Cosworth Plenum FI/NA: Pics Inside!
Old 11-07-2006, 12:49 PM
  #81
IIQuickSilverII
IIQuickSilverII's Avatar
probably
i called them and they quoted me at 1400 i think if i remember well
Old 11-07-2006, 12:52 PM
  #82
NoLimit
NoLimit's Avatar
i dunno....
this board is funny like that. plus Tim has only made a handful of these i think. The entry price without some documentation probably stops some, But people jumped on the blingin' kinetix, ... so .... ?
Old 11-07-2006, 01:44 PM
  #83
Kenk2
Professional
Kenk2's Avatar
Originally Posted by NoLimit
i dunno....
Some independent dyno testing of NA and FI cars would be great!
Old 11-07-2006, 03:13 PM
  #84
Sharif@Forged
Forged Performance
Sharif@Forged's Avatar
The flow diagrams that Cosworth showed me, clearly show a decrease in airflow to the front cylinders on the stock manifold. The Cosworth improves the distribution, but there is still less air to the front cylinders. Regardless of plenum design, it is virtually impossible to design a realistic plenum that delivers perfect distribution to all cylinders. Optimizing is the best one can hope for. And with sufficient collector volume, its not an issue. An engine does not operate on a flow bench...ie...air will travel to the path of least resistence, which happens to be an open valve.
Most high end engine management systems, and even some lower end models, allow for individual cylinder trims. We always add additional fuel to rear cylinders, just to be safe.
Old 11-07-2006, 05:19 PM
  #85
redline350ZZ
redline350ZZ's Avatar
Would it be hard to swap to a cabled TB and discard the DBW entierly? Then we could run as big a TB as we wanted too...
Old 11-07-2006, 06:27 PM
  #86
TurboTim
Vendor - Former Vendor
TurboTim's Avatar
Originally Posted by taurran
SFR was working on a manifold but I think the project died. It had longer runners than most.
http://www.speedforceracing.com/prod...y_g35imani.php
The Kinetix SSV has longer runners, but we all know that got them nowhere.
Besides, turbocharged Z's aren't hurting for low end power, it's carrying it out to redline thats the hard part.
We actually came up with our final design (third revision) and have sold it to a few beta testers. Unfortunately, people who have bought the plenum have their fricken cars in pieces or not finished yet! Arggggg!
That hasnt stopped us though A few weeks ago we put it on a rev-up G35 with a brand new motor, clutch, turbos, etc...... and dynoed it to the tune of +50 ft/lbs of torque at the wheels, at 4000 rpms. We only revved the car out to 4500 rpms and we only ran it at 7.8 psi of boost, since the motor had no miles on it (and we wanted to break it in easily). Both banks had AFRs that were within 1% of each other. We didnt measure eGT's but we will when the car is broken in and we crak upthe boost to 15-16 psi.What I noticed was the effect on spool-upthe plenum had. Outrageous! Much faster then my car and I have 10.3 to 1 compression vs. the built car which has 8.6 to 1 compression. Both cars have the same size 60-1 turbos. We will be finishing our dyno testing on this twin turbo car in about two weeks. We also have a N/A test car that we will put the plenum on very soon.
Finally, sorry for lagging on the project guys. R&D takes time and we wanted to get it right.We werent too concerned about rushing it to the market without fully testing it and determining the optimum runner length and plenum volume. We have that nailed and now it is time to see what that translates too as far as horsepower is concerned
Tim
Old 11-07-2006, 06:48 PM
  #87
zman1910
zman1910's Avatar
The Cosworth doesn't look all that different from the stock plenum design in terms air entry. I'm sure overall volume will play a factor as well but I don't think it will be all that much different than current plenums offered...but we'll see as Sharif said.
On the other hand..the one that Tuarran posted seems much more efficient as their is separate piping for each of the 3 cylinders whereas the Cosworth will be distributing to all 6 cylinders through one pipe at the top....still potentially lacking air flow to the 5th and 6th cylinders. I know there is much more involved than simply the design as I see it.....but I'm just speculating more than anything
Old 11-07-2006, 07:25 PM
  #88
IIQuickSilverII
+1 will have to wait for reivews..notice i write reviews = ]
Old 11-07-2006, 07:49 PM
  #89
Vash350Z
Vash350Z's Avatar
Oh god i want one.
Old 11-08-2006, 12:21 AM
  #90
Z350Lover
Z350Lover's Avatar
I AM SOOOOO IN FOR THAT PRODUCT!!! I think it will help my N/A tuned 350Z screams all the way to the current 8200rpm fuel cut!
cheers,
richie
Old 11-08-2006, 03:41 AM
  #91
aalzuhair
aalzuhair's Avatar
Tim
Sorry Tim ....
But soon we will all see the +800whp 350Z
I only have one issue (the one that you are working one )
Az
PS: I might have a Motec be the time I get the parts from you guys
Old 11-08-2006, 04:24 AM
  #92
Z350Lover
Z350Lover's Avatar
Az,
are you still getting your motec from Simon at Nizpro?
cheers,
richie
Old 11-08-2006, 04:38 AM
  #93
aalzuhair
aalzuhair's Avatar
What's going on Richie, all is well I hope?
Most likely .. yes
We have a local guy that told me that he could get me a good deal on a Motec .. but I'm still looking around ... And Simon .. I guess is the best, hands down
Any thoughts?
Az
Old 11-08-2006, 05:40 AM
  #94
IIQuickSilverII
cheers,
richie
if you are n/a running a utec and you raised the rpm limit to 82000..thats pretty dangerous... from 6800 maybe to 7200....
Old 11-08-2006, 05:44 AM
  #95
ZU L8R
Viper Sellout
ZU L8R's Avatar
richie has a motec and is fully built NA
Old 11-08-2006, 06:13 AM
  #96
Sharif@Forged
Forged Performance
Very easy to do, as long as you have a standalone engine management, such as the FCON VPro, AEM, Motec, etc..etc.
But I want to thoroughly research the actual bottleneck. The throttle body is one piece of the equation.
Old 11-08-2006, 10:02 AM
  #97
Vash350Z
Vash350Z's Avatar
Any word on a release date for this?
Old 11-08-2006, 10:33 AM
  #98
Sharif@Forged
Forged Performance
Q1, so probably March.
Old 11-08-2006, 11:22 AM
  #99
rs350z
rs350z's Avatar
Thumbs up
Is anyone working on something similar to this one in design?
I know routing the throttle body and piping up front would be a problem, but I'd like to be able to bypass the turbo mounted area on the single turbo kit altogether. It should also flow much better than wrapping around back.
+1 the TS plenums are al pretty nice. It would be very nice if a company came out with a diff tb location. AAM/CJ/Cosworth, someone do it!!. I think when CJ was originally designing you would be able to choose???? either way +1 for us ST guys!!!! After seeing the gtk 240 that is all I can think about
Old 11-08-2006, 11:29 AM
  #100
Sharif@Forged
Forged Performance
Front feed plenums require a lot of fabrication, and customized work. It will never be a bolt on affair, IMHO. It's a terrific design though.
Quick Reply: Cosworth Plenum FI/NA: Pics Inside!
