Nitrous Basics Thread, read here if you want nitrous for the first time....
#162
I recommend anyone working on their own install to check out these videos from cold fusion nitrous. They are helpful and informative:
http://www.coldfusionnitrous.com/dvd/video.htm
#164
Here is a torque calculator based on hp and rpms. I am not sure how well it jives since I don't know the actual equation to it, others have posted it before, just can't find it.
as per site:
This calculator will output the amount of torque from
inputing the horsepower made at a certain RPM.
http://www.dragtimes.com/horsepower-...conversion.php
Ex: Adding an extra 100hp at 3000rpm will produce 175.07 lb-ft torque.
So when you guys plan out your jets, shots, and activation rpm, this would be helpful to know how much extra tq the vehicle will experience.
as per site:
#165
So I searched the nitrous forums from the start and collected a bunch of links with nitrous installs since a lot of people ask about them. These threads have the pictures working still as of - 22 Aug 09. Check them out and see what kind of ideas you get from them for your installs.
Cyber350z - Cyberz350's Nitrous Install Thread (ongoing)
https://my350z.com/forum/nitrous-oxi...d-ongoing.html
Fluidz - Fluidz NOS Pictures
https://my350z.com/forum/nitrous-oxi...-pictures.html
Rico3682 - Rico3682 Nitrous Pics
https://my350z.com/forum/nitrous-oxi...rous-pics.html
kim - How About This
https://my350z.com/forum/nitrous-oxi...bout-this.html
BobbyRitz - Pics after current mods...wheels, nitrous and lip
https://my350z.com/forum/mid-atlanti...ml#post2404002
Old School - Install complete!
https://my350z.com/forum/nitrous-oxi...-complete.html
bldrz - Direct port nitrous system installed with pics
https://my350z.com/forum/nitrous-oxi...with-pics.html
one350zfan - Nitrous install pics!
https://my350z.com/forum/nitrous-oxi...tall-pics.html
GamblerZ - Bottle install pics
Chaser720 - New Nitrous Set Up
https://my350z.com/forum/nitrous-oxi...us-set-up.html
snaponbrian - new Zex install pics
chefrey - nitrous install pics
garym - Finally took pics of my stealth nitrous system
https://my350z.com/forum/nitrous-oxi...us-system.html
coachk - A few pics of my N20 setup
https://my350z.com/forum/nitrous-oxi...n20-setup.html
genegoesfast - Switch Panel/Map Switch Added Install Pics
genegoesfast - Freshly Painted Bottle...No Tools Bottle Removal
https://my350z.com/forum/nitrous-oxi...e-removal.html
genegoesfast - Pics of Nitrous Mount Not Stealth
https://my350z.com/forum/nitrous-oxi...t-stealth.html
BakaN20 - Yet ANOTHER stealth Nitrous Install N0 56k
https://my350z.com/forum/nitrous-oxi...ll-n0-56k.html
powermark - VQ35HR 2007 350z Zex Nitrous Kit Install Started
https://my350z.com/forum/nitrous-oxi...l-started.html
misterniceguy - New Zex nitrous install w/pics
https://my350z.com/forum/nitrous-oxi...ll-w-pics.html
doc10374 - Pics of my NX install
https://my350z.com/forum/nitrous-oxi...x-install.html
Aced16 - Add me to the list!
https://my350z.com/forum/nitrous-oxi...-the-list.html
blaster9 - 07 HR nitrous installed!!
https://my350z.com/forum/nitrous-oxi...installed.html
ChrisNelson - My Nitrous Install
https://my350z.com/forum/nitrous-oxi...s-install.html
wizard - Wizard of Nos Install...
VS 350Z - My ZEX Nitrous Set Up
3hree5ive0ero - I guess I'll come out and play too..
https://my350z.com/forum/nitrous-oxi...-play-too.html
philsill350z - hears my nos pics
https://my350z.com/forum/nitrous-oxi...-nos-pics.html
Nitrous installed w/lines inside cabin. I personally would not do this, but it has good pictures to be used as reference
http://webpages.eng.wayne.edu/~al042...itrouspics.htm
Skwiz
http://www.skwiz0d.com/pictures/dyno/
A couple large pics that you can download
Skwiz
#166
on
how would I connect the utec to the nitrous solenoids. I have read the part in the manual where it shows the pins for the spare solenoid control. It says to connect pin #7 to the solenoid or control unit..that part I understand..but what I dont understand is that they want me to connect a 12v power source to the solenoid as well...doing that it would keep the nitrous solenoids always on which is not good. The only sense i can make of it is if you are using a meth injection kit or a solenoid that requires a power,ground,and a signal wire to operate.
Do I just ignore the the 12v power source and just connect the red wire/pin # 7 to the solenoids?
Any help will be greatly appreciated.
-Ryan-
-Ryan-
#173
Retired Admin
I personally wouldn't spray on a road course (definitely not on street tires due to lack of traction). Other than the fact that you should only spray at WOT, your torque will increase significantly and instantly which means you're adding that much more stress that fast to various components on top of existing stress levels for racing on a course.
There are lots of automatic heaters that will keep the bottle pressure constant. You can also get a NANO kit that will keep your bottle pressure constant until you empty the bottle content.
#174
There are lots of ways around that. 10lb bottle is just a standard size and you can always get multiple tanks and/or just get a bigger one.
#175
Retired Admin
I was just using the standard measure.......regardless, it's clear from his wording in the question that he hasn't thought it through beyond setting it up on his xbox 360. Where there is a will....there is a way, but lets be real....nitrous is not best suited in road race apps. Can it be done...sure, but why?
I agree.. why?
#178
Retired Admin
^ Depends on your driving style, whether or not you'll be drag racing (e.g., launching), the condition of your clutch, how often you'll be spraying, etc.
Stay with the stock for now and if you need to upgrade, you'll find out. That's the best answer I can give you, as there is no universal answer that applies to everyone.
#180
Guys I have a question,
I'm thinking about selling the TT kit in my car and keeping the built 1:8.6 CR short block and spraying nitrous oxide (I know the car without the nitrous oxide will be slow as a turtle <BTW I like turtles >) but I know I will have a hard time selling the short block where I live.
So, what do you think the short block can handle? 150shot? less or more?
Thanks.
Thanks.
