Hola soy nuevo (help)
Old 12-04-2016, 03:01 PM
laz2390
laz2390's Avatar
Unhappy Hola soy nuevo (help)
hola soy nuevo en el forum del Z,
estoy teniendo el siguiente problema con el Z que compre,
cuando el tanque de gasolina ya esta vacío que voy a echarle,
cuando pasan los 10 Dólares , me bota la gasolina por arriba del tanque y se bota
(obviamente por debajo del carro) alguna idea que podrá ser? la junta oh algo?
muchas gracias.
Old 12-04-2016, 07:02 PM
rearranged
rearranged's Avatar
¡Si!
Old 12-05-2016, 03:40 AM
Received 9,046 Likes on 6,512 Posts
english would help
Old 12-05-2016, 06:01 AM
ivanorcan
ivanorcan's Avatar
muchas gracias.
Got to help translating:
"Hi, Im new at the Z forums,
Im having the following problem with the Z i bought,
when the gas tank is empty, i go to the gas station to full it up,
but when it goes over the 10 Dollars, the gas starts spilling from over the tank and falls underneath the car, any ideas on what could be the issue?
Thanks"
laz2390 (12-06-2016)
Old 12-05-2016, 06:02 AM
filler neck issue...
https://www.google.com/search?q=fill...hrome&ie=UTF-8
Old 12-05-2016, 08:32 AM
Legacy406
Legacy406's Avatar
Received 3,273 Likes on 2,574 Posts
Someone get QS in here!
Old 12-05-2016, 05:12 PM
laz2390
laz2390's Avatar
Default thanks
thanks for trying to help =]
Old 12-06-2016, 05:51 AM
laz2390
laz2390's Avatar
Originally Posted by travlee
ithe issue that in having is that i can only put 1/4 of gas after that , fuel started pouring out of the car, right in between the passenger side rear wheel, and edge of the door. i did replace the fuel pump, and just got today the O-ring from the dealer to see if thats the problem i do get lots of fuel smell " the more i hit the gas pedal of course" so you really think it might be the filler neck?
Old 12-06-2016, 06:15 AM
PerfZ
PerfZ's Avatar
There was a recall to replace the filler neck but I believe that is because they were leaking. The difficulty in filling was a somewhat common but spotty issue in the early models - my '03 never had it and as far as I know, no true cause was ever determined.
Old 12-06-2016, 08:05 AM
mignav01
mignav01's Avatar
Existe la posibilidad de que su cuello de llenado de combustible tenga una mala fuga después del punto de corte
Old 12-06-2016, 08:10 AM
laz2390
laz2390's Avatar
pero al momento de echarle gasolina no bota nada,
lo hace despues cuando llega a 1/4 mas o menos es que empiesa a botar la gasolina en cantidad... [ mi pregunta si tuviese un hueco, oh algo roto no lo botaria al momento de echarle la gasolina y no después? ya que eso va directo al tanque no?
kind of bad english translation lol
But at the moment of putting gasoline he does not throw anything,
It does later when it reaches 1/4 or so then it starts to throw a lot of fuel down ... [my question if It has a hole, or something broken shouldn't it spill the fuel at the moment? not after it reaches 1/4
Old 12-06-2016, 10:26 AM
mignav01
mignav01's Avatar
Not sure if you want English or spanish, so I'll reply in English for now. But it's possible that there's a hole around the 1/4 mark, and it simply doesn't spill right away when fuel runs through it. But rather until it fills up to that point?
Old 12-06-2016, 10:31 AM
laz2390
laz2390's Avatar
after work im going to replace the O-ring of the tank since i replace the fuel pump, i will keep in touch, hopefully i don't have to change the tank
Old 12-06-2016, 02:06 PM
zakmartin
zakmartin's Avatar
Vapor Canister Purge Valve. Go with an OEM part if you can. Dorman sucks.
Old 12-09-2016, 12:32 PM
StuLax18
General & Tech Moderator
StuLax18's Avatar
Received 3,339 Likes on 2,379 Posts
zakmartin (12-09-2016)
