SP boost activated exhaust cutout
#41
Sound Performance
Sound Performance
on
Quick video of it operating at 13psi and then at 25psi
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Bl1QdmqvU4I&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Bl1QdmqvU4I&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
SP Boost Activated Exhaust Valve (includes: valve, actuator & actuator mount)
2.5" $349
3" $349
4" 399
Additional items
Y-pipe (Stainless)
2.5" $48
3" $48
4" $77
Y-pipe (Aluminized)
2.5" $42
3" $45
4" $65
We can also sell it with a small straight section with an angle cut on it so you can just weld onto your current exhaust.
Final product pics of 3"
Chris
2.5" $349
3" $349
4" 399
Additional items
Y-pipe (Stainless)
2.5" $48
3" $48
4" $77
Y-pipe (Aluminized)
2.5" $42
3" $45
4" $65
Chris
#44
on
Let me get this right , so your saying that you should always use an x pipe,and that that would function better than true dual exhaust. Do you mind my asking if you would explain please, not bing an *** just wanting to know. Was also wondering if these are ready to ship? 2 , 3 in.
#45
CJ Motorsports
great product guys... looks like it has top notch materials and build quality.
at what boost pressure is it set to open? i assume you may be able to order different springs in the actuator to open it at different boost levels?
i need to come up with some more money for these really soon. we are gonna build the downpipes for my new setup pretty soon and thats probably the best time to put these in.
#48
Also if I already have a true dual exhaust will I need to buy 2 of these to work? And will these actually hurt performance if I'm sc bc there's no more backpressure?
#49
Sound Performance
Sound Performance
It all depends on how you install it. If you have a VSV valve inline, then you can use a hobbs switch or an output from your standalone computer to tell it exactly when to open. You can even wire in a switch in the car so that it will never open if you want the car to be quiet all the time. If you just install it with no VSV valve then it begins to open at about 4 psi and is fully open by 10 psi.
#50
Sound Performance
Sound Performance
If you have a true dual exhaust then yes you will need 2 of these. Because it will not open until you in boost, it will not hurt the performance of a SC car. Backpressure is only of real importance before you make boost. After you are in boost, the less backpressure the better for HP!!
#52
Sound Performance
Sound Performance
Yes no problem at all, just wire the vacuum switching valve in parallel to the nitrous solenoind and they will both open together.
#53
#54
Sound Performance
Sound Performance
Well I guess the easiest way to see what you will gain is do back to back pulls on the dyno... one with the exhaus ton, and then drop the exhaust to simulate the dumps and you will know!
#57
Sound Performance
Sound Performance
I guess it depends what HP is worth to you. I have customers spend tons of money on things that give you no HP at all like blow off valves. IF the car picsk up 40 HP then $1000 is not that bad!! Look at the GTR guys.... they pay $2500 for a pipe upgrade that give you ZERO HP and they spend $4500-$5000 on exhausts that give you 10 HP!!! Those guys are crazy and the GTR parts are SO overpriced!!!
#58
[/turth]
#59
でたらめ検出器
#60
no doubt! those GTR mods are ridiculously overpriced.
