Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Nitrous Oxide
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 08-02-2009, 11:13 PM   #1
azianmakaveli
Default ZEX shoots in spurts?
I have a 04 G35 6mt and my nitrous isnt working right. Ive been searching all over and cant seem to find the probem.
When I hit the activation switch, and go WOT(trigger) the nitrous shoots in spurts. I can feel when the nitrous hits and it goes on/off repeatedly.
I think its the voltage that my throttle body is sending. The nitrous management unit activates on a 5 volt signal, and since my car is a drive-by-wire, not cable, i hooked it up to a green wire on the throttle body which is the wire that the car ECU senses WOT. From what I heard, the VQ works a bit different than most conventional cars (http://my350z.com/forum/nitrous-oxid...s-trigger.html)
anyone have any ideas?
__________________
2004 G35 Coupe. with almost all the mods, not really.
azianmakaveli is offline   Reply With Quote
Old 08-03-2009, 04:05 AM   #2
duro78
Could the system be clogged? Recheck all wiring
duro78 is offline   Reply With Quote
Old 08-04-2009, 05:13 PM   #3
bottlefedZ
bottlefedz
Points: 1,061, Level: 17
Points: 1,061, Level: 17 Points: 1,061, Level: 17 Points: 1,061, Level: 17
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Are you using a bottle warmer?What was your bottle pressure at when nitrous was activated?
__________________
03 5AT *Enkei*Fujita*Kinetix*Greddy*Dynotune*Topspeed*XO2*Transgo*
bottlefedZ is offline   Reply With Quote
Old 08-07-2009, 10:44 PM   #4
garym
garym's Avatar
Points: 1,844, Level: 25
Points: 1,844, Level: 25 Points: 1,844, Level: 25 Points: 1,844, Level: 25
Send a message via Yahoo to garym
A couple of us are having a similar problem with the zex kit.
You did set WOT by hand right?
You might want to get a hold of ZEX and get the risistor wire that our cars should have between the control unit and the TPS, if you don't already have it.
Another thread with Zex issues.
http://my350z.com/forum/nitrous-oxid...ont-spray.html
__________________
2006 Touring with A/T - Altered Atmosphere Angled Plenum Spacer, UTEC w/prof tune, Short-ram intake, HiFlow Cats, ZEX 150hp shot with ALL the safety bells and whistles - On Bottle - 339whp / 372wtq. NA with UTEC tune - 248whp / 223wtq
garym is offline   Reply With Quote
Old 08-09-2009, 08:35 AM   #5
t6378tp1
Points: 970, Level: 16
Points: 970, Level: 16 Points: 970, Level: 16 Points: 970, Level: 16
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
I would start by rechecking your grounds and make sure your 12v source can handle the amp draw from the niods
if checks out fine, then I think it's your tps signal. Not sure what size shot your using but I had the same problem, I would go wot spray then it would cut off.
The problem was I had the zex box set to activate at 100% throttle and the system only gives you a 2% window. I was able to confirm that what was happening is that when I went wot I would hit 100% but the kick from the nitrous would push me back in my seat and the throttle would go down to 95% and deactivate the nitrous. The thing is in your mind it's pedal to the metal but not to the computer.
To fix the problem reset your system to spray at 95% throttle or 4.5-4.7volts and the problem should go away
t6378tp1 is online now   Reply With Quote
Old 09-05-2009, 10:59 PM   #6
coffen303
It could also be simply your tps tap was done poorly, not saying it was, but i had that exact problem awhile ago in a different car, and then it stopped all together, and went and checked, and sure enough i had just been in a rush at the end, and had to redo the whole tap. Ever since then it worked fine.
coffen303 is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
competition, spurts, trigger, wire, zex
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
