For those seeking the ultimate in suspension mods for the Z and G, we proudly offer these Whiteline urethane bushings. Each bushing set is complete, and enough for 1 car. These have been on backorder for months, and just came back into stock today...and already we sold a bunch. Grab yours before they disappear again!
Some FAQ's about these bushings:
What are the benefits of fitting WHITELINE PLUS polyurethane bushings throughout my vehicle?
Enhance suspension geometry retention
Provide crisp responsive handling
Optimise braking capacities
Reduce suspension serviceability
Improve tire performance & tyre wear
Rectify or optimise wheel alignment settings
Enhance vehicle cornering stability
Resistant to ultraviolet, ozone, acid, grease & water
How do you know when your suspension bushings are worn out?
Poor wheel alignment
Poor steering response
Poor Tire wear
Shuttering under braking, even after replacing rotors and pads
What is the core difference between WHITELINE PLUS polyurethane bushings and rubber suspension bushings my car came with?
WHITELINE PLUS features:
Mechanical fit
Unrestricted rotational movement - free pivoting bushing
Shell bushes - centre sleeve not bonded
Rubber
Compression fit
Restricted rotational movement
Shell bushes - centre sleeve bonded
[img]http://www.z1auto.com/images/whitelinebushin*****.jpg[/img]
Front Bushing Locations:
WHITELINE PLUS Control Arm Bushings
• Enhance handling characteristics
• Provide a better steering feel and vehicle stability
• Induce more responsive braking
• Ride quality of softer rubber, with the performance of ultra firm polyurethane - durometer rating in the 70-80 range, whereas most firms urethane bushings are in the 100 range and up.
• In addition, Whiteline Plus polyurethane bushings are able to be bonded directly to the metal shell, which provide a method of flow control giving the bushing the characteristics of soft ride while on smooth roads, and when under cornering pressure cause the bushing to become firmer for improved suspension performance.
Inner Lower Control Arm - see above diagram, Position #2 - $61 shipped for the set (includes left and right front inner control arm bushings - enough for 1 car)
Inner Upper Control Arm (A Arm) - see above diagram, Position #1 - $78 shipped for the set (includes 4 bushings for left and right front A Arms - enough for 1 car)
Outer Control Arm/Lower Shock Mount - see above diagram (no numbered position), fits into lower control arm, where shock mounts to the arm -$53 shipped for the set (includes bushings for left and right control arm, outer position, where shock mounts to the arm - enough for 1 car)
Purchase the FRONT INNER/OUTER CONTROL ARM BUSHING SET for $105 shipped
Purchase the COMPLETE FRONT WHITELINE BUSHING SET for $169 shipped
All require a press for installation
Rear bushings - we have all the rear bushings in stock and ready to go as well! There are alot more for the rear than there are for the front, so best to contact us directly for those!
You can read a bit about them on our site:
http://z1auto.com/prodmore.asp?model...ng&prodid=3784
To order, just give us a call
Prices include shipping in the 48 states. For any other location, please pm or email us your full, complete address and we will get back to you asap.
We've also got the Whiteline Rear Subframe kit in stock as well!
Get rid of the sloppy, wallowing feeling in the rear by stepping up to Whiteline's new Traction Control Bushing Kit for the Z/G. This kit is sold complete only, and includes all new urethane bushings for the rear subframe mounts.
One of the most noticeable compromises in Nissan suspension performance is the 4 points on the rear subframe. The bushes are a very compliant hydraulic filled rubber bush that permits squirming of the rear end under bump/turn/acceleration. This kit features the latest technology WHITELINE PLUS polyurethane bushings, steel componentry and very informative install guide. The translucent black bushings boast voiding points so that elements of compliance is achieved. The kit replaces all 4 point of the rear cradle on a 350Z or G35 Infiniti and results in a more responsive, predictable and enjoyable driving ‘Z.’
Key Benefits of WHITELINE PLUS
-The quality of ride of rubber, with the performance of solid links.
-Long lasting durability.
-Resistant to chemicals, oils and weathering.
-Enhanced handling, steering response and road holding stability.
-Increased traction and power transfer.
Price is $143.00 shipped in the 48 states. Once again, this is sold as a full kit only!
Whiteline has also now released their new rear differential insert bushings! This new kit from Whiteline is a 4 piece urethane bushing kit which is designed to serve as a supplemental form of support for the rear pumpkin. Unlike the competition, these bushings do not require you to remove the stock units. Instead, they slip right on top and bottom of them, and form a tough urethane barrier between the front pumpkin mounts and subframe. This gives you the compliance and silence of the stock bushings, with the superior strength of urethane, all in one!
Priced at $65 shipped in the 48 states
Live outside the 48 states? No problem - just contact us with your complete address
Pricing Recap!!!!
Front Inner/Outer Lower Control Arm Bushings - $105 shipped in the 48 states
Front Complete Set is $169 shipped in the 48 states
Rear Complete Set is $435 shipped in the 48 states
Front and Rear Complete Set is $575 shipped in the 48 states
Front and Rear Complete Set Including Rear Subframe Kit is $695 shipped in the 48 states
Front and Rear Complete Set Including Rear Subframe Kit and Differential Power Bushing Set is $749 shipped in the 48 states
To order, just give us a call at (631)863-3820
Thanks!
