SPC and Ichiba Camber Kits. BC BR Coilovers!!! - MY350Z.COM Forums
Thread Tools Search this Thread
Old 09-20-2011, 03:27 PM   #1
B2autodesigns
Vendor - Former Vendor
B2autodesigns's Avatar
Default SPC Camber correction kits. Package w/BC BR Coilovers!!!
Hello Guys.
Got these in stock ready to ship.
SPC Camber Kit
After lowering the ride height of your 350Z. Excessive negative camber can actually hurt your traction, tire wear and cornering performance. The complete SPC Pro-Alignment front and rear camber w/rear toe kits replace the limited stock alignment adjustment and let you fine tune the handling and traction characteristics of your car. Now you can set up your ride for any driving scenario, from the street to the strip and anything in between. These kits will NOT fit cars with active steering
Application we stock.
03+350z
09+370Z
Front kit Adjustment range: Camber: -2.5 degrees to +2.5 degrees.
Rear kit Adjustment range: Camber 4.00 degree Toe 3.00 degree
BC BR Coilovers package's
Check website for special pricing:
http://www.b2autodesigns.com/product...roducts_id=715
Mono-tube shock design
30 levels of damping force
Pillowball mounts and adjustable camber plates included*
Adjustable rear camber plates available
Separate Full length height adjustable
Inverted and Non-Inverted setups
One year warranty
Rebuildable
Technical
Coilovers use 46mm pistons and 53mm shock housings.
Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
Patented concave lower locking ring, to prevent unseating
Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
Iron lower brackets on MacPherson struts to ensure rigidity
Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
2 step coating process utilizing nickel and chromium plating to prevent corrosion
BR-Type:
BC BR coilovers with Swift spring upgrade.
BC BR true type rear coilovers:
Package BC Coilovers w/SPC Rear camber kit w/toe bolt shipped $1079.00
Please pm me with any questions you might have. Fast shipping as always
Thanks
Charles
B2autodesigns is offline   Reply With Quote
Old 09-22-2011, 07:56 AM   #2
B2autodesigns
The ISC coilover sleeves help protect your coilovers during harsh winter months. Sold as a pair. Two sizes 300mm and 370mm. Fits most coilover kit.
$59.95 shipped for a pair.
Link to more information and to order:
http://www.b2autodesigns.com/index.php?cPath=13_24_1367
Thanks
Charles
Old 09-24-2011, 07:41 AM   #3
B2autodesigns
Hello Guys,
Got these in stock ready to ship. Cool tool to add to the tool box or the trunk of your car.
Cusco has just released their new Smart Cross Wrench. Easy to use, extremely portable, yet effective at an affortable cost. The cross shaft becomes one piece, so no more clanking tools in the trunk! Made from long lasting durable material and used by Cusco's professional Rally team.
Size: 12 hex. 17mm , 19mm and 21 mm
Deep and short socket design
measurements: 400mm x 400mm
Weight: 900grams
torque capability: 450nm
material: Chrome molybdenum
Made in Japan
$64.99 shipped to the lower 48 states. Message me if you are International.
Link to order:
B2 Auto Designs
Thanks
Charles
Old 09-27-2011, 07:20 AM   #4
B2autodesigns
all pm sent
Thanks
Charles
Old 09-29-2011, 07:38 AM   #5
B2autodesigns
all pm sent
Thanks
Charles
Old 10-02-2011, 03:59 PM   #6
B2autodesigns
pm sent
Thanks
Charles
Old 10-02-2011, 07:48 PM   #7
justin4
justin4's Avatar
ichiba rear camber shipped 92707
justin4 is offline   Reply With Quote
Old 10-06-2011, 08:30 AM   #8
B2autodesigns
all pm sent
Thanks
Charles
Old 10-10-2011, 03:59 PM   #9
B2autodesigns
We are now offering these by them selfs. No need to buy the whole front kit.
Energy Suspension 350z compression rod bushing kit.
Link to order: $68.95 shipped this are in stock
http://www.b2autodesigns.com/product...oducts_id=5046
In stock!!
Old 10-13-2011, 03:43 PM   #10
B2autodesigns
all pm sent
Thanks
Charles
Old 10-13-2011, 03:56 PM   #11
ch1215g
price for the SPC full kit, front and rear to 07470
ch1215g is offline   Reply With Quote
Old 10-15-2011, 12:03 PM   #12
B2autodesigns
pm sent
Thanks
Charles
Old 10-15-2011, 12:36 PM   #13
chokee350z
How much for just the camber kits shipprd to 90703?
chokee350z is offline   Reply With Quote
Old 10-18-2011, 08:30 AM   #14
B2autodesigns
all pm sent
Thanks
Charles
Old 10-20-2011, 01:59 PM   #15
B2autodesigns
all pm sent
Thanks
Charles
Old 10-22-2011, 10:10 AM   #16
B2autodesigns
Plenty in stock ready to ship
Thanks
Charles
Old 10-25-2011, 01:17 PM   #17
B2autodesigns
all pm sent
Thanks
Charles
Old 10-25-2011, 01:20 PM   #18
ch1215g
rear kit shipped to 07470
both spc and ichiba
Old 10-26-2011, 06:02 AM   #19
Jon70ProofZ
Price Shipped to 37919 on both rear camber kits separately
Jon70ProofZ is offline   Reply With Quote
Old 10-29-2011, 02:23 PM   #20
B2autodesigns
pm sent
Thanks
Charles
Thread Thread Starter Forum Replies Last Post
Up to Date Coilover Review/Recommendations for a balance of track/drift/slam Lt_Ballzacki Brakes & Suspension 13 10-24-2015 08:56 AM
FS: BNIB SPL Parts For Sale!-Camber Link, Toe Link, Traction Link, Upper Control Arm 350Z Project X Suspension 9 10-10-2015 09:23 AM
FS: 1970's Custom HOTROD Radio Flyer "slammed & cambered" Rowlett Misc. 3 10-02-2015 10:38 AM
Tags
350z, bc, bolts, caber, camber, code, coilover, coilovers, coupon, ichaba, ichiba, kit, my350z, plates, rear, sti
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
