Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Nitrous Oxide
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 11-17-2009, 09:40 PM   #1
turbonetics 350
Default nitrous systems with turbo
has anyone had any success with installing nitrous kits with there turbos. not looking for a huge shot just 50-75 horse. stock engine on ten pounds of boost, has methanol injection but don't like it. the car has turbonetics kit so comes with reflashed ecu and injectors. some advice would be great thanks
turbonetics 350 is offline   Reply With Quote
Old 11-17-2009, 10:44 PM   #2
Italianjoe1
Italianjoe1
Points: 1,472, Level: 21
Points: 1,472, Level: 21 Points: 1,472, Level: 21 Points: 1,472, Level: 21
Today's Activity: 7.2%
Today's Activity: 7.2% Today's Activity: 7.2% Today's Activity: 7.2%
Why?
I've seen nitrous setups to help spool bigger turbos, but I doubt that's the case here.
Meth is mainly a safety feature when you are boosted/spraying, it raises working octane and cools the combustion chamber temps dramatically usually, along with adding more fuel and lowering IATs as well.
Nitrous works well to drop IAT's, but makes the car more prone to knock and greatly increases the cyl temps/pressures. Turn the boost up a little if you are just after more power. Safer that way.
__________________
Old car: 06 Cobalt SS ..... New car: 08 Nismo, #1456
Italianjoe1 is offline   Reply With Quote
Old 11-17-2009, 11:34 PM   #3
redman333
redman333's Avatar
Points: 2,989, Level: 33
Points: 2,989, Level: 33 Points: 2,989, Level: 33 Points: 2,989, Level: 33
Today's Activity: 1.9%
Today's Activity: 1.9% Today's Activity: 1.9% Today's Activity: 1.9%
Send a message via AIM to redman333 Send a message via MSN to redman333 Send a message via Yahoo to redman333
How much power are you running now. If you still have the stock block your probably pretty close to the limit. I wouldn't run nitrous.
__________________
http://www.myspace.com/redman84
TN ST, 550cc injectors, aam return fuel system, apexi n1 exhaust, Blitz ebc, defi boost, egt, oil psi guages, defi controller, utec EM, apexi turbo timer. 365whp - 360 wtq. /
Pioneer Avic-z1, 2 10" Apline Type R subs, MTX 7800 amp..
redman333 is offline   Reply With Quote
Old 11-22-2009, 01:00 PM   #4
turbonetics 350
i am about ten pounds of boost. on a single turbo. was wondering if turned the boost up a couple of pounds would that hurt a little more
Old 11-23-2009, 05:11 PM   #5
rrmedicx
rrmedicx's Avatar
Points: 4,953, Level: 45
Points: 4,953, Level: 45 Points: 4,953, Level: 45 Points: 4,953, Level: 45
Today's Activity: 1.2%
Today's Activity: 1.2% Today's Activity: 1.2% Today's Activity: 1.2%
Send a message via Yahoo to rrmedicx
If you choose to run meth you would actually need less fuel because you would be burning the alcohol in addition to pump fuel raising the octane thus making it safer to push for higher boost numbers.
However, I would not push a stock block beyond 10 psi IMHO. You would be building a time bomb if you do, but good luck.
__________________
Z is Finally Gone...in pieces.
rrmedicx is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
350z, nitrous, spoolturbo, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
