Get Yo Stance Right!!!!
Imported Performance is here to set up your stance and get your ride just how you like it with special my350z pricing!!!!
KW - Variant 1
TOO LOW TO POST!!!
The KW Variant 1 Coilover System is the ideal system for customers wishing to rely on the experience of our engineers for dampening yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety.
Features
* Optimally adjusted, sporty and comfortable dampening technology
* Inox-line stainless steel technology at no extra charge
* Individually height adjustable
* German TUEV-tested lowering range
* High-quality components for long life
* Comprehensive documentation for ease of use
KW - Variant 2 Coil Overs
TOO LOW TO POST!!!
The KW Variant 2 Coilover System is intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to one‘s own driving preferences.
Features
* Damping technology with individually adjustable rebound
* Inox-line stainless steel technology at no additional charge
* German TUEV-tested adjustment parameters
* Infinitely adjustable rebound damping
KW - Variant 3 Coil Overs
TOO LOW TO POST!!!
The new KW Variant 3 Coilover System is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers
Features
* Independently adjustable damping technology -rebound and compression damping
* Individual height adjustment
* 14- level adjustable compression damping
* Unique, independently functioning damping power adjustment
Stance GR+ Pro Coil overs -
TOO LOW TO POST!!! Shipped to the continental US
Built for the (03-08) Nissan 350Z... GR+ Pro coilover has all the features of the GR+ but adds the benefit of a helper spring. The helper spring allows the shock piston to be placed in the optimal position within the shock body, increasing rebound stroke, and maximizing articulation on cars with minimum suspension travel.Features:15-Way Damping Adjustable Camber Upper mount Pillow ball Upper mount Cold Wound Linear Spring Inverted Monotube Shocks Dust boot Aluminum Collars + Upper Mounts Height Adjustable Lower Bracket Helper Spring
HKS - Hypermax 3 and Hypermax 3 Sport Coil Overs
TOO LOW TO POST!!!
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS’ all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
In addition, the Hipermax III is shock-body adjustable (most applications) to allow vehicle height adjustment without affecting spring rate and piston stroke. With the Hipermax III’s range of adjustability, precise corner balancing can be achieved. Chrome-plated cylinder shafts provide excellent durability and newly-design rubber upper mounts reduce harshness. (For most applications, optional spherical bearing mounts are also available for enhanced steering feedback.)
Key Features
* Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
* Strengthened rubber upper mounts – enhanced durability
* Monotube design
* Shock-body length adjustable (most applications)
* 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
* Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
* 30-way adjustable dampening
* Hard chrome-plated cylinder shaft
* Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
* Pillowball upper mounts optional on certain applications
* Dustboots standard
* 1 year limited warranty
FREE SHIPPING TO THE CONTINENTAL US!!!
GO GO GO THIS CAN'T LAST LONG!!!
