Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Nitrous Oxide
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 04-18-2009, 06:00 PM   #1
ronie
ronie's Avatar
Default am i crazy?
so i bought the dynotune vq35hr kit and will be using nx lightning series solenoids and nx shark nozzles...im also getting the trick peformace progressive guage to monitor my fuel pressure and to control my nitrous... i plan to shoot a 200hp shot ramped from 3,000 rpm to 7,000 rpm starting my shot at 100hp and ending at 200hp around 6,200 thru 7,000 rpm.. only spraying 1st thru 4th gear...i will obviously get a tune, have decide on osiris tuned by jack cecil from hplogic in south florida...my car will have custom 2.5 inch header back exhaust no cats and currently have custom cai with k&n filters in stock intake box...will also get 1-2 step colder plugs but cant find the part# for the vq35hr copper plugs(ive heard copper is better with nitrous)...also fuel pressure safety switch and afr lean shutdown and wideband guage...so do you guys think its too big of a shot or will the hr handle it well...im only going to use this shot at the 1/4 mile track a couple times a month...i will have a tune for 150hp shot for the rest.. oh and plan to run race gas for extra security with both setups...any comments that will help me are very appreciated.
thanks in advance
RONIE
__________________
07 350z - base- gunmetal rota torque r -k&n...more coming soon!!!
ronie is offline   Reply With Quote
Old 04-18-2009, 07:31 PM   #2
madwi
In for vids
There a few threads around with the plug numbers.
heres one for you:
http://my350z.com/forum/nitrous-oxid...ally-know.html
Also anything over 150 you really should start thinking about going the direct port route. Its going to be your best bet for a 200 shot.
__________________
'08 350Z Touring Nogaro red
madwi is offline   Reply With Quote
Old 04-18-2009, 07:36 PM   #3
ronie
ronie's Avatar
hey, i found a thread with the plug number for the iridiums but not the coppers...im looking rite now and no luck...
__________________
Old 04-18-2009, 08:00 PM   #4
ronie
ronie's Avatar
thanks, found it...i now i will end up going direct port but i will wait till revshift or somebody prodoces an intake manifold for the hr's...it will be easier to install the direct prot on an aftermarket maniflod like the gtr r35 manifold...
__________________
Old 04-18-2009, 08:02 PM   #5
3hree5ive0ero
`•.,¸,.•*¯`•.,¸,.*~[;::;‹]ᵒᴥᵒ)›
3hree5ive0ero's Avatar
Points: 23,100, Level: 93
Points: 23,100, Level: 93 Points: 23,100, Level: 93 Points: 23,100, Level: 93
Today's Activity: 38.0%
Today's Activity: 38.0% Today's Activity: 38.0% Today's Activity: 38.0%
150 whp shot is possible on the DEs. 200 whp shot is a possibility on the HRs, but that's just my assumption as nobody as attempted yet. Maybe you can prove me right.
It seems like you're doing fine with the safety equipments and the precautionary measures you're taking. Keep in mind, however, that "ramping" is basically a on/off switch for the solenoids that is based on time. That means, it'll take its toll on the solenoids over time. Another possibility would be to have a 2 stage set up (can be controlled by 2-stage window switches).
With that all said, I'd recommend a direct port set up with such a huge shot as a single nozzle wet shot (1 on each side of the plenum) means that certain cylinder(s) won't get as much of the nitrous/fuel mixture than other(s). I assume that to be even more true with a progressive shot. I recommend either a direct port set up (progressive is ok) or a 2-stage set up (single nozzle wet shot for each side of plenum is ok).
__________________
3hree5ive0ero is offline   Reply With Quote
Old 04-18-2009, 08:08 PM   #6
ronie
ronie's Avatar
thanks for such quick replies guys...i though about the 2 stage setup but would rather a direct port setup for optimum n2o and fuel mixture...maybe i can go with a bigger shot with direct port...lol..skies the limit rite?
__________________
Old 05-01-2009, 08:22 AM   #7
JK_HRZ
JK_HRZ's Avatar
This thread just made me wet. Keep us all updated :-D
__________________
Parting out full bolt on HR Z. See Mod list in profile
JK_HRZ is offline   Reply With Quote
Old 05-01-2009, 03:22 PM   #8
ronie
ronie's Avatar
update... changed my mind on my set up,i will be going direct port...waiting for parts to come in...will keep updated as soon as install starts
__________________
Old 05-01-2009, 05:09 PM   #9
coachk
coachk's Avatar
Points: 3,733, Level: 38
Points: 3,733, Level: 38 Points: 3,733, Level: 38 Points: 3,733, Level: 38
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Where do you run the 1/4 mile at....would love to race you sometime after you get your N20 done.
coachk is offline   Reply With Quote
Old 05-01-2009, 07:08 PM   #10
ronie
ronie's Avatar
im using moroso in jupiter,fl...now called palmbeach international raceway...nice track...and traction is phenomenal...i hope to be up and running in about a month or two...im doing all the work myself so will only have the weekends to work on the car...
but no worries updates and pics will follow...im thinking it will be a mid 11 sec car maybe???
__________________
Old 05-01-2009, 08:32 PM   #11
3hree5ive0ero
Damn, direct port? Ballin'! Please keep us updated with the process. We don't see direct port set ups around here often.
__________________
Old 05-02-2009, 08:58 AM   #12
coachk
coachk's Avatar
It appears that you're going to have a 2 stage N20 system, is that correct? So you will launch on a 100shot and when will the other 100shot kick in?
Old 05-02-2009, 09:05 AM   #13
ronie
ronie's Avatar
i was thinking about a two stage set up but the space in the intake manifold isnt really convincing me so i will go with a single 200 shot proggresively controlled to shoot a 100shot at 3500 and ramp up to a 200 shot at about 5500 or 6000 rpms and cut off at 7200
__________________
Old 05-02-2009, 09:09 AM   #14
coachk
coachk's Avatar
Got it....keep me posted. A buddy of mine was spraying a 150 shot on his Z (DE) and was running low 11's at Bradenton
My350Z
350 Z
Paid Advertisement
Tags
g35, revshift
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
