You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
GT Motorsports: APS ST GT35R Turbo upgrade kit - 500RWHP
As many of you know the APS Single Turbo system was designed for stock block output, and tight packaging in mind. To accomplish this they use a Garrett CHRA with their own compressor and turbine housing, the only problem is that these housing are extremely small and kill the performance of the kit.
So for anyone looking to improve their power curve on a stock block, or make more power on there built block, then our kit will suite your needs. Includes replacement Garrett turbine and compressor housings, TiAL waste gate, V-band clamps, and custom GTM turbo/waste gate collector.
We have made over 500rwhp on this kit with the T04E compressor housing, a T04S housing is also available which will help the power output but require further modification.
This kit requires slight modification to fit, you will need to modify the APS support bracket for the scavenging pump, and you will also need to modify your cross member to clear the larger turbocharger. The T04S compressor requires significantly more modification and is recommended to be installed by a professional facility.
