:: ModBargains :: CKS Coilovers :: Get ready for track this season!!
Vendor - Former Vendor
Due to the popularity of CKS suspension in the BMW community, ModBargains is now proudly presents CKS Suspension Coilovers to the Nissan Community!
Needs a price quote? PM, Email or Call @ 714-582-3330 ext 8011 , and ask for Eddie for the BEST PRICING!!
I am running a SPECIAL INTRO PRICING for the first 5 members ONLY!
CKS 350z Coilovers are built using only the highest grade materials. The upper mounts, lower mounts and spring perch are made out of 6061 T6 aluminum, and rely on SAE 9254 springs and SCM440 hardened piston rods. Giving you a smooth and solid feeling ride, no matter if your driving through city pot holes, or racing on a track at 100+ mph. The bottom line is that after all those years of development, CKS gives you a one of a kind coilover and a guaranteed peace of mind knowing your driving with the most reliable, safe and highest performing coilover on the market.
These CKS 350z Coilovers offer 3 different setups: Street, Street/Track and Full Race. This allows you to pick how aggressive you want your coilovers to ride. They also offer 12 way dampening adjustability with a 12kg spring rate on the front and 10kg spring rate on the rear, making these CKS coilovers a true set of fully adjustable coilovers.
Benefits
- Smooth yet aggressive feel
- Comes in the option of street street/track or full track setup
- Monotube design for smoother compression and stronger build
- Everything needed to install these coilovers is included
- Simple installation with no cutting or welding required
- Built using the best materials for a high performance reliable coilover
Features
- 6061 T6 aluminum upper mounts
- CKS is strong, safe and reliable
- SAE 9254 springs and SCM440 hardened piston rod spring perches
- 3 different setups, STREET, STREET/TRACK, FULL RACE
- 12 way dampening adjustability
- 12kg spring rate on the front and 10kg spring rate on the rear
- Forged Aluminum upper mount
- Forged Aluminum lower mount
- Forged Aluminum perch
- Mono tube design
- Integrated dust boot to protect shaft and seal
What are Coilovers?
A coilover suspension basically gives you a matched lowering spring and shock absorber combination with the added benefit of adjustable ride height and spring rates through a moveable spring perch or perches. Coilovers are to your car's advantage by reducing unsprung mass, increasing suspension travel, and allowing the car to be corner balanced.
If you have any questions regarding pricing, application, and availability, feel free to contact Eddie at 714-582-3330 ext 8011 or email me at eddie@modbargains.com
on
Price on street and street/track and what is the difference shipped to 67203 also I know it in your other thread but price on shop tech brake pads and rotors. Thank you.
