You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Forged Performance: Back from the dead with a complete motor and turbo rebuild....
As some of you know I had a little incident about this time last year with my stock block Greddy Twin Turbo '03 350z. Less than 2 hours after having a new boost controller (improperly) installed by a local shop in Dallas, my motor exploded when I went into boost sending shrapnel through both sides of my block, the heads, manifolds, turbos and downpipes, yes it was a complete loss.
So I made quite a few calls to multiple shops, local and across the country asked alot of questions and finally decided to give the job to none other than Forged Performance and shipped the car out to them in early March. I had hoped to get the car back before ZdayZ '09 but as with any big build project there were setbacks here and there plus I kept adding things along the way (because us OCD'ers like to do that sort of thing) but finally I flew out to ATL in September and drove her back home.
Despite the fact that it's been raining cats and dogs here in Texas I have had enough time in the car to say that I am very pleased with the way it runs. The car is a blast to drive just on wastegate boost (which is a little over 10.5 psi). At 15psi the thing is a rocket and it is difficult to find traction in the first 3 gears, even with 295 Yokohama AD08's. I also have as race gas fuel map and a high boost setting of 18psi and it makes hitting full boost an "oops I crapped my pants" moment every time. I guess the easiest way to sum it up is just to say "I like it alot!"
Here is the basic build sheet plus some before and after pics and dyno graphs.
Forged Performance Longblock:
Arias Zero Silicon AL EXTREME Duty Piston set 9.0:1 .020 overbore
Eagle Forged H Beam Beam Rod set VQ35 w/ ARP rod bolts
ARP Extreme Duty Head Stud Kit L19
ARP VQ35 Main Stud Kit
Cosworth Nissan VQ35 (3.5L) Rod Bearing Set-Tri Metal: STD
Cosworth Nissan VQ35 (3.5L) Main Bearing Set-Tri Metal: STD
Cosworth Thrust Bearings STD
FP S1 Shortblock Machining, Polishing Crank, Balancing Crank, and Assembling
Shortblock to our tolerances
HKS Metal Head Gasket 97mm
Nissan VQ35 350Z/G35 Rear Main Seal Retainer Assembly
Nissan VQ35 350Z/G35 Engine Overhaul Gasket Kit
Nissan OEM Rev-Up Oil Pump
JWT 350Z C2 Camshaft Set
JWT VQ35 Spring/Shim Kit VQ35
Labor: Dissassebly Cylinder Heads and set Valve Lash
Nissan VQ35 Rear Coolant Bypass System
Labor: Assemble Long Block
NGK-LFR7AIX Two Steps Colder Iridium
Carbonetics Triple Disc Carbon Clutch w/1350kg Pressure Plate
also...
Cosworth Intake Plenum
CJM Double fuel pump
CJM stage 2 fuel return system
HKS 1000cc injectors
Rebuilt GReddy TD05-18 G turbo's (x2)
Ceramic Coated SGP 3" Ceramic Coated Down Pipes
Tial 0.9bar Wastegate Springs
Forged Performance custom made Ceramic Coated W/G Relocation
and Open Dump Tube Kit
To complement the pre-existing HKS F-Con Vpro EMS we added the following...
HKS EVC 6 Boost Controller
HKS AFK Knock Amp/AFR monitor
HKS Nav-Pro
HKS Camp 2 which displays via a
Alpine IVA-W505 Headunit
Here is is my dyno from the original build it went Kaboom.
Sharif had to dyno the car on a Dynojet because of wheel spin secondary to my crappy Toyo Proxes 4 tires (the tire issue has since been addressed).
Here are the graphs from the dyno pulls I had done a few weeks ago. the last one is with a DynoJet correction, jsut to make me feel better about myself!
10.5psi 93 octane
15psi 93 octane
18psi VP Racing C16
18psi with DJ correction
__________________
'03 silverstone 350z, fully built Forged Performance Greddy TT with HKS Vpro EMS.
Now for the before and after pics, some of you guys have already seen many of the pictures in other threads but i thought I would compile them into this thread for continuity so here we go!
And here is here is the poorly installed Turbosmart E-boost2 that made my car crap the bed...
Now for some pics during the install.
My original VQ35de... RIP
And so the journey begins...
__________________
Sharif, Sandy, Ryan and Chris at Forged for a job well done and tolerating my OCD. LOL
Mike the Powder Coater http://www.thepowdercoater.com/ For the awesome brake caliper coating job
and Marc with Creative Candy Powder Coating for the top notch ceramic coating. (both Mike and Marc have quick turn around times).
chopr3522 from Ebay for selling me a usable longblock for next to nothing ($350.)
__________________
Thanks and so far I am a fan of the AD08's They have excellent lateral grip and braking in both wet and dry conditions (aggressive street driving) Havent tracked the car yet.
Quote:
Originally Posted by Motormouth
well done post.
Thanks, I'm a long time lurker and have been taking notes! LOL
__________________
Congrats OP and Sharif, yet another solid Forged build hits the streets .
Way to stick with it after massive fail, these cars are sooo much fun with F/I it should be illegal. Upon further thought, most of our cars are illegal
__________________ No more VQ... I'm rockin' an LS2 ... Official member of VED club "VQ engine destroyer"
