Z-Fever builds 500whp SR20DET 350Z w/ drive-by-wire
We just started a really cool build. We had a customer bring us an 03 350Z and he wants a truly unique set up. It is getting an S14 SR20DET. We are fully building the engine, making a top mount manifold (custom) with a Garrett 3076 (GT30R) turbo and 850cc inj's. our goal is to do something no one has done before though. We are keeping the OEM drive by wire set-up from the 350Z and running a dual ECU set-up. This will allow us to manage the engine as well as to maintain the VTC, traction control, cruise control, and all factory gauges. The S14 ECU does not run can-bus but the 350Z's does. This is a cool build. I hope you like it.
Here are the pics as it is coming together. I will add pics as the build continues.
and here are all the parts we are using to build the engine:
850cc injectors
New OEM S14 oil pump
New .20 over CP pistons
New HKS 264 step 2 camshafts
New Supertech performance spring and retainers
New Cosworth 87mm x 1.1mm metal head gasket
New SCAT forged rods
New ARP head studshttp://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc7/301868_10150373688798296_296402898295_9772422_5538780_n.jpg[/img]
New ARP main studs
The engine has been sent out, hot tanked, bored .20 over, and honed. The crank was polished and balanced.
The head has been completely reconditioned and the new springs, retainers, and cams are installed.
And of course, this is the heart of it all... the Garrett GT30R (3076) fully ball bearing beast. This power plant should make an easy 500whp on pump gas.
I know that some people will not like this build because we have taken out a perfectly good running VQ35 that we could have boosted and made 400whp or built and gotten more than 600whp. All true, but we have done 100 350Z's just like that. This is something unique that you won't see 50 of at a car show. And the way we are doing it is truly inspiring. I don't think anyone has maintained all the OEM functionality of the gauges and drive-by-wire.
I hope you like it.
Here are pics of the engine build:
Installing the Supertech springs and retainers
The powder coated S14 valve cover. It is polished then black satin coated
Now we are putting the bottom end together with all new pistons, rings, main bearings, rod bearings, ARP's and metal head gasket:
New performance oil pump gears:
Then we installed the front timing cover:
Then we installed the ARP head studs, Cosworth head gasket, and cylinder head. Along with in the intake manifold, valvecover, and custom made exhaust manifold:
Here are the engine mounts we made for this build:
And here is what the engine looks like in the car
Here is the VQ35 drive-by-wire throttle body installed onto the S14 intake
We are using a Greddy VSPL front mount intercooler and have it mounted already
We started making the turbo manifold today. Using T304 stainless 1/2" flange we made and schedule 10 T304 stainless bends
We went ahead and threw my ITS T72 on it just so we can see how cool it looks.
We finally got the SR20 started and all the gauges, drive-by-wire throttle body, speedo, cruise control, VTC, etc... works 100%. The only thing we still need to do is install exhaust, coolant, a couple hoses, bleed the cooling system, and make the tach work. We will have to make a timing trigger and feed that signal to the VQ35 ECU. She is almost finished....
Here are some pics of the engine, the new custom manifold, the GT30R turbo, and piping.... All black ceramic coated exhaust side and black crinkle coated intercooler piping. Our customer wanted a very clean and stock looking appearance.
We are running our own ROM board and tuned SR20 ECU as well as the OEM 350Z ECU.
Here are a few pics of the engine as it went in and as we wrapped up all the piping.
Enjoy the video (pay attention to the throttle body) ...
BTW... this is just the initial start up...
http://www.youtube.com/watch?v=0ikTn0FYf4c
This one is after working out the bugs....
http://www.youtube.com/watch?v=9GNJSFW5DTc
http://www.youtube.com/watch?v=lZLdcgmWlP0
http://www.youtube.com/watch?v=XNMA9Kv1ch8
I hope you enjoyed it and find it interesting... We can do this with just about any engine. If you have any questions you can ask me here. Or you can contact us at 813-877-7600.
Be sure to find us on facebook also
www.facebook.com/zfever
<table summary="table" class="tborder" style="margin: auto;" align="center" width="1" border="0" cellpadding="6" cellspacing="1"><thead><tr><td class="tcat" colspan="2">
</td></tr></thead><tbody><tr><td class="alt1">
</td></tr></tbody></table>
850cc injectors
New ARP main studs
I hope you like it.
on
what does an engine build on an sr20 cost? i have a few friends with them running high hp and i thought they said it was way cheaper than what i spent on my vq35 to be built.
i like the way it looks. Very strong engines too.
It is a bit cheaper than a VQ35, after all...there are 2 less rods and pistons. But everything else is similar. It is about $4k depending on what brands you choose for your components. We charged this customer $1500 labor + parts and machining to build this engine. We normally charge $2k to build an engine.
The tach worked perfectly when we finished it. First video we didn't have the timing trigger machined properly we had done it by hand just to see if it would work.
The car is a blast to drive! very nimble and well balanced. The customer uses this car as a DD and has big plans for wheels, body, and paint...
