Hawaii Introduction Thread
on
if any mods come in here could you please sticky this..
anyhow since were starting to get a few more people comming on and theres a lot of new faces that will hopefully be comming out and i noticed there wasnt one of these in here i thought id start one.
1. Name
2. Car (Yr, Color)
3. Mods
4. Any pics you wanna put
1. Name
2. Car (Yr, Color)
3. Mods
on
1. Ryan
2. 2003 Lemans Sunset 350z
3.
ENGINE/DRIVETRAIN
CP 8.5:1 PISTONS
EAGLE RODS
HKS HEADGASKET
ARP L19 HEADSTUDS
AAM FUEL RETURN
RC 440 INJECTORS
WALBRO 255 FUEL PUMP
JWT LIGHTWEIGHT FLYWHEEL
JWT CLUTCH
FORCED INDUCTION
GREDDY TWIN TURBO
GREDDY 3 ROW INTERCOOLER
CUSTOM EXTERNAL WASTEGATES
HKS SUPER SEQUENTIAL BLOW OFF VALVE
EXHAUST
AAM 3" TITANIUM TRUE DUAL EXHAUST
TEST PIPES
ELECTRONICS
GREDDY EMANAGE ULTIMATE
AEM UEGO
AEM TRUBOOST
SUSPENSION/TIRES
STOCK >.<
3.
ENGINE/DRIVETRAIN
CP 8.5:1 PISTONS
EAGLE RODS
HKS HEADGASKET
ARP L19 HEADSTUDS
AAM FUEL RETURN
RC 440 INJECTORS
JWT CLUTCH
FORCED INDUCTION
GREDDY TWIN TURBO
EXHAUST
TEST PIPES
ELECTRONICS
AEM UEGO
AEM TRUBOOST
SUSPENSION/TIRES
STOCK >.<
on
1. Peter
2. 2006 Two-tone Magnetic Black/Gunmetal
3. Nismo V2 Front Bumper, INGS +1 N-spec sides and rear, Blacked-Out Headlights w/ CCFL Angel eyes, JDM tails, Eyelids, Stillen CAI, Motordyne 5/16 Plenum Spacers, GReddy SP axle-back, Alpine W205 Double din, 2 10" DD's.
On its way: Volks TE37 Time-Attack
Next: Planning on running GReddy TT set up next year when i get back from deployment.
on
1. Jamie
2. 2005 Pikes Peak White
3. PIAA Gloss Black Super Rozzas, JDM Tails 5/16th Plenum Spacer, Kenetix HF Cats, Stillen Headers, Borla TD Exhaust, JWT Popcharger
On the way: Varis Arising version 1 Side Stills and Front Lip
Next: Varis Arising version 1 Rear Diffuser and Exhaust Heat shields, Nismo V2 Rear Spoiler
on
1.Kamu
2.2003 350z 6spd. origonally Brickyard but now two tone Black and White
3.Procharger (it sucks), Nismo Headers, Nismo Cams, Nismo Exhaust, CP 8.5:1 piston, Eagle H-beam rods, Custom Upper Plenum, Aeromotive Digital FMU (it sucks), Ings Nspec +1 body kit, Bronze Volk TE37, Rotora BBK, Auto ECU (It thinks its in park all the time)
Pic thanks to erwin
Pic thanks to erwin
on
1. Peter
2. 2007 350Z Charcoal Black 6Spd Manual
3. Top Speed Megan Y exhaust-Dual stillen intakes-hyperforce system-3-D Carbon Fiber Wing-Megan racing headers (just took them out though) --(Later this week) -JVT racing headers-Fujita short ram dual intake-Body Kit-Rear-Tinted lights- Twin Turbo *Unknown* (When I get back from Iraq, or sooner if I order it and have my wife take it down to get it installed)
**Pic Thanks to Erwin
on
Ok...
1.Mike
2.04 350Z ET 6MT DB
3. HEEERRRREEEEE WE GO:
ENGINE & DRIVE TRAIN
BILLET LIGHT WEIGHT PULLIES
WISECO PISTONS 96MM 8.6:1CR
EAGLE H-BEAM RODS
HKS HEADGASKETS
ARP 1/2" HEAD STUDS W/ TIMECERT’S
ARP MAIN STUDS
VQ35DE REV UP OIL PUMP
FERREA +1MM VALVES
FERREA HD VALVE SPRINGS
FERREA TITANIUM RETAINERS
FERREA HIGH ANGLE STAINLESS VALVE LOCKS
FERREA STAINLESS VALVE LOCATORS
FERREA BRASS VALVE GUIDES
FERREA INTAKE AND EXHAUST VALVE STEM SEALS
JIM WOLFE S1 CAMS
FULL PORT AND POLISH AND KNIFE ENDGING
5 ANGLE VALVE JOB
FULL BOWL WORK ON COMBUSTION CHAMBER OF HEAD
BALANCING, POLISH CRANK
PATHFINDER REAR CYLINDER COOLING MODIFICATION
ALTERED ATMOSPHERE FUEL RETURN SYSEM
WALBRO 250LPH FUEL PUMP
RC 650CC FUEL INJECTORS
EAGLE BILLET VACUUM MANUFOLD
JIM WOLFE LIGHT WEIGHT FLYWHEEL
STAGE 5 SINGLE PLATE 6 PUCK SPEC CLUTCH
TOMEI TECHNICAL TRAX 2WAY LSD
NISMO FINNED DIFFERENTIAL COOLER
MOCAL THERMOSTATIC SADWICH PLATE
19 ROW OIL COOLER (NEED INSTALL)
13 ROW POWER STEERING COOLER (NEED INSTALL)
3X10 STAINLESS STEAL WINDSHIELD WASHER CONTAINER (NEED INSTALL)
2X17 STAINLESS STEAL RADIATOR OVERFLOW CONTAINER (NEED INSTALL)
FORCED INDUCTION
GREDDY TWIN TURBO KIT
3 CORE GREDDY FRONT MOUNT INTERCOOLER
GREDDY TYPE RS BOV
SVR TECH WASTE GATE RELOCATION KIT CERAMIC COATED
SVR TECH ATMOSPHERIC DUMP TUBES
CERAMIC COATED EXHAUST MANIFOLDS
CERAMIC COATED TURBO EXHAUST HOUSING
CERAMIC COATED DOWN PIPE
EXHAUST
MEGAN RACING TEST PIPES
EXTRA 02 BUNG FOR A/F GAUGE
INJEN SES TRUE DUAL STAINLESS STEEL EXHAUST
SUSPENTION & CHASSIS
TEIN FLEX FULLY ADJUSTABLE FRONT AND REAR
CUSCO ADJUSTABLE FRONT UPPER A-ARMS
KENITEX RACING REAR CAMBER ARMS
KENITEX RACING REAR TRACTION ARMS
HOTCHKIS FRONT AND REAR 3 WAY ADJUSTABLE SWAY BARS
GT SPEC FRONT LOWER LATERAL TIE BRACE
GT SPEC MID-CHASSIS LADDER BRACE
GT SPEC REAR LOWER LATERAL TIE BRACE
GT SPEC REAR UPPER LATERAL TIE BRACE
MOTEGIE TOUGES 18X9” FRONT 18X10 REAR
FALCON 451’S FRONT 245/18R35 (SOON TO BE TOYO T1R'S 265/35ZR18)
FALCON 451’S REAR 275/18R35 (SOON TO BE TOYO T1R'S 295/35ZR18)
ELECTRONICS
TURBOXS UTEC
TURBOXS PRESSURE SENSOR
GREDDY TURBO TIMER
BLITZ SBC ID-II BOOST CONTROLER
DEFI GAUGE CONTROL HEAD UNIT
DEFI BOOST GAUGE
DEFI FUEL PRESSURE GAUGE
AEM EUGO WIDE BAND AIR FUEL GAUGE
TEIN ELECTRONIC DAMPENING FORCE CONTROL SYSTEM
PANISONIC D1 DVD NAVIGATION STEREO HEAD UNIT
MISC
TOPSPEED SHORT SHIFTER
VOODOO SPUN ALUMINUM COUNTERSUNK SHIFT ****
TRIPLE A-PILLAR POD
AWAITING INSTALL
MODIFIED BUMPER BRACE
COMING SOON
101 PANICK BRAKE BYPASS
DRIVE SHAFT SHOP LEVEL 5 HALF SHAFTS
STOPTECH BIG BRAKE UPGRADE 13” 6 PISTON FRONT 12” 4 PISTON REAR
ROLLBARS
HARNESS
Um I think thats it, got a few other small projects in the works though. Like push button start (maybe biometric start depending on query resluts from a company http://www.automobile-security.com/products.htm). If not the KPierson module.
2.04 350Z ET 6MT DB
EAGLE H-BEAM RODS
HKS HEADGASKETS
ARP MAIN STUDS
FERREA +1MM VALVES
JIM WOLFE S1 CAMS
5 ANGLE VALVE JOB
FORCED INDUCTION
GREDDY TYPE RS BOV
EXHAUST
ELECTRONICS
TURBOXS UTEC
GREDDY TURBO TIMER
DEFI BOOST GAUGE
MISC
TRIPLE A-PILLAR POD
AWAITING INSTALL
COMING SOON
ROLLBARS
HARNESS
on
1 Post
- Erwin
- '04 Base MT Pikes Peak White
- Advan RGII (18x9+22F;18x10+25R) | Falken FK-451 (245/40/18F;275/40/18R) | Project Mu B-Force F+R Brake Pads | Swift Springs | Kics Project R40 Lugs | Varis CF Air Duct, CF B-Pillars, CF Front Under Spoiler | C-West PFRP Front and Rear Lip Kit | Nismo Ti GT Shift ****, Oil Filler Cap, Radiator Cap, Cat-Back Exhaust | OEM JDM Kouki Taillights & Smoke Reflectors | Blitz Rear Spoiler | Liliput Monitor | JVC Head Unit
Next: Carbing Front Strut Bar & Radiator panel... or Varis Radiator Panel, Amuse or ARC Intake Pipe, '06 OEM Air Box, Nismo Sway Bars, Tokiko Struts.
on
Originally Posted by punish_her
1.Mike
2.04 350Z ET 6MT DB
EAGLE H-BEAM RODS
HKS HEADGASKETS
ARP MAIN STUDS
FERREA +1MM VALVES
JIM WOLFE S1 CAMS
5 ANGLE VALVE JOB
FORCED INDUCTION
GREDDY TYPE RS BOV
EXHAUST
ELECTRONICS
TURBOXS UTEC
GREDDY TURBO TIMER
DEFI BOOST GAUGE
MISC
TRIPLE A-PILLAR POD
AWAITING INSTALL
COMING SOON
ROLLBARS
HARNESS
2.04 350Z ET 6MT DB
EAGLE H-BEAM RODS
HKS HEADGASKETS
ARP MAIN STUDS
FERREA +1MM VALVES
JIM WOLFE S1 CAMS
5 ANGLE VALVE JOB
FORCED INDUCTION
GREDDY TYPE RS BOV
EXHAUST
ELECTRONICS
TURBOXS UTEC
GREDDY TURBO TIMER
DEFI BOOST GAUGE
MISC
TRIPLE A-PILLAR POD
AWAITING INSTALL
COMING SOON
ROLLBARS
HARNESS
on
brendon
07 350 black
engine=stock
exhaust=nismo
suspension=airrunner japan, cusco front and rear swar bars
interior= alpine double din, 10in JL w7, JL 500 watt
wheels= AME shallen CX 19x9.5 and 19x10 +10 front and rear
work meister S1 19x9.5 and 19x11
+10 +17
07 350 black
engine=stock
exhaust=nismo
+10 +17
on
1. Andy
2. 2005 Redline Enthusiast 6sp
3. Volk Racing Time Attacks LE-37
BFG KDW2 255/35-19, 285/35-19
RAYS Light Weight Lugs (Red, Long)
JWT Pop Charger CAI
Borla True Dual Exhaust
Top Speed Headers polished
Kinetix High Flow Cats
Hotchkis Lowering Springs
Matte Black weighted shift ****
Rouge Short throw Shift kit
JWT light weight Flywheel
3.91 gears
JWT high pressure Clutch kit
Hotchkis Sways
Wilwood BBK 14" 6 piston front, 13" 4 piston rear
Motordyne 5/16" Iso-Thermal Plenum spacer
Seibon Carbon Fiber Front Lip
20% Window Tint
Custom Painted Engine and battery covers.
Vertex Rear Spoiler (Paint Match)
VIS OEM Carbon Fiber Hood
Titek Carbon Fiber Air inlet
Titek CF Cooling Plate
Zignals side emblems
Clear JDM side markers
Kenwood Double DIN in dash DVD and Navigation
Custom Speaker enclosures front doors and rear subwoofer by Wicked C.A.S
Kenwood Excelon Component Speakers Front and Rear
JL Audio 10" Sub Woofer
JL Audio 450 watt amp for components
MTX 350 watt amp powering Sub
CinCity Blacked Out Headlights
Stillen front license plate bracket
4. Not mine, but pretty damn close!
[IMG]H:\wenzelap\ProfData\My Pictures\199451507-L.jpg[/IMG]
JWT Pop Charger CAI
3.91 gears
Hotchkis Sways
20% Window Tint
on
1. jeff
2. 06 magnetic black enthusiast 6mt
3. dynamic auto design drop springs (nice and stiff)
fujita short ram intake
exhaust systems hawaii custom blitz nur spec (1 whole peice from the y pipe out with flomasters y pipe conectors)
spec d short shifter
lightend flywheel with act pressure plate and exedy disk
grounding kit with g-force.
4. soon sfr twinturbo kit, rim (dont know which one yet), greddy front lip, and blitz rear spoiler.
on
Hey! I know, it's not my right forum as I drive the older sister of the 350Z/G35, the 300ZX, but since this one is calling out to all the Hawaii locals, I figure I'd show face and get involved
1. C.A.
2. 1991 300ZX Twin Turbo
3. Current Modifications
- JWT POP Charger Intake
- JWT Performance ECU
- Specialty Z Labree Exhaust
- Aftermarket Clutch (don't know what kind, previous owner put it in)
- More to come!!!
4. Few pics below.
Other stuff can be found on my CarDomain site: http://www.cardomain.com/id/addicZion
1. C.A.
- More to come!!!
4. Few pics below.
on
I absolutely LOVE Z32's. My dad owned a '77 280Z, and when I started taking a deeper interest in cars, the 300ZX was Nissan's beast, so I fell instantly. I have a red NA, but I gave that to my dad. So, in essence, we're a Z family (my uncle has a 2+2, too).
I'll try to come out to future meets. This sunday's one doesn't look too good for me to come out, though, but anything can happen. Just keep me updated on meets
Thanks for the welcome!
on
