Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Nitrous Oxide
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 04-01-2009, 09:13 PM   #1
jomamahama
Points: 1,059, Level: 17
Points: 1,059, Level: 17 Points: 1,059, Level: 17 Points: 1,059, Level: 17
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Default dealerships and nitrous
I own a 2006 G35 5AT with 10K miles with no performance mods. So it's a VQ35DE, not the HR. Since i know the 350z forums have more knowledge regarding nitrous, i've decided to post here.
I've read the beginner's thread several times and a lot of other nitrous threads on the forums. I'm a big planner so i haven't done any mods until i know exactly where i'll end up. My proposed mods and use for nitrous will probably be another thread so this one doesn't go off track.
So i'm still under powertrain warranty and was wondering what dealerships look for as far as denying warranty claims due to nitrous. Are there ways to install it, and then if I have engine or tranny problems that may or may not be related to spraying, is there a way to uninstall with no evidence remaining? Once they look at the engine or computer could they tell? I guess the first challenge would be explaining the mounting holes in the trunk (or is there a way to mount less invasively?). I figured maybe i could explain it by saying i had to mount something else, such as a cabinet for a gun (i am in texas FYI). Then i'd have to go back with the stock intake which wouldn't have a hole for the spray, and conceal where i ran the switch through to the cabin (would the nav cubby be good?) It may be dishonest, but since powertrains can fail without nitrous, and mine very well may fail due to a non-nitrous problem, they would automatically blame nitrous use regardless and deny my claim.
Any suggestions or is this feasible? Thank you!
jomamahama is offline   Reply With Quote
Old 04-02-2009, 12:15 AM   #2
*Boose*
*Boose*'s Avatar
Points: 2,102, Level: 27
Points: 2,102, Level: 27 Points: 2,102, Level: 27 Points: 2,102, Level: 27
Today's Activity: 0.8%
Today's Activity: 0.8% Today's Activity: 0.8% Today's Activity: 0.8%
I'm sure during the teardown they would do an inspection of your engine. So there would probably be a trace of color left from the nitrous. Ever seen the cylinder walls of a sprayed motor? Alot of discoloration. That would be my only suggestion as to how they may find out the motor used nitrous. Also they wouldn't need to go into the trunk so if they did keep some extra luggage around when you go.
__________________
E46 M3
*Boose* is offline   Reply With Quote
Old 04-02-2009, 04:13 AM   #3
FALLEN1z
FALLEN1z's Avatar
ya they can swab it or just look at it. and nissan is so stingy with its warranties they'll pin anything they can on any mod they can. they tried to deny me a MAF sensor because i had an aftermarket catback..... explain to me how that has anything to do with anything
__________________
2003 performance 350z:APS test pipes: Intense Power Y-pipe: STILLEN torque dampener: Aerosync N style front bumper: ROTA torque R rims: Smoked reverse lights: tint: NISMOlightened flywheel: NISMOclutch: Hotchkis swaybars: JWT popcharger: toyo t1r's: Powerslot rotors: Hawk HPS pads: MP racing grounding kit: Powerlab 3/8 plenum spacer: zex nitrous:
FALLEN1z is offline   Reply With Quote
Old 05-22-2009, 10:39 PM   #4
ARMSTRONGARMS
ARMSTRONGARMS's Avatar
Points: 5,543, Level: 47
Points: 5,543, Level: 47 Points: 5,543, Level: 47 Points: 5,543, Level: 47
Today's Activity: 0.7%
Today's Activity: 0.7% Today's Activity: 0.7% Today's Activity: 0.7%
Nice first post
ARMSTRONGARMS is offline   Reply With Quote
Old 05-22-2009, 10:49 PM   #5
bigdv519
I also plan on doing the same. I'm going to build an intake pipe to plumb the nozzle, but I'm going to keep my stock intake just incase. How much do you plan on spraying?
bigdv519 is offline   Reply With Quote
Old 05-22-2009, 10:52 PM   #6
2004Black350z
Exhaust Whore
2004Black350z's Avatar
Points: 4,347, Level: 41
Points: 4,347, Level: 41 Points: 4,347, Level: 41 Points: 4,347, Level: 41
Today's Activity: 28.1%
Today's Activity: 28.1% Today's Activity: 28.1% Today's Activity: 28.1%
__________________
Tuned by CIN Motorsports
2004Black350z is online now   Reply With Quote
Old 05-22-2009, 11:54 PM   #7
3hree5ive0ero
`•.,¸,.•*¯`•.,¸,.*~[;::;‹]ᵒᴥᵒ)›
3hree5ive0ero's Avatar
Points: 23,100, Level: 93
Points: 23,100, Level: 93 Points: 23,100, Level: 93 Points: 23,100, Level: 93
Today's Activity: 38.0%
Today's Activity: 38.0% Today's Activity: 38.0% Today's Activity: 38.0%
If they ever tear down your engine, then they can definitely tell that you've been spraying by looking at the cylinder walls.
Nitrous installs are rather simple (relative and subjective), so you can always uninstall everything and install everything when the time comes. As far as the mounting holes for the bottle, they wouldn't know what that was for. You can also get a wooden board and mount the bottle onto that also, placing the board some place where it wouldn't be affected by turns or acceleration. And if you're worried about the hole in your intake, you can always get a Z-tube (supposedly better than the G's tube, too) and drill a hole there while saving your stock tube. Everything else should be done in a similar fashion (using something that's easily replaceable or uninstalled).
__________________
3hree5ive0ero is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
5at, g35, nitrous
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
