Shop Builds Temp moving posts for some clean up of this section.
The Build BEGINS! Gamermodz/GReddy/S&R Z goes under the knife!
Old 12-29-2010, 04:03 AM
  #141
0jiggy0
0jiggy0's Avatar
What are you doing for a front strut bar?
Old 12-29-2010, 05:54 AM
  #142
S&R Performance
Vendor - Former Vendor
S&R Performance's Avatar
I don't know yet, buddy.
and correct, we were not using BOV's before.
Old 12-29-2010, 08:43 AM
  #143
DWilks@TopSpeed
DWilks@TopSpeed's Avatar
Hey guys this is Doug from TopSpeed.
Just wanted to make a comment about those saying this car is laggy.
Its a common misconception when looking at high hp graphs that the car is laggy. It just appears to be laggy because of the high hp numbers being shifted to the right of the powerband. What everyone doesn't notice is that this car is making over 300ft/lbs of tq at 4k rpms, and over 500ft/lbs by 5k. Giving you a huge power band since the rev limiter is set at 8200rpms.
Just to show everyone what I am trying to say here is the Gamermodz 350's dynograph overlayed with a mild bolt on 350z. Notice that above 2800rpms the car is making more power.
Which one would you rather drive
Doug
Old 12-29-2010, 08:51 AM
  #144
Highway Riding
Highway Riding's Avatar
Alot of win going on here.. sweeeet
Old 12-29-2010, 08:56 AM
  #145
S&R Performance
Doug
Old 12-29-2010, 09:11 AM
  #146
rh_334
rh_334's Avatar
Why are the numbers in STD? Isnt SAE the norm?
Old 12-29-2010, 09:21 AM
  #147
RedlineHR
RedlineHR's Avatar
Silly noob question, but how are you gonna transfer that much power to the ground? I see the modded G diff - what are the details? Is it LS or welded? And what tires do you plan to run for track and street?
I would imagine that past a certain WHP number, any additional power is useless on a 2wd chassis unless it's heavily modded. Any plans or considerations for an AWD setup?
Congrats on an awesome feat of engineering regardless.
Old 12-29-2010, 09:57 AM
  #148
str8dum1
str8dum1's Avatar
Hey Doug, 300ft-lbs at 4000 rpms is laggy with a 4.2L and crazy heads!!! You are not comparing apple to apples.
typical 4.0L strokers with 60-1 sized turbos are making 500-600 ft-lbs at 4000rpms.
Doug
  #149
CRIDDA
CRIDDA's Avatar
Its in here somewhere. They do not plan on running it at high WHP. I think they said it will be tuned for @500whp for track use
Old 12-29-2010, 10:04 AM
  #150
03threefiftyz
03threefiftyz's Avatar
Bingo......any way you slice it that is laggy.
Old 12-29-2010, 10:10 AM
  #151
str8dum1
str8dum1's Avatar
there's nothing wrong with laggy, I guess I was just surprised that smaller turbos, +20% more displacement, and 37% more flow in the heads didnt left shift that curve much at all compared to 3.5L high powered cars (Sound performance, Injected, myself...)
Being a time attack car, I wouldnt think you'd want such and on/off power sweep inside a few hundred rpms.
Old 12-29-2010, 10:14 AM
  #152
rh_334
rh_334's Avatar
Old 12-29-2010, 10:21 AM
  #153
03threefiftyz
Correct. That spool up will make it impossible to keep the tires under the car. I do believe they are doing some type of traction control, but it will have its hands full to the max.
Old 12-30-2010, 02:19 AM
  #154
0jiggy0
0jiggy0's Avatar
Remember though hes had all that virtual Seat time.
Old 01-10-2011, 05:30 AM
  #155
GBoger
GBoger's Avatar
every time I see a thread with a dyno like this and the owner/shop promises that they have a trick that they haven't employed yet to shift the curve to the left and speed the spool up it never seems to materialize. That annoys me.
Old 01-10-2011, 05:37 AM
  #156
S&R Performance
we've got quite a few things done. Once we can get her back on the dyno, we're confident we'll see an improvement all across the band. Should do very well.
Old 01-17-2011, 06:07 AM
  #157
rh_334
rh_334's Avatar
Originally Posted by S&R Performance
Mod List as of right now!
Motor:
VQ35HR Stroked to 4.2L
Greddy Twin Turbos (Two 20G Turbos with larger compressor wheels) Ported & Polished
CP Pistons
Brian Crower Rods
Brian Crower Billet Crank
Ferrea 2mm over sized competition valves, springs and titanium retainers
Ported, Polished and Reflowed Heads (Flowed 37% more than stock)
Engine completely balanced and blueprinted
Tomei Pro Cams
Block sleeved by Darton
Custom Designed 6061 T6 Aluminum Twin Throttlebody Plenum
All components have been Cryogenically treated in an SubZero Cryo unit
1600cc Injectors
What about Headstuds? L19s? I hope you just left them off the list
Old 01-17-2011, 10:41 AM
  #158
S&R Performance
we're actually doing some custom work right now and yes, L19's are in the motor.
Old 01-26-2011, 05:31 AM
  #159
GBoger
GBoger's Avatar
anything?
Old 01-26-2011, 05:33 AM
  #160
S&R Performance
we should be back at Top Speed for Doug's magic tuning some time next weekend or something. We've just been VERY busy at the shop.
Quick Reply: The Build BEGINS! Gamermodz/GReddy/S&R Z goes under the knife!
