GT Motorsports Turbo and NA/SC Spec Camshaft Dyno Testing Results
#61
Originally Posted by BrianLG35C
Sam, you would have to tempt me like this, when you're getting so close to shipping my motor!
-Sam
GT MOTORSPORTS
#62
Originally Posted by baptist
Thanks Brian, thats awesome gains.
Wonder how they sound compared to stock. ????
And valvetrain required or not?
As far as the valvetrain, the cams are designed to be used with the factory valve train and springs, although we strongly recommend to upgrade the springs since you are already there.
-Sam
GT MOTORSPORTS
#64
Valve train upgrade required?
A basic spring upgrade would run you about $250, FYI
-Sam
GT MOTORSPORTS
#65
Originally Posted by BamBam
Congrats as always Sam and Crew.....
I have the GTM Turbo Spec cams and I have to say I was disappointed...LOL… I was hoping for a lopey sound from the cams...sort of like a V8... Instead it sounds pretty much stock? Everyone keeps telling me they can't tell by the way it idles or runs that anything has been done to the engine... BUT there is not doubt there is a really solid midrange boost and they work really well with my Greddy kit.
(FYI: in case someone mistakes my joking... I think the GTM cams are very good. I actually sold my JWT C2 cams for these... The fact that your average person can't tell what my car is capable of until I romp on the gas.... VERY VERY impressive...)
--B
--B
Stay out of trouble
-Sam
GT MOTORSPORTS
#68
Originally Posted by r@mon
Do you guys have anything more aggressive? I'm looking for something go for power all the way up to 8k
In the next few weeks, we will be releasing our new GTM HR(High Rev) Stroker kit, this kit will be equipped with our most aggressive cams and we will be shooting for a powerband that makes power all the way to 8k rpms. Also we will be releasing our cam for the 07 3rd gen engine (VQ35HR)
-Sam
GT MOTORSPORTS
#69
!!HR TT!!
on
Originally Posted by Sam@GTM
Currently the cams released are all stage 1, we will be offering stage 2 and stage 3 cams shortly. Stage 3 will be the most aggresive, and all these stages will be offered in all 1st though 3rd gen camshafts (VQ35DE, VQ35DE REVUP, VQ35HR)
-Sam
GT MOTORSPORTS
-Sam
GT MOTORSPORTS
Jeremy
#70
on
Unfortunately brian is would have been a very good option but we are WAY too far into your engine to make a change like this at this time.
-Sam
GT MOTORSPORTS
-Sam
GT MOTORSPORTS
#71
on
Gee, thanks Sam.... I have not even had a chance to start pushing the stroker kit I have and you are already releasing bigger/better versions ....
SLOW DOWN bro.... Take a vacation or something... Let some of use catch up with all the new stuff you have put out before overwhelming us with new product...
I mean, do we REALLY want to go through another build for me this year..... Just so I can stay on the bleeding edge... HAHAHA
Good luck with the new cams... maybe that is something I can upgrade in the winter if I feel I don't have a large enough power band . LOL
--B
PS. I could use a new 3.3 final drive, that would work with an ATS diff before mid July though..... :HINT:HINT:
--B
-Sam
GT MOTORSPORTS
-Sam
GT MOTORSPORTS
#72
Evil Boy 4 LIFE
on
ahhhhh i cant handle all this goodness.. seriously.. it sucks having so many options to achieve power goals.. now ill never decide.. thanks..haha
so whats the status on the stage2, 3 aggressive cams for revup? will the be available in time for my build? what kind of gains are you shooting for? im excited........
#74
I assume this was with the Stage 1 Turbo Cams. How about the other 2 that GTM sell as seen below.
Quick question though why does the Stage 2/3 cams duration swap around compared to Stage 1 ie: Stage 1 has a higher duration on EX and Stage 2/3 have a higher duration on IN? Also can anyone explain "generally" which of the cams you would use for what purpose or goals.
Stage1:
Intake: 256 deg (stock 238)
Exhaust: 264 deg (stock 240)
Lift: 0.423” (intake and exhaust)
Overlap: 18 deg (at 0.045” lift) – less than stock
Stage 2:
272 degrees @ .012”
232 degrees @.050”
11.00mm Valve lift intake and exhaust
Stage 3:
288 degrees @ .012”
245 degrees @ .050”
11.50mm Valve lift intake and exhaust
Stage1:
Stage 2:
272 degrees @ .012”
232 degrees @.050”
Stage 3:
288 degrees @ .012”
245 degrees @ .050”
#75
Stage1:
Stage 2:
272 degrees @ .012”
232 degrees @.050”
Stage 3:
288 degrees @ .012”
245 degrees @ .050”
Stage1:
Stage 2:
272 degrees @ .012”
232 degrees @.050”
Stage 3:
288 degrees @ .012”
245 degrees @ .050”
I currently run the stage 1 cams. My cams, showed good midrange power and still allowed power to be held through redline. As you move to the stage 2 and then to the stage 3, you are most likely pushing that power higher up in the revs; and making more of it
#78
Originally Posted by Alberto
Im no GTM hater, but how do you explain the curve on a Vortech car smooths itself out so much from a crap base tune to a nice smooth curve with only a built motor and cams with NO tuning? That makes no sense at all...
It isnt a stock Vortech....then stock Vortech with his cams . The first dyno...the car had problems [ somewhere ] it only made 300whp on a dynojet . The second [ with cams ] the problem no longer is there . Easily seen by every one . But only you and I asked why .
#79
on
have any others dyno'd this setup on a stock vortech setup vs. stock vortech setup + cams?
the one here has a built block and so it adds a few other elements to the analysis.
any extra info would be great. thank you.
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
