ModBargains.com | KW Coilovers Variants 1, 2 & 3 l Best Deals Period !!!
Old 02-15-2012, 09:51 AM
ModBargains.com
Vendor - Former Vendor
ModBargains.com's Avatar
Default ModBargains.com | KW Coilovers Variants 1, 2 & 3 l Best Deals Period !!!
ModBargains.com is proud to present to the G35/G37 community KW Coilovers Variants 1,2 & 3 !!!
Call in today for the ABSOLUTE LOWEST PRICE on all KW Coilovers. Give me a call at (714) 582-3330 ext 8003 or ask for Frank for the special price !!
Applications:
  • 350Z (Z33) Coupe + Convertible 03-09
  • 370Z (Z34) Coupe + Convertible 09+ **
  • G35 Coupe 2WD (V35) 03-08
  • G37 2WD 08+ **
** = KW V2 N/A
About KW Coilovers
Is your Vehicle looking a little too high? Do you still feel insecure about the sharp turns you attempt around the corners? Is your current body kit not doing the job of creating that AGGRESSIVE appearance? Treat your vehicle and yourself with the best suspension system out there--KW's Coilovers! Not only does this system lower your car perfectly, but it provides HUGE performance benefits.
KW designed and manufactured every coilover to CUSTOM fit your vehicle, unlike other coilovers that may be a "special one-coilover-fits-all", guaranteeing MAXIMUM handling and performance for your vehicle. Along with handling, this system makes sure your car is given a perfectly AGGRESSIVE stance, not a vehicle that's touching the floor. Maybe you're not the one for aggressive looks and ultimate performance, but for comfort. Well, KW took that into consideration, and integrated adjustable comfort technology.
KW is known for their signature colors, individuality, quality, and security. Take a look below to read more into which KW Coilover Variant is the BEST option for you!
KW Variant 1
Sportive - Harmonic with KW factory pre-set up dampening
The ideal systems for customers wishing to rely on the experience of KW engineers, yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety.
- Optimally adjusted, sporty and comfortable dampening technology
- inox-line stainless steel technology at no extra charge
- Individually height adjustable
- German TUEV-tested lowering range
- High-quality components for long life
- Comprehensive documentation for ease of us
KW Variant 2
Sporty and Personalized with adjustable Rebound Dampening
The system intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to one‘s own driving preferences.
- Damping technology with individually adjustable rebound
- inox-line stainless steel technology at no additional charge
- German TUEV-tested adjustment parameters
- Comprehensive documentation for ease of use
- Infinitely adjustable rebound damping
KW Variant 3
Race Technology for the Road with: Adjustable Compression Rebound Dampening
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the high speed set-up, so decisive for driving comfort, has been preset by our engineers
- Independently adjustable damping technology -rebound and compression damping
- Individual height adjustment
- 14- level adjustable compression damping
- Unique, independently functioning damping power adjustment
What are Coilovers?
A coilover suspension basically gives you a matched lowering spring and shock absorber combination with the added benefit of adjustable ride height and spring rates through a moveable spring perch or perches. Coilovers are to your car's advantage by reducing unsprung mass, increasing suspension travel, and allowing the car to be corner balanced.
Why do KW's cost more than other Coilovers?
The answer is simple, you get what you pay for when it comes to vehicle suspension. As such a crucial component of your vehicle, suspension is definitely something you do not want to cheap out on. KW is known for their reinforced and durable suspension components. KW's coilovers have been carefully crafted and designed by studying the flaws of competitors and improving on them. In addition KW coilovers can go lower than just about any other brand and allow you to set your car to a "slammed look", "sporty look", or anywhere in between. In the unfortunate event that anything should happen to your coilovers, KW's warranty backs all their products from manufacturer's defect.
Function
Infinitely adjustable within German TUEV-tested adjustment parameters
Shortened struts for increased spring travel
Trapezoidal threads for simple height adjustment
Three different damping technologies for individual adjustment
Elastomer bump stops with integrated dust boot protection
Easy to read documentation
Ready to use comprehensive solutions
Visually perfect – safe and unique motion dynamics
Quality
Strut housings in inox-line stainless steel technology
Anodized aluminum spring collars and add-on pieces
High-quality, high-tensile racing springs
Special ventilation and sealing system
High-quality damping components
Hardened, chromium-plated piston rods
Special guide and sealing systems
Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
Any questions feel free to call me at (714) 582-3330 ext 8003 or e-mail me at Frank@ModBargains.com
ModBargains.com is offline
Old 02-28-2012, 01:28 PM
ModBargains.com
Keep the PMs coming
-Frank
Old 03-07-2012, 03:41 PM
ModBargains.com
Got more kits in stock - send your pms!
-Frank
Old 03-14-2012, 05:47 PM
ModBargains.com
More KWs in stock!
-Frank
Old 03-22-2012, 05:41 PM
ModBargains.com
More KW kits have arrived ladies and gentlemen...I'm ready for your PMs!
-Frank
Old 03-28-2012, 03:10 PM
ModBargains.com
PMs replied!
-Frank
Old 03-30-2012, 01:33 PM
ModBargains.com
PMs replied
Giving out great discounts daily - give me a call at 714 582 3330 ext 8003.
-Frank
Old 04-06-2012, 03:28 PM
ModBargains.com
Good Friday to all! I still have couple kits left in stock - give me a call at 714 582 3330 ext 8003 to place your order.
-Frank
Old 04-13-2012, 03:45 PM
ModBargains.com
PMs replied!
-Frank
Old 04-17-2012, 01:43 PM
ModBargains.com
More kits in stock! PM Me for the best deals guaranteed!
-Frank
Old 04-17-2012, 05:02 PM
AllstarE4
Sleeps in 350Z
AllstarE4's Avatar
Frank, could you PM me pricing on the V2 and V3 kits please?
AllstarE4 is offline
Old 04-18-2012, 12:26 PM
ducky
ducky's Avatar
price for v2 and v3 to 89148 please
ducky is offline
Old 04-18-2012, 02:52 PM
ModBargains.com
You got PMs!
-Frank
Old 04-25-2012, 05:50 PM
ModBargains.com
More kits back on the shelf - send me PMs for the best deal!
-Frank
Old 04-27-2012, 01:58 PM
ModBargains.com
More kits in stock
-Frank
Old 05-01-2012, 01:34 PM
ModBargains.com
Give me a call at 714 582 3330 ext 8003 for a great deal on KW coilover kits!
-Frank
Old 05-03-2012, 02:41 PM
ModBargains.com
Did you know that KW has TUV approval on every height adjustment? This shows that you are truly getting a unique coilover system for you 350z.
Send me a PM me for the best deal ever!
-Frank
Old 05-08-2012, 09:28 AM
ModBargains.com
PMs replied!
Old 05-08-2012, 08:32 PM
hotshot350
hotshot350's Avatar
v1 and v2 shipped to 10989. thanks
hotshot350 is offline
Old 05-09-2012, 10:09 AM
ModBargains.com
PM replied!
-Frank
Quick Reply: ModBargains.com | KW Coilovers Variants 1, 2 & 3 l Best Deals Period !!!
