Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Nitrous Oxide
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 04-13-2009, 08:43 PM   #1
GrayG35
Default NGK copper 1 step colder???
does anyone know the part number to the NGK 1step colder copper spark plugs? Ive been searching but havent found the part number yet. thanks!
__________________
13.38 @ 105mph on street tires all boltons 5at
GrayG35 is offline   Reply With Quote
Old 04-13-2009, 09:27 PM   #2
JuJube
Points: 2,297, Level: 28
Points: 2,297, Level: 28 Points: 2,297, Level: 28 Points: 2,297, Level: 28
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Lfr6a-11
__________________
Greddy Twins, 400 RWHP, Haltech - My Lame Blog
JuJube is offline   Reply With Quote
Old 04-13-2009, 09:44 PM   #3
GrayG35
do you know of a link to a site that sells them at a good price?
__________________
Old 04-13-2009, 10:00 PM   #4
GrayG35
nevermind. found it thanks for the help!
__________________
Old 04-14-2009, 09:22 AM   #5
frankie945
frankie945's Avatar
Napa carries them. And all boat shops should have them in stock. They run them in some outboard motors.
frankie945 is offline   Reply With Quote
Old 04-27-2009, 08:37 PM   #6
GrayG35
what should the gap be on these plugs while running a 75-100shot?
__________________
Old 04-28-2009, 02:53 AM   #7
3hree5ive0ero
`•.,¸,.•*¯`•.,¸,.*~[;::;‹]ᵒᴥᵒ)›
3hree5ive0ero's Avatar
Points: 23,100, Level: 93
Points: 23,100, Level: 93 Points: 23,100, Level: 93 Points: 23,100, Level: 93
Today's Activity: 38.0%
Today's Activity: 38.0% Today's Activity: 38.0% Today's Activity: 38.0%
Do a search. You'll find lots of different answers, most of which are valid for various reasons. But first, let me give you a hint: find out what the part number actually means.
BTW, before you post, try searching. I'm beginning to see a trend in your postings. Also, nobody goes by "corrected times" - that's bench racing.
__________________
3hree5ive0ero is offline   Reply With Quote
Old 04-28-2009, 10:22 PM   #8
GrayG35
i just corrected them because every track is different, its like a mediator. just like the san antonio track is slower than the dallas track... lfr6a-11 heat range is 6 meaning that it is one step colder than the stock range of 5. btw i have to update those numbers thanks for reminding me...
__________________
Old 04-28-2009, 10:25 PM   #9
3hree5ive0ero
Quote:
Still, nobody goes by "corrected" numbers ever. BTW, I didn't know the SA track was slower. I know they're closer to sea level than ours, though. The one at Ennis isn't a fast track, neither. If you've ever been there, you'd know. The one at Baytown is the fastest drag strip in TX so far.
As for your interpretation of the spark plug part number, you're only partially correct. Find out what -11 is for and you'll find your answer. Also, I may be wrong, but the stickied thread should also contain some information about spark plug gaps, I believe.
__________________
Old 04-28-2009, 10:31 PM   #10
GrayG35
i didnt find anything in that thread... hows .035 - .038 gap sound?
__________________
Old 04-28-2009, 10:55 PM   #11
3hree5ive0ero
That sounds good. Was searching for yourself so hard?
Interestingly, your question caused me to look up some stuff on spark plug gaps.
I don't recall ever reading this bit of information, so I'll post it in the stickied thread.
__________________
Old 05-13-2009, 12:39 PM   #12
homeboynyc
homeboynyc's Avatar
Points: 1,487, Level: 21
Points: 1,487, Level: 21 Points: 1,487, Level: 21 Points: 1,487, Level: 21
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
good info.
__________________
[size="1"]Aps twin turbo
homeboynyc is offline   Reply With Quote
Old 05-13-2009, 03:41 PM   #13
blackz7887
blackz7887's Avatar
the -11 means the gap is at .044" from the factory. if you search on here tho most people running nitrous tend to go between .035 and .038 as he said so your point doesn't really make sense in this case.
blackz7887 is offline   Reply With Quote
Old 05-13-2009, 08:02 PM   #14
3hree5ive0ero
Quote:
Fail.
I know what -11 means. You can technically use the stock gap without problems. However, with bigger shots, it's generally recommended that you reduce the gap. Again, with bigger shots, it's just recommended that you reduce gap (for safety reasons).
And I've been on here long enough, so no need to tell me to search. Maybe you should try reading and understanding what's actually going on and why I chose to post that way. BTW, if you searched on here, you'd see that I help people with nitrous more than anybody else. The reason for that post was that the STICKIED thread had the info he was looking for, yet he chose to ignore it and make his own thread. I don't spoonfeed people answers.
__________________
Old 05-14-2009, 02:58 PM   #15
blackz7887
blackz7887's Avatar
Fail.
http://www.spark-plugs.co.uk/pages/t...ymbol_code.htm fail huh?? that shows pretty clearly what -11 means. and its pretty commonly accepted that you should reduce the gap at ~100 shot which is right around where he was asking. I wasn't trying to start an argument, just pointing out that knowing what the -11 means in this case doesn't really help him
Old 05-14-2009, 08:23 PM   #16
3hree5ive0ero
You telling me to search was fail. I literally know what is posted and what isn't in the nitrous forum, trust me. Again, maybe if you took the time to search, then you'd see that I (along with a lot of other members) already posted what gaps they're using and I even posted why the gap should be reduced. Had he searched from the get go, then none of my posts telling him to search would exist. In addition, once he found that info, then I would have posted a recommendation post telling him to reduce the gap.
__________________
My350Z
350 Z
Paid Advertisement
Tags
350z, allroad, colder, copper, gap, lfr6a11, napa, ngk, nissan, number, parts, plug, plugs, spark, step
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
