You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Description:Hotchkis Tuning Sport Sway bars improve your handling and reduce body roll. Turn in with confidence and late brake in the corners with our track tested lightweight hollow sway bars. Sway bar sets include front and rear bars, greasable bushings, and brackets.
Specs:
Front 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs) 4 Position Adjustable
Rear 15/16"(24mm) Tubular(bar weight 5.5lbs) 3 Position Adjustable
Bar Rates: 350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
06 G35 Front
Hole 1 = 1525 lbs/in (5% Softer than stock)
Hole 2 = 1845 lbs/in (15% Stiffer than stock)
Hole 3 = 2270 lbs/in (42% Stiffer than stock)
Hole 4 = 2855 lbs/in (78% Stiffer than stock)
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock)
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
Fits Models: 03-07 Nissan 350Z, 03-07 Infiniti G35 (WILL NOT WORK ON G35X)
I know these are generally sold in sets, but are you guys willing to sell just a front? Need it for SCCA BS competition (SCCA only allows a front replacement)
