350z on jack stands...
Old 08-25-2009, 10:15 PM
350Z friend
350Z friend's Avatar
Default 350z on jack stands...
Hi guys, what is the best way to get the Z up on four jackstands?
Old 08-26-2009, 01:05 AM
Project DSR
Project DSR's Avatar
Here is your freebie
https://my350z.com/forum/maintenance...ck-points.html
no other freebies will be given out beyond this point
Old 08-26-2009, 06:10 AM
Cali-Darkness
Cali-Darkness's Avatar
I just printed a copy of Vo's jack points. I need a good low racing jack & stands now.
Old 08-26-2009, 10:13 AM
Project DSR
that front one still isnt clear to me though, ill find it one day haha.
Old 08-26-2009, 11:06 AM
scotts300
scotts300's Avatar
I bought my aluminum low racing jack from Costco. I think it was $90, and it slides right under the exhaust to get to the diff.
golf (08-19-2016)
Old 08-26-2009, 11:23 AM
Cali-Darkness
Thanks Scott, I will check them out this weekend. I keep having to drive onto two yellow pages phone books to get the old jack under my Z.
Old 08-11-2014, 08:34 AM
l2iceman
l2iceman's Avatar
Bringing this back. For the rear, I use the rear diff and then put the jack stands on the jack points.
For the front, however my jack isn't low enough (now that I've lowered the car a bit) to slide it in the front, so I have to use the side jack points to lift. Since I'm lifting at the side jack point, I can't use that same point for the jack stand (obviously, my jack is in the way as it's lifting), so I looked up many pictures on where to place jack stands and attached some pics.
For the front, should I put the jack stand where the red circle is? like right there where the bolt goes through, or should I place the stand somewhere along the black frame? Ignore the green circles lol
For the rear, similarly, am I better off using any of the circled points for jack stands vs the pinch point? I saw the other thread where someone posted using the spring bucket (green circle), but I read on some threads elsewhere to avoid lifting suspension areas...so I would think the red or black circle would be better.
thanks in advance!
Front:
Rear:
Old 08-11-2014, 10:11 AM
AdvanZ33
Senior Super Moderator
AdvanZ33's Avatar
Is that your car? Do you realize your camber arm is severely bent?
Old 08-11-2014, 10:17 AM
l2iceman
l2iceman's Avatar
THAT explains why I need to keep replacing that one single tire...and when I go over bumps on the highway at 200kph it bounces all weird!!
haha J/K.. It isn't my car, I found the pics online and just added the coloured circles lol
For the rear, I currently just use the rear diff to lift and place jack stands on the rear jack points, but wanted to know if one of the circled spots was a better choice.
For the front, I don't know where exactly to place the jack stands aside from the jack point(but as mentioned above, this spot is where I lift with my jack, so I need another spot to place the stand on each side as I lift).
Old 08-12-2014, 06:44 AM
l2iceman
l2iceman's Avatar
so I did my brakes yesterday, and for the fronts I used the joint there circled in red in the first pic above, but I was a little nervous so I still left the jack on the side with some pressure (I did one side at a time rather than jacking up both front sides). For future reference, can anyone confirm that this spot would be good for jack stands? In case I need to get the entire car up on four jack stands.
For the rear, I just lifted by the diff and put the two jack stands at the pinch point and was fine...I'm just not sure for the front.
liqalu04
01-02-2022 12:58 PM
Dsowe
02-17-2021 10:38 AM
issyz
07-02-2017 03:04 PM
nanotech
10-02-2015 05:02 AM
samansharif
09-25-2015 12:31 PM
Quick Reply: 350z on jack stands...
