Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Forced Induction > Shop Builds
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 05-01-2009, 02:35 PM   #1
Clint@Altered
Clint@Altered's Avatar
Arrow AAM Built: APS TT, STG II LB, AUTO - 450whp@13psi
Tom, a long time car enthusiast (Maserati fan) came to us stating that something was missing/just not right about his TT'd Auto 350Z Vert. Tom was right - the car was having some issues with its previous built motor that came with the car. One quick look and it was obvious the car had serious cooling issues. Got so hot it warped the heads .
Tom recently went through a double knee replacement!, so it was important to him that his Z was an easy to drive yet high powered summer car. Already well equipped with an APS TT, it was time to get his vert back on the road and running right. His block was salvageable, but a good set of heads were in order. A built block and a solid tune later, we had his 350Z right where he wanted it. Next up for Tom, a good boost controller and 500whp!
Details:
AAM STGII Longblock
- 9:0:1 JE Pistons
- Eagle Rods
- HKS Headgasket
- L19
APS Standard TT Kit (original kit)
- New AAM Feed and Return Lines
AAM Oil Pan Spacer
AAM Basic Fuel System (rails supplied by customer)
APS 3" Exhaust
APS DownPipes
UTEC w/ Map Sensor
Rotora BBK
13psi - Dip From TQ Converter
Clint@Altered is offline   Reply With Quote
Old 05-03-2009, 12:14 PM   #2
NA&CH
Old Z Back
NA&CH's Avatar
Chris Hendrickson nach350 nach350
Points: 4,506, Level: 42
Points: 4,506, Level: 42 Points: 4,506, Level: 42 Points: 4,506, Level: 42
Today's Activity: 11.5%
Today's Activity: 11.5% Today's Activity: 11.5% Today's Activity: 11.5%
Almost bought this car. It looks to be the same. NIce job guys.
Chris
__________________
www.SFZCC.com
I can haz Z back?
NA&CH is online now   Reply With Quote
Old 05-03-2009, 01:40 PM   #3
Cass007
Moderator
OT, Market, & FI
Cass007's Avatar
Points: 5,985, Level: 50
Points: 5,985, Level: 50 Points: 5,985, Level: 50 Points: 5,985, Level: 50
Today's Activity: 31.5%
Today's Activity: 31.5% Today's Activity: 31.5% Today's Activity: 31.5%
Clint - what size injectors is he running and is 13psi the stock wastegate spring? I was thinking more power for sure and wondering why only 451whp? Also, got a dyno vid, I would love a preview of what my APS downpipes and 3" exhaust will sound like.
__________________
No more VQ... I'm rockin' an LS2 ... Official member of VED club "VQ engine destroyer"
Diebold Autosport - Hills Garage - GM - Stillen - Tein - SPRacing - CiNcity - 5Ziegen - Defi - Acree - Wicked CAS - Mishimoto - Quaife - Toyo - ViPEC - Cusco - APS
Cass007 is offline   Reply With Quote
Old 05-03-2009, 02:35 PM   #4
SlideFox
SlideFox's Avatar
Points: 3,455, Level: 36
Points: 3,455, Level: 36 Points: 3,455, Level: 36 Points: 3,455, Level: 36
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
Send a message via AIM to SlideFox
Nice car, but tell him to get rid of that god awful intake manifold!!! < stock
__________________
Go Turbo or Go Home!!//Cowboys 2012 Superbowl Champs//Phoenix Suns 2012 NBA Champs
SlideFox is offline   Reply With Quote
Old 05-03-2009, 03:23 PM   #5
coachk
coachk's Avatar
Points: 3,733, Level: 38
Points: 3,733, Level: 38 Points: 3,733, Level: 38 Points: 3,733, Level: 38
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Quote:
Remember its a 5AT
coachk is offline   Reply With Quote
Old 05-03-2009, 05:42 PM   #6
rcdash
rcdash's Avatar
Points: 4,722, Level: 43
Points: 4,722, Level: 43 Points: 4,722, Level: 43 Points: 4,722, Level: 43
Today's Activity: 5.4%
Today's Activity: 5.4% Today's Activity: 5.4% Today's Activity: 5.4%
Congrats. As Coachk mentioned, power looks on target Cass for a APS TT on a 5AT (esp. without cams). He should be able to hit 500 around 15-16 psi. Also that DJ was uncorrected so difficult to compare. The dip in power is odd for the TC. Usually you get a sudden drop in rpms, not so much power, as fluid coupling occurs. In fact, power should jump a bit at that point. Is any part of the 5AT built?
__________________
build thread
rcdash is offline   Reply With Quote
Old 05-04-2009, 05:18 AM   #7
Jeremy@Altered
Well, with the 5AT if you have it on the dyno graph VS Speed it will show that rise and then a dip. If you have it on VS RPMs then it will show a loop in the graph.
The tranny was supposed to be built by SGP. It had new clutch packs in it and the VB and TC were done. The tranny felt really mushy and the TC locked up at different points and it was such a PITA to tune. One pull it would make 15 psi and the next it would make 12. I decided to give it back to him on the safe side until he wanted to invest in a boost controller instead of the already wired up Utec boost control.
Honestly, i am starting to like the Kinetix SSV. I know it has a bad rap on here but i have made some good numbers through it in the past couple years. You really just have to have the right combo for it to work right. Mike just made 276whp SAE on this NA reflash tune the other day on a 03 DE motor with the Kinetix SSV. I was very very surprised because that is the highest NA bolt on SAE DJ i have ever seen. I also made 630 with a Greddy kit through one on 17 psi before and it was a fun car to drive.
Jeremy@Altered is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
13psi, 350z, 450, aam, aps, auto, build, coach, drag, japan, jeremyaltered, my350z, toms, tt, whp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
