Nitrous Oxide Too soon, jr.
Stalling on startup after nitrous run
Old 11-10-2015, 06:15 AM
kiyanismoz
kiyanismoz's Avatar
Default Stalling on startup after nitrous run
I've searched all of google and on here for a similar issue. I found one thread with the same exact issue but his resolution is not my problem.
I have an 03 350z with an NX EFI Proton plus kit @ 35 shot for testing. The bottle was at 860psi while testing the system. I know the recommended is 900-1000psi but I just wanted to make sure the system is working. After doing a few pulls on the road, I park the car to go eat. When I come back out to start the car, it revs up like normal then the rpms drop and the engine stalls. It only does it after a nitrous run.
I had a similar issue when I first bought the car. Cleaned the throttle body and it was fine, until I started using nitrous. Any ideas fellow z sprayers?
EDIT: Some more information. It is currently not tuned for the nitrous. I have a tune scheduled in a couple of weeks for a 100 shot. This is just a testing phase.
Old 11-10-2015, 10:31 AM
Conway_160
Conway_160's Avatar
Do you spray before or after your MAF?
Old 11-10-2015, 05:43 PM
PP08HR
PP08HR's Avatar
You're freaking your ecu out. Keep it at idle for bit and ecu should relearn.
Old 11-11-2015, 06:13 AM
kiyanismoz
kiyanismoz's Avatar
I spray after the MAF. Approx 2-3 in. from throttle body to minimize puddling.
Old 11-11-2015, 06:17 AM
kiyanismoz
kiyanismoz's Avatar
I had the same theory. I haven't gotten it tuned yet. I just have the tune for my bolt ons set. Think once I get it tuned, the issue will go away? I just dont want it to be something like a fuel issue.
Old 11-11-2015, 03:30 PM
vertico
vertico's Avatar
Curious, how long (minutes) was it between the time you sprayed and the time you shut off the car when parked?
Old 11-11-2015, 07:24 PM
kiyanismoz
kiyanismoz's Avatar
Around 5-7 minutes from the nitrous run to parking. Then another 30 min eating and starting the car.
Old 11-12-2015, 07:13 AM
Italianjoe1
Italianjoe1's Avatar
Sounds like the solenoid isn't sealing perfectly and the car is getting some fuel vapor in the manifold when sitting. Check to see if there's any leakage at the nozzle after using the system.
Old 01-21-2016, 08:59 AM
kiyanismoz
kiyanismoz's Avatar
I'm not sure what it was but it only happened on my 30 shot. I bumped up to a 50 shot and it no longer does it.
Old 01-23-2016, 06:20 PM
Italianjoe1
There's no way the jetting change should have affected it, but it shouldn't have done it anyway. With the shot on my nismo there were never any effects on startup or after a run.
Glad it's working well for you though, enjoy the extra power, it really makes the car fun.
dkmura
11-21-2015 07:51 AM
_Graham
11-13-2015 06:52 PM
pettyboy69
11-13-2015 04:19 AM
joeb1983
11-03-2015 01:52 PM
Quick Reply: Stalling on startup after nitrous run
