Photoshop expert needed...please
Old 09-10-2012, 10:19 AM
KingBaby
Hardest Setting
KingBaby's Avatar
not adding a wing to it...just raise the stock top wing!
Old 09-10-2012, 11:06 AM
TedB350Z
TedB350Z's Avatar
got your PM... something like this?
Attached Thumbnails Photoshop expert needed...please-a8226a27.jpg   Photoshop expert needed...please-nismov3380rsside.jpg
Old 09-10-2012, 01:06 PM
KingBaby
Hardest Setting
KingBaby's Avatar
Not exactly lol
sperate the wings
remove the middle stantion/blade
the risers that connect the two wings to be black
I made an embrassing paintbrush picture but it looks like my son made it lmao
Old 09-10-2012, 01:32 PM
KingBaby
Hardest Setting
KingBaby's Avatar
Originally Posted by KingBaby
Either way removed my wing today in preparation for awesome or complete and utter failure!
Pop trunk and remove the six black tape circles covering (6) 10mm bolts and (2) 10mm nuts!
A whole bottle of this is required! Not even kidding...floss and plastic knife help!
The mess it left?
Authentic Nismo 350Z Z33 V3 Wing Spoiler (<---for engine searches) is 10lbs max my house scale is accurate but by myself wasn't able to hold the wing and take picture!
(3) 10mm each side (6) total...1 Philips head bolt, didn't size it holds the center blade down
Seperated!
For the high rising idea, it's not a smooth/flat surface. So the mount gonna have grooves in it.
Notice how the wings are three pieces? hopes this helps...
Old 09-11-2012, 08:52 AM
tkuntz
tkuntz's Avatar
seen the work you put into taking that wing off and the mess it made, has made me reconsider taking the wing off to get a carbon fiber blade!
I hope everything works out ha, looks like a PITA! ha.
Old 09-11-2012, 09:42 AM
Sean S
Sean S's Avatar
Here hope this helps. Would be badass if you could pull it off,
Old 09-11-2012, 09:51 AM
KingBaby
Hardest Setting
KingBaby's Avatar
Thanks thanks thanks.....but and it's a small but....
can you make the side plates silver like the car and the added riser black?
thanks alot
It was a mess, but one a scale of 1 to 10. It was a 3, mainly because it was so tedious. Also I was scared to break a bracket!
Old 09-11-2012, 10:15 AM
Sean S
Sean S's Avatar
No problem,
here it is with the colors switched,
Old 09-11-2012, 10:16 AM
Sean S
Sean S's Avatar
raised up and a bit bigger,
Old 09-11-2012, 12:20 PM
KingBaby
Hardest Setting
KingBaby's Avatar
Awesome job...on the second picture
[/QUOTE]
BUT
how about we make the side plates the same relative size as the stock wing!
thanks alot
Old 09-12-2012, 03:49 PM
Sean S
Sean S's Avatar
here you go, no problem:
Old 09-13-2012, 02:32 AM
KingBaby
Hardest Setting
KingBaby's Avatar
Perfect man!
You guys must think I'm a ***** lmao, only thing is to move is slightly backwards loo!
Even if you don't do that man you've a lot for me/us visually on how this would look! Obviously it would look great!
Thanks again man
Old 09-25-2012, 06:01 PM
Sean S
Sean S's Avatar
no problem man,
sorry lost track of time, here it is pushed back a bit
Old 09-25-2012, 07:00 PM
KingBaby
Hardest Setting
KingBaby's Avatar
Win!
As an update, I took the wing to a shop last week and he already on it! I forward him this link to help visual with where I wanted it!
Thanks man hopefully we can see this materialize here shortly.
Old 09-25-2012, 07:07 PM
Sean S
Sean S's Avatar
Sweet! Good to hear man no problem, hit me up if he needs more visual updates.
Old 09-02-2013, 06:13 PM
KingBaby
Hardest Setting
KingBaby's Avatar
Paging Sean S
If possible on this picture
Old 09-02-2013, 06:17 PM
KingBaby
Hardest Setting
KingBaby's Avatar
Since my last idea of a paint job has been done several times I think it might look good?
08-06-2021 06:19 AM
m_0g
06-03-2021 10:05 AM
350zrn35
Photoshop
09-14-2015 06:53 PM
carid
Misc.
09-10-2015 06:16 AM
Quick Reply: Photoshop expert needed...please
