Hotchkis Suspension Kits for 350Z!! MVP Motorsports
350Z Stage 1 TVS Kit
The Hotchkis Stage 1 TVS is an all inclusive kit that has been designed and tested as a system. No need to mix and match components. The Stage 1 TVS kit is designed to improve performance on daily driven vehicles while still offering a comfortable ride. Stage 1 kits include Sport Coils and Sport Sway Bars.
Sway Bar Specs:
Front 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs)
4 Position Adjustable
Rear 15/16"(24mm) Tubular(bar weight 5.5lbs)
3 Position Adjustable
Bar Rates:
350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
06 G35 Front
Hole 1 = 1525 lbs/in (5% Softer than stock)
Hole 2 = 1845 lbs/in (15% Stiffer than stock)
Hole 3 = 2270 lbs/in (42% Stiffer than stock)
Hole 4 = 2855 lbs/in (78% Stiffer than stock)
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock)
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
350Z Sport Coil Springs
Hotchkis Sport Suspension coils offer the performance you seek, and the comfortable ride you deserve. Made from cold wound silicon steel, our springs are linear rate, and are powder coated seabring silver.
Front Front 9/16" (15mm) Drop
340 lbs/in
Stock 310lbs/in
Rear 3/4" (19mm) Drop
330 lbs/in
Stock 350 lbs/in
Nissan 350Z / G35 Sport Sway Bars
Hotchkis Sport Suspension Sway bars for your Nissan 350 Z or Infinity G35 improve your handling and reduce body roll. Turn in with confidence and late brake in the corners with our track tested lightweight hollow sway bars. Sway bar sets include front and rear bars, greasable bushings, and brackets.
Specs:
Bar Rates:
06 G35 Front
Rear:
PM FOR PRICING!!
Regards,
Robert
EnjukuRacing
09-11-2015 08:30 AM
