FS: KW Variant 3 coilovers, Hotchkis sways, Injen CAI, K&N Air Fliter, Ichiba spacer
Old 04-15-2014, 11:12 PM
plastiketa
plastiketa's Avatar
Default KW Variant 3 coilovers, Hotchkis sways, Injen CAI, K&N Air Fliter, Ichiba spacer
Up for sale is a used set of KW Variant 3 coilovers for 03-07 350z. PRICE: SOLD!
It should fit G35s of the same years, but please check before purchasing. Used for about 40k miles, tracked once, casual use all other times. No leaks, good condition with minor wear, but before uninstalling, still felt and responded great! The plastic cover on one of the rear coilovers was crack during install, but it still works fine
Hotchkis sway bars for 03-07 350z. Price: SOLD!
Also have an Injen Cold Air Intake, a K&N Air Filter, and Ichiba Wheel Spacers for sale!
plastiketa is offline
Old 04-15-2014, 11:31 PM
plastiketa
plastiketa's Avatar
Default Injen Cold Air Intake & K&N Air Fliter
Up for sale is an Injen Cold Air Intake for 03-06 350z. Price: SOLD! May fit G35s of the same year, but please check before buying. Used for about 50k miles. Great condition with minor wear. Comes with the Injen air filter. I eventually switched to the K&N air filter below.
K&N Air Filter used in combination with Injen Air Filter. Price: SOLD!
Switched to this filter when I converted the cold air into a short ram air. Reusable air filter that is easy to clean. Whole system sounded great!
Specs from website:
Part RC-4630 Product Specifications
Product Style: Round Tapered Universal Air Filter
Air Filter Shape: Round Tapered
Base Outside Diameter: 5.5 in (140 mm)
Top Outside Diameter: 4.5 in (114 mm)
Flanges: 1
Flange Inside Diameter: 3.5 in (89 mm)
Flange Length: 1.25 in (32 mm)
Flange Type: Centered
Height: 6.5 in (165 mm)
Filter Material: Cotton Gauze
Top Style: Metal
Top Material/Finish: Chrome
Package Contents: 1 Air Filter
Package Quantity: 1
Filter Re-Oiling Amount: 1.45 oz (43 ml)
Weight: 1.3 lb (0.6 kg)
Old 04-16-2014, 12:15 AM
plastiketa
plastiketa's Avatar
Default Ichiba Wheel Spacers; 20mm & 25mm
Up for sale are Ichiba Wheel Spacers; one pair is 20mm, the other is 25mm.
Good condition with minor wear. Price: SOLD.
Old 04-16-2014, 02:50 AM
AdvanZ33
Senior Super Moderator
AdvanZ33's Avatar
Move to local Marketplace for pick-up only.
AdvanZ33 is offline
Old 04-16-2014, 02:51 AM
AdvanZ33
AdvanZ33's Avatar
Also, I don't think the front suspension is KW V3 with the lack of side tanks.
AdvanZ33 is offline
Old 04-16-2014, 05:51 AM
gonzalo_300zx
gonzalo_300zx's Avatar
Front appears to be V2's and rears are V3's
gonzalo_300zx is offline
Old 04-16-2014, 07:38 AM
plastiketa
plastiketa's Avatar
All four are V3s. The first version didn't have side tanks in front. I'll take a picture of all four tags and post soon.
Old 04-16-2014, 08:21 AM
crazyjeys
crazyjeys's Avatar
Pm sent on sways.
crazyjeys is offline
Old 04-16-2014, 08:58 AM
AdvanZ33
AdvanZ33's Avatar
Didn't know that, thanks. Did the older version not have dampening adjustment as well?
AdvanZ33 is offline
Old 04-16-2014, 09:03 AM
AdvanZ33
AdvanZ33's Avatar
Moved to your local Marketplace.
AdvanZ33 is offline
Old 04-16-2014, 09:07 AM
AdvanZ33
AdvanZ33's Avatar
Moved to your local marketplace since you want local pick-up on all your other items. If you decide you want to ship, please include a date on your verification slip and I will move the thread to the General Marketplace. GLWS.
AdvanZ33 is offline
Old 04-16-2014, 12:42 PM
plastiketa
plastiketa's Avatar
Sure does! I loved this setup!
Old 04-16-2014, 12:47 PM
tukeeg35
tukeeg35's Avatar
Hey bud, do you have the cleaning kit for the K&N filter? What are the filters dimensions?
tukeeg35 is offline
Old 04-16-2014, 12:54 PM
plastiketa
plastiketa's Avatar
The filter didn't come with a cleaning kit. Here's the specs from the website.
Flanges: 1
Top Style: Metal
Package Quantity: 1
Old 04-16-2014, 09:24 PM
gonzalo_300zx
Ahhh did not know that either.. Thanks..
Old 04-17-2014, 07:52 AM
plastiketa
plastiketa's Avatar
Sale pending for the sway bars. Coilovers still available!
Old 04-17-2014, 12:47 PM
plastiketa
plastiketa's Avatar
Update:
- Sway Bars have been sold
- Pending for Spacers
All other items are still available! I'll be posting an authentic Veilside V1 polyurethane lip soon (03-05 version).
Old 04-17-2014, 01:37 PM
frankie350zgt
frankie350zgt's Avatar
condition and miles of kw v3s? where are you located
frankie350zgt is offline
Old 04-18-2014, 11:19 AM
plastiketa
plastiketa's Avatar
The KW have 40k on them. Condition is great as mentioned in the first post. Only thing worth mentioning is the crack in the plastic cover on one of the rear coilovers; it's pictured above. It's pretty much cosmetic and works fine as is
I'm located in north OC
Old 04-21-2014, 01:44 PM
plastiketa
plastiketa's Avatar
Monday bump!
Quick Reply: FS: KW Variant 3 coilovers, Hotchkis sways, Injen CAI, K&N Air Fliter, Ichiba spacer
