You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Sway bars and tower braces!!! Must go!!! Lowest prices ever!!!
- Eibach Anti Roll Kit -
Anti Roll Kit
Front & Rear Bar
Complete your suspension upgrade with an Eibach Anti-Roll-Kit. While our Pro-Kit and Sportline spring sets are regarded as the primary suspension enhancement components, the Eibach Anti-Roll-Kit allows critical fine-tuning of your car´s handling characteristics.
Our Anti-Roll-Kit reduce body roll through increased design stiffness over stock bars. The result: increased handling and cornering grip in any performance-driving situation.
Manufactured from cold-formed, high-strength aircraft-grade steel for precision performance, and finished with a long-lasting red powder coat finish, the Anti-Roll-Kit comes complete with all necessary mounting hardware and instructions for easy installation.
Features
* Performance Tuned Handling
* Further Reduce Body Roll
* Precision Engineered for Pro-Kit & Sportline
* Part of the Eibach Pro-System-Plus & Sport-System-Plus
* Million Mile Warranty
Front Diameter 34mm
Front Style Tubular/Adjustable
Rear Diameter 22mm
Rear Style Tubular/Adjustable
GReddy Strut Tower Brace
Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. GREX Strut Tower Braces improve chassis rigidity and reduce this flex. By using a monocoque aluminum triple tube shaft and stout, easy-to-install steel base plates, high strength and rigidity are obtained without unnecessary weight gain.
ST Sway bar - Street Series Kit
COMPLETE SET
Need more Traction? Reduce your vehicle’s body roll and increase the gripping power of your tires with a set of ST Suspensions Anti-Sway Bars which are engineered to give you the best performance possible. ST’s cold formed solid steel anti-sway bars are powder coated for durability, and come complete with polyurethane bushings and all hardware needed for installation.
Progress Technology Front and Rear Sway Bars
Progress Anti-Roll Bars are cold-formed in-house using custom built precision bending equipment. Both laser-cut and CNC bar ends are MIG welded in place to ensure a precise fixture for exact fit.
* Reduced Body Roll Adds Driver Confidence
* Less Roll Means More Traction and Cornering Speed
* Polyurethane Bushings Produce Crisp Response on Turn-In
