Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Body, Interior, Exterior & Lighting (DIY) > Repairing & Detailing (DIY)
Old 04-20-2007, 10:16 PM   #1
FairladyZ06's Avatar
Thumbs up How-To Change Your Oil **WITH PICS**
The oil change is very straight forward, no hidden bolts etc. Lets start with the tools you need, thanks to prior DIY's.
TOOLS: 10mm socket, 14mm socket, Oil filter removal tool($3), Socket wrench, 5 Quarts of oil, Nissan drain plug copper gasket($.66), Ramps are optional($30), Oil catch pan, Funnel, Rag(for cleaning up) and ofcourse Common sense(Priceless). *Refer to Image 1, 2*
* If you are doing this at night, you will need a work light. (Image 1A)
Alright lets begin:
STEP 1: REMOVE UNDERBODY DIFFUSER. Some people do this without removing it, I suggest otherwise unless you like oil spilling onto it and clean up more than you have to. The diffuser is very easy to remove, although somewhat annoying because of the 14 bolts. Basically, you want to follow the 10mm bolts around the diffuser til you get all of them off- they should be on snug. (Refer to image 4, 5)
STEP 2: REMOVE DRAIN PLUG. Alright now that you have the diffuser off, you should be able to see everything underneath. Remove the oil cap on your motor before draining oil. You will see the drain plug pretty much directly underneath the filter. Get the oil catch pan ready. Use a 14mm socket to remove this. Once out, you will see a majestic stream of dirty grimy oil come flying out. This will take a few minutes, thankfully my VQ isnt burning oil so I saw most of my oil come back out haha (Refer to image 3)
STEP 3: REMOVE OIL FILTER. Once you get the drain plug out, you can loosen the oil filter by using the oil filter removal tool. If you are using the adjustable one, just get it tight around the filter and slowly loosen it. There will be some oil coming out, so keep the oil catch pan next to you. Once all this is drained out, you are ready to put the drain plug back in. (refer to image 6)
STEP 4: INSTALL DRAIN PLUG AND NEW FILTER. Get the new copper gasket/washer contraption, use 14mm socket to get the plug back on snug, DO NOT OVERTIGHTEN the bolt. LUBE the new filter around the gasket with some fresh oil. Put the filter on with your hand and get it snug, and give it a 3/4 rotation with the tool. (refer to image 7)
STEP 5: STAND UP AND STRETCH!:icon14: After being in a crouching tiger hidden dragon position, its always good to stretch.
STEP 6: POUR NEW OIL INTO MOTOR. Get your 5 quarts of oil and funnel. Start pouring the oil in. Once thats done, put your oil cap back on.
STEP 7: CHECK YOUR WORK AND TURN CAR ON. Look around make sure you didnt miss anything. Make sure everything is on tight. Turn the car on and check for leaks.
STEP 8: PUT DIFFUSER BACK ON. Reverse directions from STEP 1. Once you have this back on, you are good to go!
Pretty easy install, I did it by myself during my first oil change on the Z , so you can do it too! Obviously I dont take responsibility if something goes wrong, as this is merely a guide to help you.
FairladyZ06 is offline   Reply With Quote
Old 04-20-2007, 10:21 PM   #2
More Images: P.S. Fram is just another way to spell CRAP!!
Old 04-20-2007, 10:28 PM   #3
JDMFairladyZ33's Avatar
Is that a fram oil filter?!?
__________________
I love Silver cars!! 2007 Infiniti FX35 Diamond Graphite 2005 Nissan Altima 2.5S Sheer Silver 2003 Nissan 350Z Performance SS - SOLD
JDMFairladyZ33 is offline   Reply With Quote
Old 04-20-2007, 10:32 PM   #4
Sean's Avatar
I guess if I was making this guide, it would just be a picture of me pulling into the dealership
__________________
Entaille "you dont know how long I've been looking for a hoodie that has a skull with angel wings and glitter all over the place. where can I buy them? "
Sean is offline   Reply With Quote
Old 04-20-2007, 10:33 PM   #5
jeffie7's Avatar
lol I didn't know people used Fram filters on Z.
One thing to add, make sure you check the old oil filter to make sure it still has it's gasket on it. If not you'll double up the gaskets when installing the new oil filter. This makes for a nice oil leak.
The flat fram gaskets do this often!
__________________
DNF fUzZyBuNnYbAlLz iny0mouf
jeffie7 is offline   Reply With Quote
Old 04-21-2007, 02:05 PM   #6
Haha yeah thats my buddy's Z and he didnt know how bad FRAM was . I taught him that PureOne is the way to go as I myself learned because of this forum
Old 04-21-2007, 02:13 PM   #7
My R1 is Faster
zand02max's Avatar
Quote:
uhm, lose the SCAM, I mean FRAM filter next time, !
zand02max is offline   Reply With Quote
Old 04-21-2007, 02:16 PM   #8
subscribed
__________________
flynbrin is online now   Reply With Quote
Old 04-21-2007, 07:23 PM   #9
jondimellow's Avatar
is bosch a good filter for the Z?
__________________
//Some Stuff// Kimchee Powered//
jondimellow is offline   Reply With Quote
Old 04-21-2007, 07:30 PM   #10
drivenCSZ's Avatar
just did mine today as a matter of fact.
mobile 1 and a M1-108
__________________
2003 VIN# 189...my popcharger is getting lonely
drivenCSZ is offline   Reply With Quote
Old 04-21-2007, 07:37 PM   #11
n8vz's Avatar
Quote:
Bosch recently bought Purolater. I think the top of the line Bosch and the top of the line Purolater (PureOne) are identical. I have a PureOne installed on my Z for the past 5K miles and it has worked great. (I used the larger sized PureOne spec'ed for 2001-2004 Maxima and it works fine).
Although, people (bobistheoilguy.com) have complained that quality of PureOne has suffered a bit since they were bought by Bosch. On my next oil change, I am either going to the extra OEM Nissan "larger" size filter or try out WIX/Napa Gold filter(which has really good reviews).
n8vz is offline   Reply With Quote
Old 04-22-2007, 05:07 PM   #12
the regular purolator filter and the proline filter (i get it at pep boys) is the same exact filter. i know the purolator pure one filter has better filtering media, but at the sacrifice of having less oil flow ability.
any of you getting the regular purolator filter should get the proline filter; same exact filter..saves you a little bit.
i think i'm gonna try the wix filter next. wix always makes excellent oil filters.
ipodhustle is offline   Reply With Quote
Old 04-22-2007, 09:42 PM   #13
I always use OEM i didnt know that they had a larger one. What is part # on filter?
SiCKBLaCKMaX99 is offline   Reply With Quote
Old 04-23-2007, 08:09 PM   #14
n8vz's Avatar
Quote:
15208-9E000
this is what the OEM nissan filter I use and it fits VQ35DE just fine. It is spec'ed for previous generation Pathfinder and the current Titan. It is not a really big filter (about the same size as the OEM toyota filter for 3.3L Camry engine), but just bigger then the super small OEM Nissan filter for 350Z.
Old 04-24-2007, 02:52 PM   #15
Moderator
350Z, OT, & Engine
vo7848's Avatar
I've used fram filters for over 10 years now, and never had one single leak. Perhaps those doing the oil changes are forgeting to coat the new filter gasket with some oil before they screw it on.
On a different note, I've been brainstorming ways to modify the deflector shield so I can change the oil, in a clean manner, without removing it. My GF's Corolla had a similar problem. I was able to cut the plastic shield under her car with my dremmel. Oil changes are a breeze now. Of course with the Z it's a bit different, considering the deflector actually serves a purpose. I'd hate to compromise the intergrity of why the panel is there or even cut an open hole in it, allowing dirty street water to splash up and dirty my immaculate engine bay.
Any thoughts?
__________________
Team Nextstage
Sponsored by Meguiar's
www.teamnextstage.com
Team DNF n00bslayer & eater of children............................................................ ...............
vo7848 is offline   Reply With Quote
Old 04-29-2007, 09:19 PM   #16
billp's Avatar
Where do you get rid of your drained oil?
billp is offline   Reply With Quote
Old 04-29-2007, 11:11 PM   #17
Bevo's Avatar
Quote:
There you go, type in your zipcode and search:
http://www.mobiloil.com/USA-English/...Recycling.aspx
__________________
2006 350Z Enthusiast MB 6MT
Bevo is offline   Reply With Quote
Old 04-29-2007, 11:17 PM   #18
saved
__________________
JWT Popcharger/NISMO exhaust/Crawford Plenum
NissanZfan is offline   Reply With Quote
Old 04-30-2007, 03:49 AM   #19
billp's Avatar
Thanks, will do
Old 05-01-2007, 10:26 PM   #20
AlvinHuyN's Avatar
Can you do this without removing the diffuser? That seems so annoying if you have to remove it every time you change the oil lol. Ok ok I guess I'll stop being a lazy bum haha
__________________
[His]-Graphite Grey Evolution IX MR & [Hers]-Obsidian Black G35 Coupe
AlvinHuyN is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
