First Look - KPtechnologies Speed Shift Module
#162
on
As we discussed I also sent a relay for the brake bypass module. I didn't include any instructions to install the relay so I'll have to send you that info still. It should be pretty easy to install though!
#178
Vendor - Former Vendor
on
We just installed the KP module on my twin-turbo Z.It works great.I love that two-step.Now I can launch the car without bogging out or spinning the tires.Ok well I still spin the tires but when I play with it more, I should be able to have minimal spin.The flat-foot shifting is cool but it definitely takes some getting used to.Your normal tendancy is to let up off the throttle between shifts so you dont rev the car to oblivion!
#179
on
Just got done with the install - I must say it was a bit frustrating on this car. The "ignition coil" power wire wasn't in the same location and when we finally found it it wasn't that easy to work with. We did get it working though and I made a few videos - I will try to post them tomorrow at some point.
I only have, I think, 2 modules left - I guess we need to decide if we are going to release them or not.
