Berk HFC -Test pipes, DeatschWerks injectors and Mishimoto Radiators,Fans, Rad Caps!!
Hello Guys,
Check second post for Injen intakes offered and 3rd post for Royal Purple Motor Oil.
We are a Authorized STOCKING dealer of Berk Technology.
Berk Techology High Flow Cats
Metallic substrate spun catalytic converters, OBDII & 49 state compliant. Full stainless steel construction. Metallic substrate offers higher flow and lighter weight. Uses advanced spiral wound ultra thin foil. Includes our custom made soft crush graphite collector gaskets for a leak free seal. Made with pride in the USA
Nissan 350Z 03-06 Application Please pm me for best pricing
Nissan 350z 07-08 350z/370z Application Please pm me for best pricing
In stock guys ready to ship:
Berk Test pipes: 03-06 350z and 07-08/370z 350z kits offered:
Berk resonated test pipes. 03-06 350z and 07-08/370z 350z kits offered:
B2autodesigns offers Gates Racing Micro V Accessory Drive belts
As with all Gates Racing Performance Products, Micro-V belts are designed and built to satisfy the tuner demand for reliability. The extra strength comes from a high-modulus, low-stretch polyester tensile cord. The belts are constructed from a patented EPDM compound that has three times the heat resistance and durability of standard belts. That's why they last three times longer
They are colored blue.
Fits: 03-06 350z
$79.95 shipped in side USA includes both drive belts.
Package deal. Gates drive belts (both belts) and NGK Iridium plugs x6 shipped $129.95.
Borla stainless steel headers: In stock!!!
Borla stainless steel headers for the VQ35DE powered 2003-2006 Nissan 350Z full stainless steel construction, with thick flanges and all the necessary hardware and gaskets for a easy bolt-on installation. And because these headers are made by Borla, they are backed by a million-mile warranty; guaranteed to be on the only headers you will ever have to buy for your Z car.
Also have DC Sports Headers in Stock . Message me for best pricing.
K&N's replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. K&N filters are custom designed to fit into your factory air box for simple, easy installation. K&N stock replacement air filters for street vehicles are covered by a Million-Mile Limited Warranty. K&N Filters use oil to provide filtration.
NGK Iridium Spark Plug
Check link for pricing:
http://www.b2autodesigns.com/index.php?cPath=17_560_562
Guys we also offer DeatschWerks injectors:
DeatschWerks Nissan G35/350Z VQ35 / Maxima VQ35/VQ35dek 600cc, 750cc, 850cc and 1000cc Top Feed Injectors
DeatschWerks 350z & G35 fuel injectors are engineered to fit your OEM harness, fuel rail and manifold. Each set of 350Z & G35 DeatschWerks injectors is balanced within 2% variation, making them easy to tune. This means better fitment, easier tuning, and increased reliability. DeatschWerks injectors are backed by a comprehensive 12-month warranty. Deatschwerks performs flow balancing and quality assurance testing on every set of injectors they produce, ensuring that the end product is top-notch. Deatsch Werks injectors are tested and analyzed at over 40 data points on DW's in-house New Age Technologies injector flow bench. DeatshWerks VQ35DE injectors are 100% new Denso manufactured units, you can rest assure that you are receiving a top-quality, reliable, well-performing product at a price that is hard to pass up.
We also offer the DW 320lph fuel pump w/install kit.
Message me for best deals.
Walbo 255lph In-take Fuel pump $79.95 shipped
Injector Dynamics: Message me for pricing.
Mishimoto Cooling parts FREE SHIPPING ON ALL MISHIMOTO PRODUTCS
We have the following parts in stock from Mishimoto parts
Nissan 350Z Performance Aluminum Radiator 2003-2008
The Mishimoto performance aluminum radiator for the 350Z is designed and engineered to maximize cooling efficiency by up to 30%, boost engine functions, and most importantly protect your car from overheating. Whether you drive your vehicle daily or take it for track runs. The Mishimoto aluminum Nissan 350Z radiator features a lightweight dual core, 100% brazed aluminum, and polished end tanks, enhancing the overall performance of your engine. Every Mishimoto aluminum radiator is a direct OEM fit, making installation effortless with no cutting or modification required, the ideal upgrade to the stock Nissan 350Z radiator. All Mishimoto radiators come with a high pressure 1.3 bar Mishimoto radiator cap and a great warranty.
Nissan 350Z Performance Aluminum Fan Shroud, 2003-2006
Nissan 350Z Silicone Radiator Hose Kit 2003-2006
Nissan 350Z Silicone Radiator Hose Kit 2007-2008
Offered in Red, blue and Black:
Mishimoto silicone Nissan 350Z radiator hose kits are made with a dual layer combining high grade silicone and heat-resistant embedded fibers to provide efficient heat reduction and increased pressure tolerance, all with an OEM replacement fit!
Mishimoto Oil Cooler:
Mishimoto bolt on Oil cooler kit for 350z/370z in stock.:
Rows: 10
Core: 11.81" x 5.31"
Thickness: 1.97"
Braided Hoses: 4ft .75 inch 4ft 9 inch
Braided Hose Fittings: 10AN
Sandwich Plate Screws: -8AN
Mishimoto has released a carbon fiber oil catch can. These units come with all necessary hardware
Also new Flat black finish:
Mishimoto Aluminum Oil Catch Can - Small or large.
Mishimoto Aluminum Coolant Reservoir Tank
Mishimoto Aluminum Power Steering Reservoir Tank
Weapon R catch can and coolant can. 18 or 24oz in stock. Message me.
Weapon R 03-06 350z Aluminum Coolant Overflow Tank.
Weapon R 03+ Nissan 350Z/ G35 Power Steering Reseroir Tank.
B2autodesigns would like to introduce our new 1pc bolt on wheel spacers for the Nissan/Infiniti application. These are high quality with a great price for G35NY members.
Features:
Material: Aluminum/Magnesium alloy
Bolt-on design
Easy Installation
Hub centric (66.1) to Nissan/Infiniti
1pc design
Incredibly strong and very lightweight
Sizes offered. 15, 20 and 25mm
At this time we only have the 15 and 20mm kits ready to ship. 25mm are about 3-4 weeks out.
Price shipped to lower 48 states.
per a kit is $113.95.
Two kits (4 spacers) $220.00.
Link to order:
http://www.b2autodesigns.com/index.php?cPath=45_48_1052
International customers please pm me or call us 813-787-4075 for pricing. These are in stock and will ship right away. Please pm me with any questions you might have.
Customer feedback:
Please message me or call the shop 813-787-4075 with any questions.
Thanks
Charles
Fits: 03-06 350z
Rows: 10
Thickness: 1.97"
Features:
Bolt-on design
Easy Installation
1pc design
Link to order:
Customer feedback:
Thanks
Charles
We stock Royal Purple Motor Oil. We do a pacakge w/Filters. K&N, HKS and Royal Blue Filters. You can order by the case or qt.
Link for pricing: Royal Purple HPS (High Performacne Street) Oil.
http://www.b2autodesigns.com/index.p...h=17_1087_1089
Link for pricing: Royal Purple Muilt-grade.
Message me with any questions.
Thanks
Charles
Thanks
Charles
Guys these are available to ship.
Berk Nissan 07+ 350Z/G37/G35, 09+ 370Z Test Pipes Our highly anticipated 2007-up test pipes are now available! Features fully gusseted and plated support brackets, the strongest in the industry. Includes the same leak free soft crush graphite collector gaskets found in our 07- up HFC's and secondary O2 sensor bungs for wideband tuning or AF monitoring. Plugs included when not in use. Mechanical CEL fix included,
Price shipped inside USA $320.00
Link to order:
http://www.b2autodesigns.com/product...oducts_id=2400
Link to order:
Join us on Facebook: Always got deals going on!!!
https://www.facebook.com/#!/pages/B2...s/165793298063
Thanks
Charles
Thanks
Charles
