You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
First off, THANK YOU SOUND PERFORMANCE
Thank you Chris, Larry, Vince, Tim, and the rest of the team........
They have converted my '04 G35 6mt coupe into a terror, and I couldn't be happier.
Today Larry finished the tuning to let me break in the motor...
Now warning this was done with stock heads, stock cams and through the STOCK Y-PIPE, STOCK MID-PIPE, STOCK MUFFLER (the exhaust is just for the engine break-in, don't worry it'll be changed)
After the break-in and new exhaust we'll be turning up the boost on both pump-gas and E85 so stay tuned in the next couple weeks, and carefull what stock looking G35's in chicago you roll up on.
@ 9psi the car made:
393rwhp
402rwtq
The setup:
SP Stage one built Shortblock
Pauter Rods
Wiseco Pistons
ACL Race Series bearings
ARP Main Studs
Nissan Gasket Kit
New Nissan Oil pump
Hot Tank, clean, bore cylinder block
SP Twin Turbo setup
SP51mm ball bearing turbo’s
Tubular Turbo manifolds with T3 flanges (heat coated hi-temp silver)
Oil Scavenge Pump Custom
SP Oil scavenge tank
K&N Filters
Tial 38mm wastegates with atmospheric dump
Tial 50mm Blowoff valve
SP Front mount intercooler
3” Downpipes from turbo’s to factory y-pipe
Oil pan spacer and fittings
SP Fuel System
SP Triple pump hangar
3 walbro 255lph pumps
1000cc inj
all plumbing of course
pro-EFI (48-box)
Southbend DXD Stage V feramic clutch
Gauges:
AEM Tru-boost/controller
AEM UEGO AFR
Wheels:
Don't remember brand (d'oh) but 18x8.5 and 18x9.5
Tires:
Khumo MX 245/40, 275/40
I'll have more pics of the car as soon as it gets a bath tomorrow.....
__________________
04 G35c Sound Performance TT..Did I just make 650rwhp on pure pump? Yes I did!
Very nice.
Enjoy the ride and break in the engine smoothly.
I'm sure it wont stay stock looking for long since you will
probably want to expose your FMIC more to lower your
AIT(Air Intake Temperature).
Welcome to the FI Club
__________________
Billhyco says R. E. V. U. P.-Remember Each Victim U Pwnd.
You can't go wrong with them.
Fabricate, Assemble, Tune or any combo of the three, I have to say they are at the top....
And oh, the car drives Exactly like stock. Just faster.
The Pro-EFI is quite impressive. The car responds just like stock, no misses, or bumps, or delays.
Tom
Quote:
Originally Posted by Shift__Z
Nice I've been hearing good things about SP...and I will need a turbo installed sooner or later
__________________
Great Build! So what are you going to push it to (psi speaking)? +1 on atleast a new front bumper to improve air flow to the FMIC. Looks like SP did an awesome job on the build and the tuning! Congrats!!!!
__________________
Go Turbo or Go Home!!//Cowboys 2012 Superbowl Champs//Phoenix Suns 2012 NBA Champs
Not sure on what the ultimate boost pressure will be. Thats up to Larry and Chris and the tuning of course...prob somewhere round 20psi (hopefully we can run that boost on E85 and save some $$ on race gas).
As for front bumper we've all scratched our head on this one.
I just don't like any aftermarket front clips....I actually like the newer sedan sport bumper that has the same openings as the coupe but also has an opening in the center under the license plate.
In the meantime we'll watch the AIT's.
Thanks
Tom
Quote:
__________________
btw how do you like that clutch so far(i am not very familiar)? maybe a little review.
The clutch has a learning curve thats for sure.
Southbend, and the TT Z32 guys say that as it breaks in it smooths out.
It has gotten better allready but 1 thing is for sure, it doesn't like idle rpms or slipping.
You have to give it some rpms and get off it as quick as possible. I don't like that the drivetrain is taking the abuse right now, but that should be going away...it only does this coming from a stop in first gear.
T
__________________
