You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Need some help finding tach signal for NX RPM Window Switch on VQ35HR
Hello, I am trying to install an NX kit on a 2007 G35 Sedan w/ VQ35HR. I have pretty much everything done except I can't quite figure out where to get the tach signal for the RPM Window Switch.
Does anyone have any insight? Any help would be greatly appreciated.
-Kim
What do the instructions say to tap into?
I wired up a NOS window switch and it asked for two injector wires to be tapped for tach signal, #1 and the next one in the firing order.
__________________
Old car: 06 Cobalt SS ..... New car: 08 Nismo, #1456
If you are looking at the engine bay on the passenger side locate the first coil pack, it sits above where you would install spark plugs. You’re going to use the #1 coil pack. (If you’re standing directly in front of your engine, it is the one on the passenger side closes to you) The wire you are looking for is going into the connector that plugs into the coil pack; the wire is yellow with a black line running down it. There are three wires going into the connector the one you need is YELLOW and BLACK. On my Zex window switch when the car is on I am able to read what RPMs I am idling at, if your window switch is the same, you know its hooked up correctly.
Good to know, thanks. Anywhere I can find a good wiring diagram for these engines without picking up a factory service manual?
__________________
This sounds right, but I thought it was yellow with red stripes. Either way, the above post is the best answer.
