Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Marketplace > Vendor Classifieds > Suspension
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into My350Z.com, click logo to login
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Closed Thread
Old 05-06-2009, 05:01 PM   #1
Gruppe-S
MY350Z.COM Premium Sponsor
Gruppe-S's Avatar
Default KW V3_Free Cusco or SPC Upper Control Arms_Apexi EX-V $975
KW V3 Coilovers
Free Camber Control Arms
$2099 Shipped
***Please note: Cusco Control Arms are 'Negative' Upper A-arms, they will not adjust camber back to 0 degrees.***
Ohlins PCV
Spring Rates
10k/7k
Ride Height
20mm
$3000 Shipped
Apexi EXV Dampers
Super Affordable
The N1 ExV Damper is the newest edition to our high performance street line of coilover suspension. The Expert Type V (ExV) is a full coilover suspension featuring a threaded base for precise ride height adjustment without compromising shock or spring travel. We have taken our street suspension to the next level for 2005 by including high performance upper mounts and 32 way ride quality adjustment for street cars that are used at the track as well. The spring rates and internal valving of the ExV has been completely refined for excellent ride quality and sports driving. The ExV was designed to cater exclusively to US market vehicles. With this in mind, internal components have been specifically engineered to withstand harsher road conditions and increased wear caused by everyday street driving. The Expert Type V was developed based upon user requests for a high performance damper that doesn't carry a typical racing suspension price tag. This system stands as our commitment in providing our customers with the ultimate in quality and affordability.
$975 Shipped
Buddy Club Racing Spec Dampers
Buddy Club Racing Spec Damper is the perfect complete suspension kit with resemblance of P-1 racing damper's excellent designs while it is de-tuned for street - circuit use. However, the car specific pillow-ball upper mount design, proper spring rate, 15 level damper adjustment, and height adjustment capabilities accommodates driver's requests
$1450 Shipped
HKS Hipermax 3
Best Ride Quality
HIPERMAX III
Series Concept: Designed and tuned for street application / daily driving.
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
HIPERMAX III SPORT
Series Concept: Designed and tuned for competition / track.
The Hipermax III Sport series has firmer spring rates and valving to take advantage of the smoother, more consistent pavement of race tracks allowing quicker, more precise transient response and instant direction changes necessary in competition. In addition, the Hipermax III Sport incorporates HKS' all-new Hiper Linear Piston fluid-channel system, shock-body length adjustability (most applications) and ultra-thick chrome plating of the cylinder shaft for excellent durability and reduced stiction (static friction). Spherical bearings, for precise steering and feedback, are standard - but reinforced, rubber upper mounts are available for those seeking reduced vibration from less-than-smooth pavement.
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements.. As piston speed increases, dampening rate linearly increases.
• Pillowball upper mounts standard
• Monotube design
Hipermax III
$PM For Price
Hipermax III Sport
$Pm For Price
SPC Camber Kit
All Competitors Beat
The SPC Adjustable control arms you can finally tune camber and caster .
SPC Performance's new arm/shim kit has more than enough camber and caster change to correct cars that have been lowered, or for vehicles used in drifting, allowing for precise changes when fine tuning suspension alignment angles necessary when racing or drifting.
The hub and caliper shims extend out the center of the wheel making it possible for the forged and fabricated arm to make up to 5 degrees total camber change and กพ1.0กฦ degrees of caster change.
The SPC Rear Control Arms are the perfect kit for the lowered Z, whether you are looking at high performance, racing, lowered, or extreme applications.
This kit provides plenty of adjustment for camber and toe. With the adjustable EZ Arm?camber can be changed up to And the kit comes with a larger offset toe cam to bring the toe angle back into range.
Front Arms
$450 Shipped
Rear Arms
$235 Shipped
F&R Combo
$675 Shipped
Eibach Lowering Springs
1.2"/1.2" Drop
$250 Shipped
Tein Lowering Springs
S. Tech
.7"/.6" Drop
$250 Shipped
***Open Box Display Sale-1 Set Each in Stock***
H. Tech
.3"/.2" Drop
$250 Shipped
Tanabe Lowering Springs
NF
1.2"/1.2" Drop
$195 Shipped
GF
1.0"/1.2" Drop
$195 Shipped
__________________
20521 Teresita Way, Lake Forest CA 92630 Phone: 949-457-1234 Fax: 949-457-8000
email: sales@gruppe-s.com paypal:payments@gruppe-s.com
Ca Residents Please Add 7.75% Sales Tax
Gruppe-S is offline
Old 05-07-2009, 10:17 AM   #2
Gruppe-S
Gruppe-S's Avatar
Bump Guys
Maxim.com Girl of the Day
__________________
Gruppe-S is offline
Old 05-11-2009, 12:04 PM   #3
Gruppe-S
Gruppe-S's Avatar
Bump Guys
Maxim Girl of the Day
__________________
Gruppe-S is offline
Old 05-12-2009, 10:49 AM   #4
Gruppe-S
Gruppe-S's Avatar
Bump Guys
__________________
Gruppe-S is offline
Old 05-13-2009, 10:27 AM   #5
Gruppe-S
Gruppe-S's Avatar
Bump Guys
__________________
Gruppe-S is offline
Old 05-14-2009, 12:42 PM   #6
Gruppe-S
Gruppe-S's Avatar
Bump Guys
__________________
Gruppe-S is offline
Old 05-15-2009, 10:47 AM   #7
Gruppe-S
Gruppe-S's Avatar
Bump Guys
__________________
Gruppe-S is offline
Old 05-18-2009, 12:39 PM   #8
Gruppe-S
Gruppe-S's Avatar
Bump Guys
__________________
Gruppe-S is offline
Old 05-20-2009, 11:28 AM   #9
Gruppe-S
Gruppe-S's Avatar
Bump Guys
__________________
Gruppe-S is offline
Old 05-21-2009, 11:28 AM   #10
Gruppe-S
Gruppe-S's Avatar
Bump Guys
Maxim Girl Of The Day
__________________
Gruppe-S is offline
Old 05-22-2009, 10:33 AM   #11
Gruppe-S
Gruppe-S's Avatar
Bump Guys
__________________
Gruppe-S is offline
Old 06-01-2009, 01:05 PM   #12
Gruppe-S
Gruppe-S's Avatar
Maxim.com
Today's Girl
__________________
Gruppe-S is offline
Old 06-03-2009, 12:24 PM   #13
Gruppe-S
Gruppe-S's Avatar
Bump
Today's Girl
__________________
Gruppe-S is offline
Old 06-03-2009, 06:01 PM   #14
sektor 11
sektor 11's Avatar
what are the spring rates on the v3 and what would shipping be to 45002?
__________________
cause you're not cool unless you have a signature. http://race-ready.blogspot.com
sektor 11 is offline
Old 06-04-2009, 11:38 AM   #15
Gruppe-S
Gruppe-S's Avatar
They are progressive springs but the specs are around,
Front: 485lbs to 525Lbs
Rear: 240Lbs to 548Lbs
__________________
Gruppe-S is offline
Old 06-04-2009, 02:04 PM   #16
DC350ZTrack
2004 Nissan 350Z
DC350ZTrack's Avatar
Do you carry Cusco Zero 2 coilovers? Price shipped to 20906? Thanks!
DC350ZTrack is online now
Old 06-11-2009, 11:07 AM   #17
Gruppe-S
Gruppe-S's Avatar
Maxim.com
Today's Girl
__________________
Gruppe-S is offline
Old 06-19-2009, 04:22 PM   #18
Gruppe-S
Gruppe-S's Avatar
__________________
Gruppe-S is offline
Old 07-14-2009, 10:58 AM   #19
Gruppe-S
Gruppe-S's Avatar
__________________
Gruppe-S is offline
Old 08-07-2009, 12:19 PM   #20
Gruppe-S
Gruppe-S's Avatar
Bump Maxim Girl of the Day
__________________
Gruppe-S is offline
Closed Thread
Tags
arm, control, rust, shaft, spc
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ฉ2002 - 2008, MY350Z.COM All Rights Reserved.
