I was wondering if anyone has used a mix of gas/toluene or race gas to increase the octane and ran a bigger (say, 125 or 150 shot) rather than pulling timing? since the main risk without retarding timing is detonation, i would think that 98-100 octane would reduce the chance of that
2) I have heard that the VQ has a tendency to lean out at WOT with only breathing mods, so would a small step up in injector size help with that? i can live with it running a little rich and losing a few hp. better safe than sorry.
3) Am i nuts to think i can take a 150shot just by mixing 20-25% toluene in the fuel to make 97-99ish octane and only using the spray when that is in the tank? without pulling timing?
#116
Retired Admin
I don't know anybody or at least haven't heard of anybody using a mix of toluene (or xylene, or methanol, or alcohol, or other "octane boosters" for that matter). I wouldn't want to experiment before fully knowing its effects and its results on the dyno first, though.
You don't need aftermarket injectors. Just adjust your pill size to a smaller one until you can get a tune.
I also wouldn't go all the way up to a 150 shot even if I c16 in my tank. That's just asking for trouble. Stick with a 100 shot, even if you have a 100 octane gas, until you can get a tune to SAFELY spray above 100 shot.
#118
Retired Admin
Originally Posted by wade750
Need help..
Im planning to installed 2 botols of 10Lbs, what sort of line or connecter do i need. i thinking ot get the NX kit..
You would probably want two bottle openers that will open simultaneously (not hard, if you make them be controlled by one switch). Maybe you'd want two pressure gauges, but I think one would be fine. Other than that, it should be the same.
